Banana Pi BPI-ZERO
- Quad Core ARM Cortex A7 CPU H2+.
- 512MB SDRAM.
- Mini HDMI.
| HardWare Specification of Banana pi BPI-M2 zero | |||
| CPU | H2+ Quad-core Cortex-A7 H265/HEVC 1080P | ||
| GPU | Mali400MP2 GPU @600MHz,Supports OpenGL ES 2.0 | ||
| Memory \(SDRAM\) | 512M \(shared with GPU\) | ||
| Onboard Storage | TF card \(Max. 64GB\) | ||
| Onboard Network | NOPE | ||
| Onboard WIFI | SDIO AP6212(option AP6181、AP6335) | ||
| Video Input | A CSI input connector Camera:1 Supports 8-bit YUV422 CMOS sensor interface,2 Supports CCIR656 protocol for NTSC and PAL,3 Supports SM pixel camera sensor ,4 Supports video capture solution up to 1080p@30fps | ||
| Video Outputs | Supports Mini HDMI Port | ||
| Audio Output | Mini HDMI | ||
| Power Source | Micro USB with 5V/2A | ||
| USB 2.0 Ports | one USB 2.0 OTG | ||
| Buttons | Power Button, Reset Button | ||
| Low-level peripherals | 40 Pins Header,compatible with Raspberry Pi 3 | ||
| uart GPIO\(1x3\) pin | UART, ground | ||
| LED | Power led & Status led | ||
| IR | nope | ||
| Supported OS | Android, Ubuntu, Debian, Rasberry Pi Image | ||
| Product size | 65mm × 30mm | ||
| Weight | 35g | ||
