BPI-PC101 gesture recognition module
  • Digital control and data output via I2C (100 KHz and 400 KHz) interface
  • ALS, PS and Gesture sensor with built-in IR LED
  • Slave Address 0x58
  • 6D Gesture Recognition Distance: 20~200 mm(up、down、left、right、hold)
  • Programmable interrupt function for ALS and PS with upper and lower thresholds
  • Support interrupt notification
Description
Interface
PIN definitions
