Banana Pi BPI-ZERO
  • Quad Core ARM Cortex A7 CPU H2+.
  • 512MB SDRAM.
  • Mini HDMI.
HardWare Specification of Banana pi BPI-M2 zero
CPU H2+ Quad-core Cortex-A7 H265/HEVC 1080P
GPU Mali400MP2 GPU @600MHz,Supports OpenGL ES 2.0
Memory \(SDRAM\) 512M \(shared with GPU\)
Onboard Storage TF card \(Max. 64GB\)
Onboard Network NOPE
Onboard WIFI SDIO AP6212(option AP6181、AP6335)
Video Input A CSI input connector Camera:1 Supports 8-bit YUV422 CMOS sensor interface,2 Supports CCIR656 protocol for NTSC and PAL,3 Supports SM pixel camera sensor ,4 Supports video capture solution up to 1080p@30fps
Video Outputs Supports Mini HDMI Port
Audio Output Mini HDMI
Power Source Micro USB with 5V/2A
USB 2.0 Ports one USB 2.0 OTG
Buttons Power Button, Reset Button
Low-level peripherals 40 Pins Header,compatible with Raspberry Pi 3
LED Power led & Status led
IR nope
Supported OS Android, Ubuntu, Debian, Rasberry Pi Image
Product size 65mm × 30mm
Weight 35g
HardWare Specification of Banana pi BPI-R2
Default Function | Function2:GPIO | Function3 |
CON2-P01 VCC-3V3
CON2-P02 VCC-5V
CON2-P03 TWI0-SDA PA12-EINT12
CON2-P04 VCC-5V
CON2-P05 TWI0-SCK PA11-EINT11
CON2-P06 GND
CON2-P07 PWM1 PA6-EINT6
CON2-P09 GND
CON2-P11 UART2-RX |
CON2-P12 PA16-EINT16 | SPI1-MISO |
CON2-P13 PA0-EINT0 | |
CON2-P14 | |
CON2-P15 PA3-EINT3 | |
CON2-P16 PA15-EINT15 | SPI1-MOSI |
CON2-P17 | |
CON2-P18 PC4 | |
CON2-P19 PC0 | |
CON2-P20 | |
CON2-P21 PC1 | |
CON2-P22 PA2-EINT2 | |
CON2-P23 PC2 | |
CON2-P24 PC3 | |
CON2-P25 | |
CON2-P26 PC7 | |
CON2-P27 PA19-EINT19 | |
CON2-P28 PA18-EINT18 | |
CON2-P29 PA7-EINT7 | |
CON2-P30 | |
CON2-P31 PA8-EINT8 | |
CON2-P32 PL2-S-EINT2 | |
CON2-P33 PA9-EINT9 | |
CON2-P34 | |
CON2-P35 PA10-EINT10 | |
CON2-P36 PL4-S-EINT4 | |
CON2-P37 PA17-EINT17 | SPDIF-OUT |
CON2-P38 PA21-EINT21 | |
CON2-P39 | |
CON2-P40 PA20-EINT20 | | |
Opnewrt
Release
