BPI I2C electric level conversion expand module
Revision as of 04:21, 16 May 2018 by Sinovoip (talk | contribs) (Produce Overview)
Front:
![](I2C Level Shlfting board 1.JPG)
Back:
![](I2C Level Shlfting board 2.JPG)
Product Specification
![](I2c l1.png)
Produce Overview
The I2C electric level conversion module is specifically designed for Banana Pi. The module convert the 3.3V of I2C electric level to 5V level or convert 5V to 3.3V. The module made by NMOSFET, it makes the module have fast feedback and the low power. There is an pull-up resistor to solve the open-drain output level is not stable.
Produce Features
1. Strong anti-interference ability 2. Pull-up resistor on board 3. 1.8 V, 2.4 V and 3 V, 5 V voltage conversion to each other
Port
1. 1X6 Header
Product Parameters
  • 1. Working voltage: 1.8V-5.5V
  • 2. 4 conversion channel
Typical Application
Interface electric level conversion
How to use
![](I2c l2.png)
As show in picture, the left Header is the output or input port of lower electric level; The right Header is the output or input port of higher electric level.
