BPI-PC101 gesture recognition module
Revision as of 03:50, 27 June 2018 by Sinovoip (talk | contribs) (Use Uart)
  • Digital control and data output via I2C (100 KHz and 400 KHz) interface
  • ALS, PS and Gesture sensor with built-in IR LED
  • Slave Address 0x58
  • 6D Gesture Recognition Distance: 20~200 mm(up、down、left、right、hold)
  • Programmable interrupt function for ALS and PS with upper and lower thresholds
  • Support interrupt notification
Applications
  • smart lights
  • Household electrical control
  • Music control equipment
  • Game equipment
  • Smart bath
  • Distance detection
  • Smart toy
Interface
Block Diagram
PC101 DFN Pin Assignment
PC101 PIN definitions
PC101 Gesture Sensor Pin define
Pin Name Description
1 5V Power
2 GND Ground
3 INT Digital Out
4 SCL Serial Digital Input Clock
5 SDA Serial Digital I/O Data
6 TXD Serial port sends pins
7 RXD The serial port receives the pin
Application Circuit
Electrical Characteristics
  • Voltage characteristic
No pin MIN TYP MAX UNIT
1 5V 4.5 5.0 5.5 V
2 GND -0.3 0 0.3 V
3 INT GND 0/3.3 3.7 V
4 SCL -0.3 0/3.3 3.7 V
5 SDA -0.3 0/3.3 3.7 V
  • Digital interface characteristics
No Description MIN TYP MAX UNIT
1 SCL/SDA:LOW -0.3 - 1.0 V
2 SCL/SDA:HIGH 2.3 - 3.6 V
3 SCL 0 - 400 kHz
4 Pull-up resistors - 2.0 -
5 INT:LOW - - 0.4 V
6 INT:HIGH 2.4 - - V
I2C interface
I2C interface '
Ordering Chip Information Write to Slave Read from Slave
PC101 1011000 1011001
  • Receive (Single Read) data from register
  • Send (Single Write) data into register
Principles of Operation
Total register addresses are maintained inside the I2C block, each having a 8-bit register address. Each address accommodates an 8-bit data register that can be either written or read via I2C. The command registers program the sensor for various modes, setting and Interrupt threshold. The read-only registers contains output codes.
  • Register Table and Definitions
NAME R/W 8-bit Address Default Descrition
ChipID R 0x00 0xAA Chip ID
Capability R 0x01 0xF0 Gesture Functional description
LibVersion R 0x02 0xB1 Gesture Version
Gesture R 0x03 0x00 Gesture Data
Proximity R 0x04 0x00 Distance
  • 0x00: ChipID
This address holds ChipID, which is 0xAA by default and can be read to verify that I2C reading is normal.
  • 0x01: Capability
This address holds a bitmap of the gesture detection capability, 0 Disable, 1 enable.
BIT 7 6 5 4 3 2 1 0
Read Proximity Hold Left/Right Up/Down Reserved Reserved Reserved Reserved
Reset 1 1 1 1 0 0 0 0
The default is all supported, so the register defaults is 0xF0.
  • 0x02: LibVersion
This address holds Gesture Version defaults is 0xB1.
  • 0x03: Gesture Date
The address is stored with the result of gesture detection.
address of gesture detection
0: Gesture(Hold) 0xA0
1: Gesture(Up) 0xA1
2: Gesture(Down) 0xA2
3: Gesture(Left) 0xA3
4: Gesture(Right) 0xA4
  • 0x04: Proximity Date
This address holds the distance of the gesture from 0 to 255, the larger is near, the smaller is far.
How to Start
Use Uart
Connect product like the Circuit diagram , Set the Baud Rate as 115200
Using TTL-USB moudle, you can see the data like the picture
Use I2C
