Banana Pi BPI-ZERO
- Quad Core ARM Cortex A7 CPU H2+.
- 512MB SDRAM.
- Mini HDMI.
| HardWare Specification of Banana pi BPI-M2 zero | |||
| CPU | H2+ Quad-core Cortex-A7 H265/HEVC 1080P | ||
| GPU | Mali400MP2 GPU @600MHz,Supports OpenGL ES 2.0 | ||
| Memory \(SDRAM\) | 512M \(shared with GPU\) | ||
| Onboard Storage | TF card \(Max. 64GB\) | ||
| Onboard Network | NOPE | ||
| Onboard WIFI | SDIO AP6212(option AP6181、AP6335) | ||
| Video Input | A CSI input connector Camera:1 Supports 8-bit YUV422 CMOS sensor interface,2 Supports CCIR656 protocol for NTSC and PAL,3 Supports SM pixel camera sensor ,4 Supports video capture solution up to 1080p@30fps | ||
| Video Outputs | Supports Mini HDMI Port | ||
| Audio Output | Mini HDMI | ||
| Power Source | Micro USB with 5V/2A | ||
| USB 2.0 Ports | one USB 2.0 OTG | ||
| Buttons | Power Button, Reset Button | ||
| Low-level peripherals | 40 Pins Header,compatible with Raspberry Pi 3 | ||
| uart GPIO\(1x3\) pin | UART, ground | ||
| LED | Power led & Status led | ||
| IR | nope | ||
| Supported OS | Android, Ubuntu, Debian, Rasberry Pi Image | ||
| Product size | 65mm × 30mm | ||
| Weight | 35g | ||
| HardWare Specification of Banana pi BPI-R2 | ||||
| GPIO Pin Name | Default Function | Function2:GPIO | Function3 | |
| CON2-P01 | VCC-3V3 | |||
| CON2-P02 | VCC-5V | |||
| CON2-P03 | TWI0-SDA | PA12-EINT12 | ||
| CON2-P04 | VCC-5V | |||
| CON2-P05 | TWI0-SCK | PA11-EINT11 | ||
| CON2-P06 | GND | |||
| CON2-P07 | PWM1 | PA6-EINT6 | ||
| CON2-P08 | UART3-TX | PA13-EINT13 | SPI1-CS | |
| CON2-P09 | GND | |||
| CON2-P10 | UART3-RX | PA14-EINT14 | SPI1-CLK | |
| CON2-P11 | UART2-RX | PA1-EINT1 | ||
| CON2-P12 | UART3-CTS | PA16-EINT16 | SPI1-MISO | |
| CON2-P13 | UART2-TX | PA0-EINT0 | ||
| CON2-P14 | GND | |||
| CON2-P15 | UART2-CTS | PA3-EINT3 | ||
| CON2-P16 | UART3-RTS | PA15-EINT15 | SPI1-MOSI | |
| CON2-P17 | VCC-3V3 | |||
| CON2-P18 | PC4 | PC4 | ||
| CON2-P19 | SPI0-MOSI | PC0 | ||
| CON2-P20 | GND | |||
| CON2-P21 | SPI0-MISO | PC1 | ||
| CON2-P22 | UART2-RTS | PA2-EINT2 | ||
| CON2-P23 | SPI0-CLK | PC2 | ||
| CON2-P24 | SPI0-CS | PC3 | ||
| CON2-P25 | GND | |||
| CON2-P26 | PC7 | PC7 | ||
| CON2-P27 | TWI1-SDA | PA19-EINT19 | ||
| CON2-P28 | TWI1-SCK | PA18-EINT18 | ||
| CON2-P29 | PA7-EINT7 | PA7-EINT7 | ||
| CON2-P30 | GND | |||
| CON2-P31 | PA8-EINT8 | PA8-EINT8 | ||
| CON2-P32 | PL2-S-EINT2 | PL2-S-EINT2 | ||
| CON2-P33 | PA9-EINT9 | PA9-EINT9 | ||
| CON2-P34 | GND | |||
| CON2-P35 | PA10-EINT10 | PA10-EINT10 | ||
| CON2-P36 | PL4-S-EINT4 | PL4-S-EINT4 | ||
| CON2-P37 | PA17-EINT17 | PA17-EINT17 | SPDIF-OUT | |
| CON2-P38 | PA21-EINT21 | PA21-EINT21 | ||
| CON2-P39 | GND | |||
| CON2-P40 | PA20-EINT20 | PA20-EINT20 | ||
