Getting Start with M2U
BPI-M2U
- 2GB DDR3 SDRAM
- 8 GB eMMC storage
- SATA Interface
Load your first image on M2U
1.You could download latest image from our forum * Here is the example forum thread link:
2.Install bpi-tools on your system * apt-get install pv * curl -sL https://github.com/BPI-SINOVOIP/bpi-tools/raw/master/bpi-tools | sudo -E bash
SATA
1. Mount SATA on M2U
- "fdisk /dev/sdx" to create new partition , after created input "wq" to save and quit.
- "mount /dev/sdx /mnt/xxx"
OTG
1. On M2U console:
2. On PC terminal:
LCD 5" & LCD 7"
- Find "BPI_M2U_LCD7.img.gz"
Touch screen
- Use iperf3 to test gmac
1.
- Execute "bluetoothctl"
- Execute these commands:
WiFi on M2U
We use HDF5640 camara.
- test_ov5640_image_mode.sh
- cameratest.sh
IR function
- Execute getevent
WringPi
- Execute bpi_test_lcd1602
- Execute bpi_test_52pi
- Execute bpi_test_gpio40
