Successful case
Revision as of 17:33, 24 June 2018 by Sinovoip (talk | contribs) (4G Industrial safety tablets)
MultiQB
Hardware Specification
  • SIZE: two-deck, 88x88 mm
  • Memory: 1 GB DDR3
  • USB: USB Host 2.0 x 1
  • AUDIO Input: Microphone x 1
  • VIDEO Outputs: HDMI out x 1
  • IR Receiver: x1
KANO Pixel Ki
eBlocker
MTK MT6737 4G watch
