Banana Pi BPI-M4 Berry
Revision as of 08:09, 7 June 2024 by Squy (talk | contribs) (Resources)
BPI-M4 Berry development board stands as a powerful Single Board Computer (SBC), harnessing the capabilities of the Allwinner H618 System-on-Chip (SoC) to provide developers with impressive performance and a wealth of features. Similar to the Raspberry Pi 4b, the BPI-M4 Berry boasts comparable CPU prowess, 2G LPDDR4 memory and 8G eMMC, integrated WiFi and Bluetooth functionalities, and a familiar 40-pin header layout, alongside 4 USB interfaces and a GbE RJ45 port.
Characterized by its robust performance, versatile features, and remarkable image processing capabilities, stands as an exemplary SBC development platform for professionals within the embedded and computing industries. Equipped with 8GB eMMC flash storage, high-performance decoding and encoding capabilities, and an array of interface options, it caters to a wide spectrum of application domains, including media processing, IoT, and entertainment. Whether catering to novices or seasoned developers, the BPI-M4 Berry development board offers an ideal toolset for realizing creative visions and project objectives.
  • ARM Mali G31 GPU
  • WIFI & Bluetooth
  • 2G LPDDR4 RAM
  • 8G eMMC flash memory
  • 4x USB2.0 Type-A
  • 1x HDMI 2.0a
  • 1x 3.5mm Audio & TVE jack socket
  • 1x GbE Ethernet port
Hardware Specification of Banana pi BPI-M4 Berry
GPU ARM Mali G31 GPU
Memory 2 GB LPDDR4
Storage 8G eMMC flash
SD card MicroSD card slot
Ethernet 1x GbE Ethernet port(supports PoE with add-on PoE HAT)
HDMI 1x full-size HDMI 2.0a (up to 4K@60Hz with HDR10, CEC, DDC, SCDC), HDMI digital Audio output
Audio 1x 3.5mm Audio & TVE jack socket
IR 1x CIR
USB 4x USB2.0 Type-A HOST, 1x USB2.0 Type-C OTG
40-pin header 28 pins GPIO and Power (+5V, +3.3V and GND)
Buttons Reset, FEL and User
Power 5V@3A via USB Type-C
Size 85x56 mm
Weight 60g
module Raspberry Pi 4B Banana Pi BPI-M4 Berry
CPU 1.5GHz Quad-Core BroadcomBCM2711(Cortex A72) H618,64 Bit Cortex™-A53 Quad-Core
GPU 500 MHz VideoCore Vl ARM Mali G31 GPU
Memory 1-4GB DDR4 2GB LPDDR4(up to 4G)
Onboard Storage MicroSD (TF) card MicroSD (TF) card / MMC card slot ,eMMC 8GB
Network 10/100/1000 Ethernet 10/100/1000 Ethernet
Onboard WIFI &BT IEEE 802.11a/b/g/n/ac & BT5.0 IEEE 802.11a/b/g/n/ac & BT4.2
Display HDMI HDMI
Camera CSI N/A
Video Outputs 2*Micro-HDMI HDMI 2.0a 4K@60fps
Audio Output 3.5 mm Jack and HDM 3.5 mm Jack and HDMI
Audio In N/A N/A
GPIO 40-PIN: PWM,GPIO,UART,I²C bus,I²S bus,SPI bus,+3.3v,+5v,ground. CAN bus 40-PIN: PWM,GPIO,UART,I²C bus,I²S bus,SPI bus,+3.3v,+5v,ground. CAN bus
Remote N/A IR reciever
USB Ports 2*USB3.0+2USB2.0 2 * USB 2.0 1* USB Otg
Buttons N/A Reset button, User button, Uboot button
LED Power led Status led Power led Status led Wifi led
Power DC 5V/3A DC 5V/2A
Board Size 88mmx58mm 88mmx58mm
PIN define
BPI-M4 Berry 40-pin header
1 3.3V
2 5V
3 PG16 UART2_RX TWI4_SDA
4 5V
5 PG15 UART2_TX TWI4_SCK
6 GND
7 PG19 PWM1
8 PG6 UART1_TX
9 GND
10 PG7 UART1_RX
11 PH2 UART5_TX PWM2
12 PG11 H_I2S2_BCLK
13 PH3 UART5_RX PWM1
14 GND
15 PG2
16 PG8 UART1_RTS
17 3.3V
18 PG9 UART1_CTS
20 GND
22 PG1
25 GND
27 PG18 UART2_CTS TWI3_SDA
28 PG17 UART2_RTS TWI3_SCK
29 PG3
30 GND
31 PG4
32 PG0
33 PG5
34 GND
35 PG12 H_I2S2_LRCK
36 PH4
37 PG10 H_I2S2_MCLK
39 GND
BPI-M4 Berry Debug UART
1 GND
2 UART0_RX
3 UART0_TX
Baidu Cloud: https://pan.baidu.com/s/1yMlLXauxZywujH8WkYqEcQ?pwd=8888 (pincode:8888)
Google Drive: https://drive.google.com/drive/folders/1qQxQik4GJjOF1aEOs9a1YVFxJBPlyFnc?usp=sharing
  • BPI-M4 Berry Schematic diagram
Baidu cloud: https://pan.baidu.com/s/18jV5XOVoECraDpSWlYd1iA?pwd=8888 (pincode: 8888)
Google drive: https://drive.google.com/file/d/1KAFmQuvXMsLBnQDVcm-svhN356vxdrFn/view?usp=sharing
  • BPI-M4 Berry DXF file
Baidu cloud: https://pan.baidu.com/s/1lgmPfwqR-B9Pg7ET7NavKw?pwd=8888 (pincode: 8888)
Google drive: https://drive.google.com/file/d/1pQELD4uTexkHbvar-ArksAJ9TPj86HA1/view?usp=sharing
  • Allwinner H618 Datasheet
  • BPI-M4Berry-Android_20240429
Baidu cloud: https://pan.baidu.com/s/1SFwaz199hXgBsCcI0D1hlg?pwd=8888 (pincode:8888)
Google drive: https://drive.google.com/drive/folders/1kPdWuO5VBhvr-XIohHAqTDrk6mk8W1Z-?usp=sharing
  • 2024-01-14-bananapi-m4berry-android12-box.img
Baidu Cloud: https://pan.baidu.com/s/1TxHK3re-n83OqxyRN063_g?pwd=8888 (pincode:8888)
Google Drive: https://drive.google.com/drive/folders/1HbhgXqBajDsA8esbMLRzHbddpAFOV-lS?usp=sharing
  • 2024-01-14-bananapi-m4berry-android12.img
Baidu Cloud: https://pan.baidu.com/s/1htyoCTGtCGgKfGUwL3OuHQ?pwd=8888 (pincode:8888)
Google Drive: https://drive.google.com/drive/folders/1CQh4ZHjA1Na7jvAk2y1AEP8r8p0HIwx1?usp=sharing
  • 20240327_Bpi-m4berry_1.0.2_debian11_bullseye_desktop_xfce_linux6.1.31
Baidu Cloud: https://pan.baidu.com/s/1DFuklrdgB1FfK0feh2Iskw?pwd=8888 (pincode:8888)
Google Drive: https://drive.google.com/file/d/1fwksjD8w17oZRsxIqjAXHUMviL9DkFNP/view?usp=sharing
  • 20240327_Bpi-m4berry_1.0.2_debian11_bullseye_minimal_linux6.1.31
Baidu Cloud: https://pan.baidu.com/s/1fMurMeF5NoEnnThORMX4Hw?pwd=8888 (pincode:8888)
Google Drive: https://drive.google.com/file/d/1KofzlzsEjG2IwwoYRs6DN9bbkCNXW2OQ/view?usp=sharing
  • 20240327_Bpi-m4berry_1.0.2_debian12_bookworm_desktop_xfce_linux6.1.31
Baidu Cloud: https://pan.baidu.com/s/1bZPgpFcurgYOjTIw1OExhQ?pwd=8888 (pincode:8888)
Google Drive: https://drive.google.com/file/d/1e27dd0WLRbZhiUfXnxlAW22FRuhJS8cm/view?usp=sharing
  • 20240327_Bpi-m4berry_1.0.2_debian12_bookworm_minimal_linux6.1.31
Baidu Cloud: https://pan.baidu.com/s/1cR0s1kODTi3jOxylb2aDQQ?pwd=8888 (pincode:8888)
Google Drive: https://drive.google.com/file/d/1kp-HkS6R3twpPtfyiMhIVyb_oSIkNmxK/view?usp=sharing
  • 20240327_Bpi-m4berry_1.0.2_ubuntu22.04_jammy_desktop_xfce_linux6.1.31
Baidu Cloud: https://pan.baidu.com/s/17FQ0ypGUIGRsGwFlFpCvbg?pwd=8888 (pincode:8888)
Google Drive: https://drive.google.com/file/d/15IpXunBV0hqCG39_Op2dqybEa6IajjBn/view?usp=sharing
  • 20240327_Bpi-m4berry_1.0.2_ubuntu22.04_jammy_minimal_linux6.1.31
Baidu Cloud: https://pan.baidu.com/s/1xQn02wms3YP159N6keejoQ?pwd=8888 (pincode:8888)
Google Drive: https://drive.google.com/file/d/1iwMHm0oaat-3Jme82qQFHhk_DZzh7By2/view?usp=sharing
  • Aliexpress shop:
SINOVOIP Aliexpress shop: https://www.aliexpress.us/item/1005006212355480.html?spm
Bipai Aliexpress shop: https://www.aliexpress.us/item/1005006212128000.html?gatewayAdapt=glo2usa
Taobao Shop: https://item.taobao.com/item.htm?spm=a1z10.5-c-s.w4002-25059194413.11.489155c8Addsck&id=747425760994
