Getting Started with M2P
Revision as of 17:23, 21 May 2018 by JackZengWiki (talk | contribs) (Guvcview)
Overview: BPI-M2+ Ubuntu linux
Overview:BPI-M2+ Debian linux
BPI-M2+ H3
  • Quad-core 1.2GHz Cortex-A7 H3
  • 1GB DDR3
  • 8GB eMMC onboard
  • WiFi and BlueTooth onboard
Let's get start to develop on BPI-M2P, see amazing things happen.
Load your first image on M2P
 * Here is the example forum thread link: http://forum.banana-pi.org/t/banana-pi-bpi-m2p-new-image-release-ubuntu-16-04-v1-1/5719
 * apt-get install pv
 4.After step 3, then you can insert your TF card into M2P, and press power button setup M2P.
How to build kernel
How to build uboot
How to create a image
  • Prepare a SD card which have installed system(Ubuntu/Respbian/..)
  • Boot your SD card with M2P, after M2P finish starting, copy your files and config your system, then poweroff M2P. [If you don't want to config your system, you can skip this step]
  • Execute "bpi-migrate -c bpi-m2p.conf -c ubuntu-mate-from-sd.conf -d /dev/sdx"
  • Use iperf3 to test gmac
  • Execute "bluetoothctl"
  • Execute these commands:
WiFi on M2P
Driver code:
  • ip link set wlan0 up
  • dhclient wlan0
We use HDF5640 camara.
IR function
  • Execute getevent
  • Use your IR device to send information to M2P
WringPi
  • Execute bpi_test_lcd1602
  • Execute bpi_test_52pi
  • Execute bpi_test_gpio40
Reference Link
