Getting Started with M2 Zero
Revision as of 22:31, 22 May 2018 by JackZengWiki (talk | contribs) (0.96 Inch OLED Display)
BPI-M2U
  • 512MB SDRAM.
  • Mini HDMI.
How to create a image
  • Boot your SD card with M2 Zero, after M2 Zero finish starting, copy your files and config your system, then poweroff M2 Zero. [If you don't want to config your system, you can skip this step]
  • Execute "bpi-migrate -c bpi-m2z.conf -c ubuntu-mate-from-sd.conf -d /dev/sdx"
OTG
1. On M2 Zero console:
2. On PC terminal:
  • If adbd was succeed to set up, insert OTG-USB interface to M2 Zero and PC(with Ubuntu system)
  • Execute "adb devices" to see if PC has recognised M2 ZeroP OTG
  • If yes, we could execute "adb shell" to connect M2 Zero by adb now
USB Ethernet
  • Prepare a USB to OTG wire, usb ethernet adapter
  • Use iperf3 to test network
  • Execute "bluetoothctl"
  • Execute these commands:
  • ip link set wlan0 up
  • dhclient wlan0
We use HDF5640 camara.
IR function
  • Execute "getevent"
  • Use your IR device to send information to M2 Zero
WringPi
