Getting Start with M2U
BPI-M2U
- 2GB DDR3 SDRAM
- 8 GB eMMC storage
- SATA Interface
Load your first image on M2U
1.You could download latest image from our forum * Here is the example forum thread link:
2.Install bpi-tools on your system * apt-get install pv * curl -sL https://github.com/BPI-SINOVOIP/bpi-tools/raw/master/bpi-tools | sudo -E bash
SATA
- fdisk /dev/sdx 对硬盘创建新的分区,wq保存
- 格式化:mkfs.ext2 /dev/sdx
- mount /dev/sdx /mnt/xxx
- time dd if=/dev/xxx of=/dev/null bs=1M count=1000 测试读速度
- time dd if=/dev/zero of=/dev/sdx 测试写速度
OTG
LCD 5"
LCD 7"
Touch screen
- Use iperf3 to test gmac
- Execute "bluetoothctl"
- Execute these commands:
WiFi on M2U
We use HDF5640 camara.
- test_ov5640_image_mode.sh
- cameratest.sh
IR function
- Execute getevent
WringPi
- Execute bpi_test_lcd1602
- Execute bpi_test_52pi
- Execute bpi_test_gpio40
