Getting Started with M2S
- 1 Introduction
- 2 specifications
- 3 development
- 3.1 Prepare
- 3.2 Android
- 3.3 Linux
- 3.3.1 Prepare
- 3.3.2 Install Image to SDcard
- 3.3.3 Install Image to EMMC
- 3.3.4 Build Linux Source Code
- 3.3.5 DTB overlay
- 3.3.6 Enable Camera
- 3.3.7 Switch Mipi Panel
- 3.3.8 Panel Rotation
- 3.3.9 WiringPi
- 3.3.10 RPi.GPIO
- 3.3.11 WiringPi2-Python
- 3.3.12 Luma.Examples
- 3.3.13 HDMI LCD
- 3.3.14 Custom Linux Boot Logo
- 3.4 Other Development
Android DTB overlay
- How to apply a new dtbo
- 1. ADB command via sysfs
- 3. Settings App(To-Do)
Install OpenGapps
- 2. Download device_id.apk.
- udisk:
- sdcard:
Switch Mipi Panel
Panel Rotation
diff --git a/device/bananapi/bananapi_m2s/bananapi_m2s.mk b/device/bananapi/bananapi_m2s/bananapi_m2s.mk index 1f51703..d592a44 100644 --- a/device/bananapi/bananapi_m2s/bananapi_m2s.mk +++ b/device/bananapi/bananapi_m2s/bananapi_m2s.mk @@ -579,6 +579,6 @@ PRODUCT_PROPERTY_OVERRIDES += \ else PRODUCT_PROPERTY_OVERRIDES += \ ro.sf.lcd_density=213 \ - ro.sf.primary_display_orientation=0 + ro.sf.primary_display_orientation=90 endif
diff --git a/common/arch/arm64/boot/dts/amlogic/bananapi_m2s.dts b/common/arch/arm64/boot/dts/amlogic/bananapi_m2s.dts index 4a698b0..3d41b63 100755 --- a/common/arch/arm64/boot/dts/amlogic/bananapi_m2s.dts +++ b/common/arch/arm64/boot/dts/amlogic/bananapi_m2s.dts @@ -876,8 +876,8 @@ reg = <0x5d>; reset-gpio = <&gpio GPIOA_6 GPIO_ACTIVE_HIGH>; irq-gpio = <&gpio GPIOA_5 GPIO_ACTIVE_HIGH>; - rotation = <4>; /* sf_rotation 0 */ - //rotation = <0>; /* sf_rotation 90*/ + //rotation = <4>; /* sf_rotation 0 */ + rotation = <0>; /* sf_rotation 90*/ //rotation = <5>; /* sf_rotation 180 */ //rotation = <3>; /* sf_rotation 270 */
Custom Android Boot Logo
- 4. Extract this tool
- 8. The wiki guide is only for bananapi 4.9 bsp ubuntu/debian images.
$ sudo balena local flash path/to/xxx-bpi-m2s-xxx.img.zip $ sudo balena local flash path/to/xxx-bpi-m2s-xxx.img.zip --drive /dev/disk2 $ sudo balena local flash path/to/xxx-bpi-m2s-xxx.img.zip --drive /dev/disk2 --yes
$ sudo apt-get install pv unzip $ sudo unzip -p xxx-bpi-m2s-xxx.img.zip | pv | dd of=/dev/sdX bs=10M status=noxfer
$ sudo apt-get install pv unzip $ sudo bpi-copy xxx-bpi-m2s-xxx.img.zip /dev/sdX
$ sudo apt-get install pv unzip $ sudo unzip -p xxx-bpi-m2s-xxx.img.zip | pv | dd of=/dev/mmcblk0 bs=10M status=noxfer
$ sudo apt-get install pv unzip $ sudo bpi-copy xxx-bpi-m2s-xxx.img.zip /dev/mmcblk0
root@bananapi:~# ls /boot/overlays/ custom_ir.dtbo pwm_b-backlight.dtbo spi0.dtbo ds3231.dtbo pwm_c-beeper.dtbo uart1_cts_rts.dtbo hifi_pcm5102a.dtbo pwm_cd-c.dtbo uart1.dtbo hifi_pcm5122.dtbo pwm_cd.dtbo uart2.dtbo i2c1.dtbo pwm_ef.dtbo waveshare_tft24_lcd.dtbo i2c2.dtbo pwm_ef-f.dtbo waveshare_tft35c_lcd.dtbo pwm_ab.dtbo sdio.dtbo waveshare_tft35c_rtp.dtbo
Enable Camera
overlays="os08a10"
Switch Mipi Panel
Panel Rotation
Section "Device" Identifier "Configured Video Device" # Rotate off # Option "Rotate" "off" # Rotate Right / clockwise, 90 degrees Option "Rotate" "CW" # Rotate upside down, 180 degrees # Option "Rotate" "UD" # Rotate counter clockwise, 270 degrees # Option "Rotate" "CCW" EndSection Section "InputClass" Identifier "Coordinate Transformation Matrix" MatchIsTouchscreen "on" MatchProduct "goodix-ts" MatchDevicePath "/dev/input/event0" MatchDriver "libinput" # Rotate Right / clockwise, 90 degrees Option "CalibrationMatrix" "0 1 0 -1 0 1 0 0 1" # Rotate upside down, 180 degrees # Option "CalibrationMatrix" "-1 0 1 0 -1 1 0 0 1" # otate counter clockwise, 270 degrees # Option "CalibrationMatrix" "0 -1 1 1 0 0 0 0 1" EndSection
$ sudo apt-get update $ sudo apt-get install build-essential git $ git clone https://github.com/Dangku/WiringPi $ cd WiringPi $ chmod a+x build $ sudo ./build
- 3. BPI GPIO Extend board and examples in WiringPi/examples
- oled, BPI LCD 1602 display module example.
- 52pi, BPI OLED Display Module example.
- matrixled, BPI RGB LED Matrix Expansion Module example.
- berryclip, BPI BerryClip Module
$ sudo apt-get update $ sudo apt-get install build-essential python3 python3-pip python3-dev python3-setuptools git $ git clone https://github.com/Dangku/RPi.GPIO-Amlogic.git $ cd RPi.GPIO-Amlogic $ sudo python3 setup.py clean --all $ sudo python3 setup.py install
WiringPi2-Python
$ sudo apt-get update $ sudo apt-get install build-essential python3 python3-dev python3-setuptools swig git $ git clone --recursive https://github.com/Dangku/WiringPi2-Python-Amlogic.git $ cd WiringPi2-Python-Amlogic $ sudo python3 setup.py install
Luma.Examples
- build bananapi m2s RPi.GPIO with python3 instead of python because luma uses python3.
$ sudo apt-get update $ sudo apt-get install build-essential python3 python3-dev python3-setuptools git $ git clone https://github.com/Dangku/RPi.GPIO-Amlogic.git $ cd RPi.GPIO-Amlogic $ sudo python3 setup.py clean --all $ sudo python3 setup.py install
$ sudo python3 test/led.py
$ sudo groupadd --system xxx
$ sudo -H pip install -e .
- or
$ sudo -H pip3 install -e .
- 3. examples test
HDMI LCD
Bananapi M2S Tested HDMI LCD panel /boot/env.txt Waveshare 3.5inch 480x320 hdmi_autodetect=no hdmi=480x320p60hz
Waveshare 3.5inch 640x480 Waveshare 4inch 720x720 Waveshare 5inch 800x480 Waveshare 5.5inch 1440x2560 hdmi_autodetect=no hdmi=1440x2560p60hz
Waveshare 7inch 800x480 Waveshare 7inch 1024x600 Waveshare 7.9inch 400x1280 Waveshare 8inch 1536x2048 hdmi_autodetect=no hdmi=1536x2048p60hz
Waveshare 8.8inch 480x1920 Waveshare 9inch 2560x1600 hdmi_autodetect=no hdmi=2560x1600p60hz
Waveshare 10.1inch 1024x600 Waveshare 10.1inch 1280x800 Waveshare 11.9inch 320x1480 Waveshare 13.3inch 1920x1080 Waveshare 15.6inch 1920x1080
- backlight control
Boot Sequence
Wifi/BT support
- 2. Linux test and support.
- How to enable Linux Wifi
- SDIO/UART type:
overlays="wifi_bt_rtl8822cs"
Cloud-init&Snap
- or
$ sudo apt purge cloud-init
- 2. disable or remove snap
$ sudo apt purge snapd
Enable rc-local
- Create /etc/rc.local file.
sudo nano /etc/rc.local
$ sudo chmod +x /etc/rc.local
Enable sudo for Debian
Install Docker Engine
- 1. Set up the repository
$ echo \ "deb [arch=arm64 signed-by=/usr/share/keyrings/docker-archive-keyring.gpg] https://download.docker.com/linux/ubuntu \ $(lsb_release -cs) stable" | sudo tee /etc/apt/sources.list.d/docker.list > /dev/null
- 2. Install Docker Engine
$ sudo docker run hello-world
