Banana Pi BPI-ZERO
- Quad Core ARM Cortex A7 CPU H2+.
- 512MB SDRAM.
- Mini HDMI.
| HardWare Specification of Banana pi BPI-M2 zero | |||
| CPU | H2+ Quad-core Cortex-A7 H265/HEVC 1080P | ||
| GPU | Mali400MP2 GPU @600MHz,Supports OpenGL ES 2.0 | ||
| Memory \(SDRAM\) | 512M \(shared with GPU\) | ||
| Onboard Storage | TF card \(Max. 64GB\) | ||
| Onboard Network | NOPE | ||
| Onboard WIFI | SDIO AP6212(option AP6181、AP6335) | ||
| Video Input | A CSI input connector Camera:1 Supports 8-bit YUV422 CMOS sensor interface,2 Supports CCIR656 protocol for NTSC and PAL,3 Supports SM pixel camera sensor ,4 Supports video capture solution up to 1080p@30fps | ||
| Video Outputs | Supports Mini HDMI Port | ||
| Audio Output | Mini HDMI | ||
| Power Source | Micro USB with 5V/2A | ||
| USB 2.0 Ports | one USB 2.0 OTG | ||
| Buttons | Power Button, Reset Button | ||
| Low-level peripherals | 40 Pins Header,compatible with Raspberry Pi 3 | ||
| uart GPIO\(1x3\) pin | UART, ground | ||
| LED | Power led & Status led | ||
| IR | nope | ||
| Supported OS | Android, Ubuntu, Debian, Rasberry Pi Image | ||
| Product size | 65mm × 30mm | ||
| Weight | 35g | ||
| HardWare Specification of Banana pi BPI-R2 | |||
| CON2-P01 | VCC-3V3 | ||
| CON2-P02 | VCC-5V | ||
| CON2-P04 | VCC-5V | ||
| CON2-P06 | GND | ||
| CON2-P09 | GND | ||
| CON2-P14 | GND | ||
| CON2-P17 | VCC-3V3 | ||
| CON2-P18 | PC4 | PC4 | |
| CON2-P20 | GND | ||
| CON2-P25 | GND | ||
| CON2-P26 | PC7 | PC7 | |
| CON2-P30 | GND | ||
| CON2-P34 | GND | ||
| CON2-P39 | GND | ||
| 24 PIN CSI Camera connector of Banana pi BPI-R2 | |||
| CN3-P01 | NC | ||
| CN3-P02 | GND | ||
| CN3-P04 | CSI0-AVDD | ||
| CN3-P10 | CSI0-DVDD | ||
| CN3-P11 | CSI0-DOVDD | ||
| CN3-P15 | GND | ||
| CN3-P16 | CSI0-D5 | PE9 | |
| CN3-P18 | CSI0-D4 | PE8 | |
| CN3-P19 | CSI0-D0 | PE4 | |
| CN3-P20 | CSI0-D3 | PE7 | |
| CN3-P21 | CSI0-D1 | PE5 | |
| CN3-P22 | CSI0-D2 | PE6 | |
| CN3-P23 | GND | ||
| CN3-P24 | CSI0-DOVDD | ||
| jumper CON3 of Banana pi BPI-R2 | |||
| CON3 P01 | GND | ||
