Banana Pi BPI-ZERO
File:BPI-M2 zero.jpg
  • 512MB DDR 3 SDRAM.
  • Mini HDMI.
HardWare Specification of Banana pi BPI-M2 zero VS Raspberry Pi Zero W
Module Banana Pi BPI-M2 Zero Raspberry Pi Zero W
CPU H2+ Quad-core Cortex-A7 H265/HEVC 1080P Broadcom BCM2835 32 Bit 1 GHz ARM1176JZF-S single-core
GPU Mali400MP2 GPU @600MHz,Supports OpenGL ES 2.0 VideoCore IV
Memory \(SDRAM\) 512M DDR3(shared with GPU) 512 MB DDR2
Onboard Storage TF card \(Max. 64GB\) TF card \(Max. 64GB\)
Onboard Network NOPE (but can extension with PIN define) NOPE
Onboard WIFI SDIO AP6212(option AP6181、AP6335) 802.11n wireless, Bluetooth 4.1
Video decoding 1080p@60fps,H.264 Video encoding 1080p@30fps,H.264 1080p30 H.264/MPEG-4 AVC high-profile decoder and encoder
Video input A CSI input connector Camera CSI camera connector
Video Outputs mini HDMI 1.4,1080P@30fps, DHCP Mini HDMI and USB On-The-Go ports
Audio Output Mini HDMI Mini HDMI
Power Source Micro USB with 5V/2A 5V/2A
USB 2.0 Ports one USB 2.0 OTG one USB 2.0 OTG
Buttons Power Button, Reset Button Composite video and reset headers
Low-level peripherals 40 Pins Header,compatible with Raspberry Pi 3 40 PIN
uart GPIO\(1x3\) pin UART, ground UART
LED Power led & Status led Power Status LED
IR N/A N/A
Supported OS Android, Ubuntu, Debian, Rasberry Pi Image Linux
Product size 65mm × 30mm 65mm x 30mm
Weight 15g 9G
CON2-P01 VCC-3V3
CON2-P02 VCC-5V
CON2-P03 TWI0-SDA PA12-EINT12
CON2-P04 VCC-5V
CON2-P05 TWI0-SCK PA11-EINT11
CON2-P06 GND
CON2-P07 PWM1 PA6-EINT6
CON2-P09 GND
CON2-P11 UART2-RX PA1-EINT1
CON2-P13 UART2-TX PA0-EINT0
CON2-P14 GND
CON2-P15 UART2-CTS PA3-EINT3
CON2-P17 VCC-3V3
CON2-P18 PC4 PC4
CON2-P19 SPI0-MOSI PC0
CON2-P20 GND
CON2-P21 SPI0-MISO PC1
CON2-P22 UART2-RTS PA2-EINT2
CON2-P23 SPI0-CLK PC2
CON2-P24 SPI0-CS PC3
CON2-P25 GND
CON2-P26 PC7 PC7
CON2-P27 TWI1-SDA PA19-EINT19
CON2-P28 TWI1-SCK PA18-EINT18
CON2-P29 PA7-EINT7 PA7-EINT7
CON2-P30 GND
CON2-P31 PA8-EINT8 PA8-EINT8
CON2-P33 PA9-EINT9 PA9-EINT9
CON2-P34 GND
CON2-P39 GND
24 PIN CSI Camera connector of Banana pi BPI-R2
CN3-P01 NC
CN3-P02 GND
CN3-P03 CSI0-SDA PE13
CN3-P04 CSI0-AVDD
CN3-P05 CSI0-SCK PE12
CN3-P06 CSI0-Reset PE14
CN3-P07 CSI0-VSYNC PE3
CN3-P08 CSI0-PWDN PE15
CN3-P09 CSI0-HSYNC PE2
CN3-P10 CSI0-DVDD
CN3-P11 CSI0-DOVDD
CN3-P12 CSI0-D7 PE11
CN3-P13 CSI0-MCLK PE1
CN3-P14 CSI0-D6 PE10
CN3-P15 GND
CN3-P16 CSI0-D5 PE9
CN3-P17 CSI0-PCLK PE0
CN3-P18 CSI0-D4 PE8
CN3-P19 CSI0-D0 PE4
CN3-P20 CSI0-D3 PE7
CN3-P21 CSI0-D1 PE5
CN3-P22 CSI0-D2 PE6
CN3-P23 GND
CN3-P24 CSI0-DOVDD
jumper CON3 of Banana pi BPI-R2
CON3 P03 UART0-TXD PA4
CON3 P02 UART0-RXD PA5
CON3 P01 GND
PIN define:
schematic diagram:
test
Zero power with GPIO 5V input
  • Android 4.4 source code
forum pthread: http://forum.banana-pi.org/t/bpi-m2-android-4-4-source-code-download-link/3159
  • Linux source code
Android 4.4
  • 2017-11-12 update Android 4.4
Google Drive:https://drive.google.com/open?id=1TywrMLLxqJj23ql2jyzLruZw18V_XwX3
Baidu Cloud : https://pan.baidu.com/s/1c2pTXUo
Forum pthread:
RetroPie
Raspbian 8.0
2018-07-09
Ubuntu 16.04 mate desktop
2018-07-09
2017-11-13
