Banana Pi BPI-ZERO
[hide]Introduction
- Quad Core ARM Cortex A7 CPU H2+.
- 512MB SDRAM.
- Mini HDMI.
HardWare Specification of Banana pi BPI-M2 zero | |||
CPU | H2+ Quad-core Cortex-A7 H265/HEVC 1080P | ||
GPU | Mali400MP2 GPU @600MHz,Supports OpenGL ES 2.0 | ||
Memory \(SDRAM\) | 512M \(shared with GPU\) | ||
Onboard Storage | TF card \(Max. 64GB\) | ||
Onboard Network | NOPE | ||
Onboard WIFI | SDIO AP6212(option AP6181、AP6335) | ||
Video Input | A CSI input connector Camera:1 Supports 8-bit YUV422 CMOS sensor interface,2 Supports CCIR656 protocol for NTSC and PAL,3 Supports SM pixel camera sensor ,4 Supports video capture solution up to 1080p@30fps | ||
Video Outputs | Supports Mini HDMI Port | ||
Audio Output | Mini HDMI | ||
Power Source | Micro USB with 5V/2A | ||
USB 2.0 Ports | one USB 2.0 OTG | ||
Buttons | Power Button, Reset Button | ||
Low-level peripherals | 40 Pins Header,compatible with Raspberry Pi 3 | ||
uart GPIO\(1x3\) pin | UART, ground | ||
LED | Power led & Status led | ||
IR | nope | ||
Supported OS | Android, Ubuntu, Debian, Rasberry Pi Image | ||
Product size | 65mm × 30mm | ||
Weight | 35g |
HardWare Specification of Banana pi BPI-R2 | |||
CON2-P01 | VCC-3V3 | ||
CON2-P02 | VCC-5V | ||
CON2-P04 | VCC-5V | ||
CON2-P06 | GND | ||
CON2-P09 | GND | ||
CON2-P11 | UART2-RX | | | |
CON2-P12 | PA16-EINT16 | SPI1-MISO | | ||
CON2-P13 | PA0-EINT0 | | | ||
CON2-P14 | | | | ||
CON2-P15 | PA3-EINT3 | | | ||
CON2-P16 | PA15-EINT15 | SPI1-MOSI | | ||
CON2-P17 | | | | ||
CON2-P18 | PC4 | | | ||
CON2-P19 | PC0 | | | ||
CON2-P20 | | | | ||
CON2-P21 | PC1 | | | ||
CON2-P22 | PA2-EINT2 | | | ||
CON2-P23 | PC2 | | | ||
CON2-P24 | PC3 | | | ||
CON2-P25 | | | | ||
CON2-P26 | PC7 | | | ||
CON2-P27 | PA19-EINT19 | | | ||
CON2-P28 | PA18-EINT18 | | | ||
CON2-P29 | PA7-EINT7 | | | ||
CON2-P30 | | | | ||
CON2-P31 | PA8-EINT8 | | | ||
CON2-P32 | PL2-S-EINT2 | | | ||
CON2-P33 | PA9-EINT9 | | | ||
CON2-P34 | | | | ||
CON2-P35 | PA10-EINT10 | | | ||
CON2-P36 | PL4-S-EINT4 | | | ||
CON2-P37 | PA17-EINT17 | SPDIF-OUT | | ||
CON2-P38 | PA21-EINT21 | | | ||
CON2-P39 | | | | ||
CON2-P40 | PA20-EINT20 | | | |
