Banana Pi BPI-M2+
HardWare Specification of Banana Pi M2+(Plus)
Flash 8GB eMMC flash onboard
Network 10/100/1000 Ethernet
Onboard WIFI SDIO AP6212(option AP6181 AP6335)
Audio Outputs HDMI
LED Power led & Status led
IR IR input on board
Opnewrt
TinaLinux
Release
