Getting Started with BPI-W2
Read more: Banana Pi BPI-W2
Load your first image on W2
Build your own image on W2
How to make a SD card with bootloader
there are two ways to boot w2, controlled by SW4
- 0 boot from emmc.
- 1 boot from SPI + SD card.
After power on, there are 3 steps must be done before loading kernel,(Normally they all are called bootloader):
- step 3: u-boot;
RTD1296 supports booting from eMMC and SPI flash, so if we want to boot W2 from SD card, (that means we put u-boot on the SD card.) the second step code must be written to SPI flash, normally it’s done in factory before the board sending out, and the code is fixed and provided by RTK without source. We need not care about it, it does a simple job.
In fact, if the board will boot from eMMC, the second code must be written to eMMC first too, remember that we introduced how to do it with u-boot together on other pages. Normally it’s also been done in factory.
The u-boot for eMMC and SD card are different, normally eMMC u-boot 's name is dvrboot.exe.bin, and u-boot for SD card name is u-boot.bin.
Write u-boot to SD card
The u-boot file for booting from SD card is here: https://drive.google.com/drive/folders/17ShSHLOvxeYA6tI9HQXOAb3O7RjqfD_6?usp=sharing
- step 1: build a SD card system according:
- 2.1.3.2.1 How to make and run the 64-bit ubuntu 16.04 on SD card 2018-4-28
- step 2: boot up the board with eMMC and press ‘Esc’ key to let board stays on u-boot prompt;
- step 3: using tftp to get u-boot.bin file from network;
tftp 0x1500000 u-boot.bin
- step4: using sd command to write it to SD card:
sd write 0x1500000 0x50 0x3f0
1.Requirement:
- 2.A banana Pi W2 board;
- 3.A SD card;
- ouImage – kernel image
Requirement:
Steps:
s98007058 01500000
Requirement:
Steps: (on the host):
- 1.mkdir rootfs
- 2.su root
!/bin/bash
function mnt() {
echo "MOUNTING"
sudo mount -t proc /proc ${2}proc
sudo mount -t sysfs /sys ${2}sys
sudo mount -o bind /dev ${2}dev
sudo mount -o bind /dev/pts ${2}dev/pts
sudo chroot ${2}
function umnt() {
echo "UNMOUNTING"
sudo umount ${2}proc
sudo umount ${2}sys
sudo umount ${2}dev/pts
sudo umount ${2}dev
if [ "$1" == "-m" ] && [ -n "$2" ] ;
then
mnt $1 $2
elif [ "$1" == "-u" ] && [ -n "$2" ];
then
umnt $1 $2
else
echo ""
echo "Either 1'st, 2'nd or both parameters were missing"
echo ""
echo "1'st parameter can be one of these: -m(mount) OR -u(umount)"
echo "2'nd parameter is the full path of rootfs directory(with trailing '/')"
echo ""
echo "For example: ch-mount -m /media/sdcard/"
echo ""
echo 1st parameter : ${1}
echo 2nd parameter : ${2}
fi
- 8../ch-mount.sh -m rootfs/
- 10.apt-get install udev
- 13.exit
- 14../ch-mount.sh -u rootfs/
Until now, the ubuntu file system have been built successfully on the host, next we will write it to the SD card.
Requirement:
- 1.A SD card;
Steps:
Steps:
- 5.apt-get update
6.Furthermore:
PDF format file download
Ubuntu 16.04 Install and run Node.js and http-server
- insltall Node.js
OpenWrt
Burn OpenWRT with Linux kernel 4.4
1.About this release
2.Burn OpenWRT on W2 steps:
- MP_Tool
- Set your console parameters
- Choose "LK option"
- hypertrm
::s98007058 ::01500000
- U disk
- install.img
2)Burn OpenWRT on W2 steps:
emmc.uImage
bluecore.audio
rescue.emmc.dtb
save
go ru
3.Image & Tools link:
Baidu Drive: https://pan.baidu.com/s/1Rs9F46wNJibORaeCfVh4wg PinCode:1w4w
4.BPI-W2 run OpenWRT video:
