BPI-PC101 gesture recognition module
- Digital control and data output via I2C (100 KHz and 400 KHz) interface
- ALS, PS and Gesture sensor with built-in IR LED
- Slave Address 0x58
- 6D Gesture Recognition Distance: 20~200 mm(up、down、left、right、hold)
- Programmable interrupt function for ALS and PS with upper and lower thresholds
- Support interrupt notification
Applications
- smart lights
- Household electrical control
- Music control equipment
- Game equipment
- Smart bath
- Distance detection
- Smart toy
Interface
Block Diagram
PC101 DFN Pin Assignment
PC101 PIN definitions
| PC101 Pin define | |||
| Pin | Name | Description | |
| 1 | 5V | Power | |
| 2 | GND | Ground | |
| 3 | INT | Digital Out | |
| 4 | SCL | Serial Digital Input Clock | |
| 5 | SDA | Serial Digital I/O Data | |
| 6 | TXD | Serial port sends pins | |
| 7 | RXD | The serial port receives the pin | |
