BPI-PC101 gesture recognition module
- Digital control and data output via I2C (100 KHz and 400 KHz) interface
- ALS, PS and Gesture sensor with built-in IR LED
- Slave Address 0x58
- 6D Gesture Recognition Distance: 20~200 mm(up、down、left、right、hold)
- Programmable interrupt function for ALS and PS with upper and lower thresholds
- Support interrupt notification
Applications
- smart lights
- Household electrical control
- Music control equipment
- Game equipment
- Smart bath
- Distance detection
- Smart toy
Interface
Block Diagram
PC101 DFN Pin Assignment
PC101 PIN definitions
| PC101 Gesture Sensor Pin define | |||
| Pin | Name | Description | |
| 1 | 5V | Power | |
| 2 | GND | Ground | |
| 3 | INT | Digital Out | |
| 4 | SCL | Serial Digital Input Clock | |
| 5 | SDA | Serial Digital I/O Data | |
| 6 | TXD | Serial port sends pins | |
| 7 | RXD | The serial port receives the pin | |
Application Circuit
Electrical Characteristics
- Voltage characteristic
| Voltage characteristic | |||||
| No | pin | MIN | TYP | MAX | UNIT |
| 1 | 5V | 4.5 | 5.0 | 5.5 | V |
| 2 | GND | -0.3 | 0 | 0.3 | V |
| 3 | INT | GND | 0/3.3 | 3.7 | V |
| 4 | SCL | -0.3 | 0/3.3 | 3.7 | V |
| 5 | SDA | -0.3 | 0/3.3 | 3.7 | V |
- Digital interface characteristics
| Digital interface characteristics | |||||
| No | Description | MIN | TYP | MAX | UNIT |
| 1 | SCL/SDA:LOW | -0.3 | - | 1.0 | V |
| 2 | SCL/SDA:HIGH | 2.3 | - | 3.6 | V |
| 3 | SCL | 0 | - | 400 | kHz |
| 4 | Pull-up resistors | - | 2.0 | - | kΩ |
| 5 | INT:LOW | - | - | 0.4 | V |
| 6 | INT:HIGH | 2.4 | - | - | V |
I2C interface
| I2C interface ' | |||
| Ordering Chip Information | Write to Slave | Read from Slave | |
| PC101 | 1011000 | 1011001 | |
- Receive (Single Read) data from register
- Send (Single Write) data into register
Principles of Operation
Total register addresses are maintained inside the I2C block, each having a 8-bit register address. Each address accommodates an 8-bit data register that can be either written or read via I2C. The command registers program the sensor for various modes, setting and Interrupt threshold. The read-only registers contains output codes.
- Register Table and Definitions
| Register Table and Definitions | ||||
| NAME | R/W | 8-bit Address | Default | Descrition |
| ChipID | R | 0x00 | 0xAA | Chip ID |
| Capability | R | 0x01 | 0xF0 | Gesture Functional description |
| LibVersion | R | 0x02 | 0xB1 | Gesture Version |
| Gesture | R | 0x03 | 0x00 | Gesture Data |
| Proximity | R | 0x04 | 0x00 | Distance |
- 0x00: ChipID
This address holds ChipID, which is 0xAA by default and can be read to verify that I2C reading is normal.
- 0x01: Capability
This address holds a bitmap of the gesture detection capability, 0 Disable, 1 enable.
| Digital interface characteristics | ||||||||
| BIT | 7 | 6 | 5 | 4 | 3 | 2 | 1 | 0 |
| Read | Proximity | Hold | Left/Right | Up/Down | Reserved | Reserved | Reserved | Reserved |
| Reset | 1 | 1 | 1 | 1 | 0 | 0 | 0 | 0 |
The default is all supported, so the register defaults is 0xF0.
- 0x02: LibVersion
This address holds Gesture Version defaults is 0xB1.
- 0x03: Gesture Date
The address is stored with the result of gesture detection.
| address of gesture detection | |||
| 0: | Gesture(Hold) | 0xA0 | |
| 1: | Gesture(Up) | 0xA1 | |
| 2: | Gesture(Down) | 0xA2 | |
| 3: | Gesture(Left) | 0xA3 | |
| 4: | Gesture(Right) | 0xA4 | |
- 0x04: Proximity Date
This address holds the distance of the gesture from 0 to 255, the larger is near, the smaller is far.
