Successful case
Revision as of 07:51, 11 July 2018 by Sinovoip (talk | contribs)
MT7623N for 4G router
A83T design
R40 for vehicle license plate recognition
R40 for IoT gateway with Z-wave, zigbee,WiFI
A64 for IoT gateway design
H3 for Network security information analysis instrument
A20 for Unmanned aerial vehicle (uav) flight control
T3 design for vehicle traveling data recorderl
4G Multi-network fusion
this is base on BPI-R2, with 4 4G module desin. We can work with our customers to provide overall solutions
4G Multi-network fusion server
4G Multi-network fusion terminal
MultiQB
what we do : hardware design, BSP software design, tooling design, quantity production, product certification
pcba inside:
Case design:
Hardware Specification
  • SIZE: two-deck, 88x88 mm
  • Memory: 1 GB DDR3
  • USB: USB Host 2.0 x 1
  • AUDIO Input: Microphone x 1
  • VIDEO Outputs: HDMI out x 1
  • IR Receiver: x1
  • easy to add zigbee, z-wave ,NB-IoT and other IoT function.
KANO Pixel Kit
what we do : hardware design, quantity production
eBlocker
What we do : hardware design, BSP software design, PCBA support, product certification
PCBA inside:
4G Industrial safety tablets
PCBA inside:
MTK MT6737 4G watch
4G watch PCBA:
4G watch Spec
Interface Configuration:
Software Configuration:
Necessary Accessories:
