Getting Started with M1P
BPI-M1P
Overview: BPI-M1P ubuntu linux
  The Banana Pi M1+ features onboard WiFi g/b/n. The board supports all classic projects and even more because of the onboard WIFi chip. Like its sibling, it can run operating systems including Android, Lubuntu, Ubuntu, Debian, and Raspbian.
  The Banana Pi M1+ is our upgraded M1 board. We feel like the onboard WiFi adds a lot more features to the board and makes it more convient for users to set up their linx desktop or router projects.
  • Dual-core 1.0GHz CPU
  • 1 GB DDR3 memeory
  • Mali-400 MP2 with Open GL ES 2.0/1.1
  • WiFi onbaord
Let's get start to develop on BPI-M1P, see amazing things happen.
 * Using your USB-Serial Connect debug console on M1P
Load your first image on M1P
 * apt-get install pv
 4.After step 3, then you can insert your TF card into M1P, and press power button setup M1P
Load your first image on M1P EMMC
 * Run your M1P with TF card
 * Plug your USB disk in M1P
 * After M1P recognise USB disk, execute "bpi-copy xxx-sd-emmc-xxx.img.zip / xxx-sd-emmc-xxx.img" to install image on EMMC
 * Then power off M1P, take TF card out, power on M1P
SATA
1. Mount SATA on M1P
  • "mount /dev/sdx /mnt/xxx"
OTG
1. On M1P console:
2. On PC terminal:
  • If adbd was succeed to set up, insert OTG-USB interface to M1P and PC(with Ubuntu system)
  • Execute "adb devices" to see if PC has recognised M1P OTG
  • If yes, we could execute "adb shell" to connect M1P by adb now
LCD 5" & LCD 7"
  • Find "BPI_M1P_LCD7.img.gz"
  • Then execute "bpi-bootsel /usr/lib/u-boot/bananapi/bpi-M1P/BPI_M1P_LCD7.img.gz"
 File:M1P bootsel lcd7.png
Touch screen
Use iperf3 to test gmac
1. On PC Terminal:
  • Execute "iperf3 -s"
2. On M1P console:
  • Execute "bluetoothctl"
  • Execute these commands:
File:M1P bluetooth.png
WiFi on M1P
  • ip link set wlan0 up
  • dhclient wlan0
Ov5640
Ov8865
  • "/test_ov8865.sh"
IR function
  • Execute "getevent"
  • Use your IR device to send information to M1P
WringPi
File System
Install QT
  • sudo apt-get install build-essential
  • sudo apt-get install libgl1-mesa-dev
  • sudo apt-get install libglu1-mesa-dev
  • sudo apt-get install freeglut3-dev
  • sudo apt-get install cmake
  • sudo apt-get install qt5-default qtcreator
