Successful case
Revision as of 22:19, 24 June 2018 by Sinovoip (talk | contribs) (MultiQB)
Network security information analysis instrument
Unmanned aerial vehicle (uav) flight control
MultiQB
what we do : hardware design, BSP software design, tooling design, quantity production, product certification
pcba inside:
Hardware Specification
  • SIZE: two-deck, 88x88 mm
  • Memory: 1 GB DDR3
  • USB: USB Host 2.0 x 1
  • AUDIO Input: Microphone x 1
  • VIDEO Outputs: HDMI out x 1
  • IR Receiver: x1
KANO Pixel Ki
what we do : hardware design, quantity production
eBlocker
What we do : hardware design, BSP software design, PCBA support, product certification
4G Industrial safety tablets
MTK MT6737 4G watch
4G watch PCBA:
4G watch Spec
Interface Configuration:
Software Configuration:
Necessary Accessories:
BPI-T3 Car design
What we do : hardware design, BSP software design , product certification
