BPI-Bit
The BPI:bit (also referred to as BPI-bit, stylised as webduino:bit) is an ESP32 with Xtensa 32bit LX6 dual-core processor based embedded system. support Webduino, Arduino, MicroPython as well as Scratch X programming environments.
BPI:Bit development board 5 cm width 5 cm long, weighs about 10 ~ 12 grams, in addition to below 20 Pin goldfinger interface, a built-in a 25 full-color LED lighting matrix, two photosensitive resistance button switch a temperature sensing resistor A buzzer and a nine shaft sensor (triaxial acceleration Three-axis gyroscope and three-axis magnetic compass), space configuration is as follows:
- Full color LED matrix :4
- photosensitive sensor :36 (A0 left) 39 (A3 right upper)
- button switch :35 (A) 27 (B)
- temperature sensor :34 (A6)
- buzzer: 25
- 9 axis sensor mpu-9250:21,22.
BPI:bit hardware
BPI:bit hardware description
The board is 5 cm × 5 cm and has an ESP32 module with Xtensa 32bit LX6 dual-core processor, with a capacity of up to 600DMIPS, with a built-in 448KB ROM and 520 KB SRAM.accelerometer and magnetometer sensors,2.4G WiFI,Bluetooth and USB connectivity, a display consisting of 25 LEDs, two programmable buttons, and can be powered by either USB or an external battery pack.The device inputs and outputs are through five ring connectors that are part of the 23-pin edge connector.
BPI:bit interface
BPI:bit edge interface
BPI:bit PIN define
BPI:bit edge interface fully compatible micro:bit. so you can use micro:bit accessories on BPI:bit
P3 | ADC2_CH4 | GPIO13 | |||
P4 | ADC2_CH3 | GPIO16 | |||
P5 | ADC1_CH7 | GPIO35 | |||
P6 | ADC2_CH5 | GPIO12 | |||
P7 | ADC2_CH6 | GPIO14 | |||
P1 | ADC1_CH4 | GPIO32 | |||
P8 | GPIO16 | ||||
P9 | GPIO17 | ||||
P11 | ADC2_CH7 | GPIO27 | |||
P12 | ADC2_CH2 | GPIO02 | |||
P2 | ADC1_CH5 | GPIO33 | |||
P13 | GPIO18 | SPI_SS | |||
P14 | GPIO19 | SPI_SCK | |||
P15 | GPIO23 | SPI_MISO | |||
P16 | GPIO05 | SPI_MOSI | |||
3V3 | POWER:3V3 | ||||
P19 | GPIO22 | I2C_SCL | |||
P20 | GPIO21 | I2C_SDA | |||
GND | GROUND | ||||
GND | GROUND | ||||
GND | GROUND |
5*5 LED list
BPI:bit have 25 LEDs on board ,you can control it with 1 GPIO . easy to use it.
20 | 15 | 10 | 5 | 0 |
21 | 16 | 11 | 6 | 1 |
22 | 17 | 12 | 7 | 2 |
23 | 18 | 13 | 8 | 3 |
24 | 19 | 14 | 9 | 4 |
MPU9250 9 axis sensor
A powerful 9 axis sensor, MPU9250, is placed on the BPI:bit board. and MPU9250 use I2C 0x69 address.
bpi:bit VS micro:bit
bpi:bit VS micro:bit | |||
Module | bpi:bit | micro:bit | |
CPU | Dual-core 32bit Xtensa LX6, up to 240MHz | 32bit ARM Cortex M0, up to 16MHz | |
RAM | 520KB | 256KB | |
ROM | 448KB | Unkown | |
Flash | 4MB | 16KB | |
WIFI | 802.11 b/g/n/e/i | N/A | |
Bluetooth | BT4.2 BR/EDR and BLE | BLE only | |
photosensitive sensor | 2 light sensor | Basic light detection function on LEDs | |
temperature sensor | Stand along temperature sensor | On CPU chip temperature sensor | |
other senesor | MPU-9250 9-axis MotionTracking : 3-axis gyroscope, 3-axis accelerometer, 3-axis magnetometer | 3-axis Accelerometer; 3-axis magnetometer | |
Buzzer | 1x Buzzer | N/A | |
5*5 LEDS | 25 intelligent-control full-color (16777216 color) LEDs, Cascading all LEDs by a single line. | 25 red LEDs | |
25 GPIO | edge interface (compatible with most micro:bit I/O features) | edge interface | |
Button | 2 programmable buttons | 2 programmable buttons | |
micro USB | 1x micro USB(UART) | 1 x micro USB(Mass Storage Device) | |
Software | Webduino, Arduino, MicroPython, Scratch X | Microsoft MakeCode, MicroPython, Scratch X | |
Size | 5*5 cm | 5*4 cm |
BPI-bit software
BPI:bit for webduino
About webduino
Webduino working principle:
- 1 use WebComponents integration Breakout.
- 2 use WebSocket(Firmata) to interacting with the server.
- 3 Server use TCP/IP(Firmata) to control webduino terminal.
Webduino project VS Arduino and micro:bit project | |||
item compared | Webduino | Arduino | Micro:bit |
development language | HTML/JavaScript | C/C++ | Python/JavaScript |
development environment | WEB browser | Arduino IDE | JavaScript Blocks |
Simulator | Webduino Simulator | Third-party support | MciroSoft arm Simulator |
graphical programming | Wbduino blockly | Third-party Scratch | Blockly |
Cloud Server | webduino cloud | N/A | N/A |
attended mode | WiFi | USB | USB |
Update the program | web online update | USB burn | USB disk |
- Quick start Webduino Blockly and simulator
Note: BPI:bit have burn webduino Firmware defaults. Only when you clear the factory Settings and use arduino open source, will you need to burn webduinofirmware again.
Burning method:
Select ESP32 DownloadTool:
File and burn position corresponding | |||
set | file name | Position | |
1 | bootloader_dio_40m.bin | 0x1000 | |
2 | partitions.bin | 0x8000 | |
3 | boot_app0.bin | 0xe000 | |
4 | bit_default.bin | 0x10000 |
- SpiFlashConfig:
SpiFlashConfig | |||
1 | SPI SPEED | 40NHz | |
2 | SPI MODE | DIO | |
3 | FLASH SIZE | 32Mbit | |
4 | COM | COMx(Fill in the port number assigned by the computer) | |
5 | BAUD | 1152000 |
During the burning process:
Finished:
Burn time is about 20s
BPI: bit Online tutorials
BPI:bit for arduino
Arduino IDE
microPyhton
Scratch
- BPI:bit for webduino source code on github: https://github.com/webduinoio
- BPI:bit for arduino Source code on Github: https://github.com/yelvlab/BPI-BIT
documents
- BPI:bit dxf file : http://forum.banana-pi.org/uploads/default/original/2X/0/0b86ccaeb565cdeef093164fd1ff837727ca2887.rar
- Taiwan server : http://webuino.io
- Overworld server: http://webduino.io
- china mainland : http://www.webduino.com.cn
- Easy to buy BPI:bit sample form aliexpress
