Getting Started with M2P
Read more: Banana Pi BPI-M2+
BPI-M2+ H3
- 1GB DDR3
- 8GB eMMC onboard
- WiFi and BlueTooth onboard
Let's get start to develop on BPI-M2P, see amazing things happen.
Load your first image on M2P
1.You could download latest image from our forum * Here is the example image link: https://pan.baidu.com/s/1Jf-AZF6a4jZugqqx2QXH3Q
2.Install bpi-tools on your Ubuntu * apt-get install pv * curl -sL https://github.com/BPI-SINOVOIP/bpi-tools/raw/master/bpi-tools | sudo -E bash
4.After step 3, then you can insert your TF card into M2P, and press power button setup M2P.
Build your own image on M2P
- Execute "bluetoothctl"
- If you don't know how to use bluetoothctl, type help, you will see more commands
- Execute these commands:
WiFi and Ap mode on M2P
AP mode
We use HDF5640 camara.
- test_ov5640_image_mode.sh
- cameratest.sh
IR function
- Execute getevent
WringPi
- Execute bpi_test_lcd1602
- Execute bpi_test_52pi
- Execute bpi_test_gpio40
