BPI-Bit
Revision as of 22:56, 18 May 2018 by Sinovoip (talk | contribs) (BPI:bit VS Micro:bit)
Overview: ESP32
Overview: ESP32
BPI:bit hardware
BPI:bit hardware description
BPI:bit interface
BPI:bit edge interface
BPI:bit PIN define
P3 ADC2_CH4 GPIO13
P0 ADC2_CH8 DAC_1 GPIO25
P4 ADC2_CH3 GPIO16
P5 ADC1_CH7 GPIO35
P6 ADC2_CH5 GPIO12
P7 ADC2_CH6 GPIO14
P1 ADC1_CH4 GPIO32
P8 GPIO16
P9 GPIO17
P10 ADC2_CH9 DAC_2 GPIO26
P11 ADC2_CH7 GPIO27
P12 ADC2_CH2 GPIO02
P2 ADC1_CH5 GPIO33
P13 GPIO18 SPI_SS
P14 GPIO19 SPI_SCK
P15 GPIO23 SPI_MISO
P16 GPIO05 SPI_MOSI
3V3 POWER:3V3
3V3 POWER:3V3
3V3 POWER:3V3
P19 GPIO22 I2C_SCL
P20 GPIO21 I2C_SDA
GND GROUND
GND GROUND
GND GROUND
5*5 LED list
25 5*5 LED list of BPI:bit
20 15 10 5 0
21 16 11 6 1
22 17 12 7 2
23 18 13 8 3
24 19 14 9 4
MPU9250
A powerful 9 axis sensor, MPU9250, is placed on the BPI:bit board.
BPI:bit Micro:bit
CPU Xtensa 32bit LX6 single/dual-core 32bit Arm cortex M0
RAM 520KB
ROM 448KB
WIFI 802.11 b/g/n/e/i N/A
Bluetooth BT4.2 BR/EDR and BLE BLE
25 LEDS
BPI-bit software
BPI:bit for webduino
BPI: bit Webduino Firmware Burning
Burning method:
Select ESP32 DownloadTool:
set file name Position
2 partitions.bin 0x8000
3 boot_app0.bin 0xe000
4 bit_default.bin 0x10000
- SpiFlashConfig:
SpiFlashConfig
1 SPI SPEED 40NHz
2 SPI MODE DIO
3 FLASH SIZE 32Mbit
5 BAUD 1152000
During the burning process:
Finished:
Burn time is about 20s
BPI:bit for arduino
Arduino
documents
