Banana Pi BPI-M1
It is the first open source hardware launched by the banana pie team, and also a classic product with the largest cumulative sales of banana pie.There are still a lot of business clients that apply to various projects.A20 chip
- 1 GB DDR3 memory.
- 1x SATA interface.
- 1x Gigabit LAN
- 1x USB otg and 2x USB 2.0
- 1X MIC
- AV vide out
- HDMI out
- IR
- CSI camera interface
- DSI display interface
- 26 PIN gpio
| Banana Pi BPI-M1 | |||
| CPU | A20 ARM Cortex -A7 Dual-Core | ||
| GPU | ARM Mali 400 MP2; Complies with OpenGL ES 2.0/1.1 | ||
| Memory | 1GB DDR3 | ||
| Network | 10/100/1000 Ethernet 8P8C (1000BASE-T) | ||
| Video Input | A CSI input connector allows for the connection of a designed camera module | ||
| Video Outputs | HDMI, CVBS, LVDS/RGB | ||
| Audio Outputs | 3.5mm jack and HDMI | ||
| Power Source | 5 volts DC via Micro USB or GPIO | ||
| USB 2.0 ports | 2 (direct from Allwinner A20 chip) | ||
| GPIO | GPIO, UART, I2C BUS, SPI BUS, WITH TWO CHIP SELECTS, CAN bus, ADC, PWM, +3.3V, +5V, GND | ||
| LED | Power Key & 8P8C | ||
| Storage | SATA 2.0, | ||
Banana Pi BPI-M1 has a 26-pin GPIO header . Following is the Banana Pi GPIO Pinout:
| 40 PIN GPIO of Banana pi BPI-M1 | |||
| CSI GPIO Pin | Pin Name | GPIO | |
| CON1 P01 | LINEINL | ||
| CON1 P02 | LINEINR | ||
| CON1 P03 | VCC-CSI | ||
| CON1 P04 | ADC\_X1 | ||
| CON1 P05 | GND | ||
| CON1 P06 | ADC\_X2 | ||
| CON1 P07 | FMINL | ||
| CON1 P08 | ADC\_Y1 | ||
| CON1 P09 | FMINR | ||
| CON1 P10 | ADC\_Y2 | ||
| CON1 P11 | GND | ||
| CON1 P12 | CSI-FLASH | PH17 | |
| CON1 P13 | LRADC0 | ||
| CON1 P14 | TWI1-SDA | PB19 | |
| CON1 P15 | LRADC1 | ||
| CON1 P16 | TWI1-SCK | PB18 | |
| CON1 P17 | CSI-D0 | PE4 | |
| CON1 P18 | CSI0-STBY-EN | PH19 | |
| CON1 P19 | CSI0-D1 | PE5 | |
| CON1 P20 | CSI-PCLK | PE0 | |
| CON1 P21 | CSI-D2 | PE6 | |
| CON1 P22 | CSI0-PWR-EN | PH16 | |
| CON1 P23 | CSI-D3 | PE7 | |
| CON1 P24 | CSI0-MCLK | PE1 | |
| CON1 P25 | CSI-D4 | PE8 | |
| CON1 P26 | CSI0-RESET\# | PH14 | |
| CON1 P27 | CSI-D5 | PE9 | |
| CON1 P28 | CSI-VSYNC | PE3 | |
| CON1 P29 | CSI-D6 | PE10 | |
| CON1 P30 | CSI-HSYNC | PE2 | |
| CON1 P31 | CSI-D7 | PE11 | |
| CON1 P32 | CSI1-STBY-EN | PH18 | |
| CON1 P33 | RESET\# | ||
| CON1 P34 | CSI1-RESET\# | PH13 | |
| CON1 P35 | CSI-IO0 | PH11 | |
| CON1 P36 | HPR | ||
| CON1 P37 | HPL | ||
| CON1 P38 | IPSOUT | ||
| CON1 P39 | GND | ||
| CON1 P40 | IPSOUT | ||
| LVDS GPIO of Banana pi BPI-M1 | |||
| LVDS Pin | Pin Name | Multiplex Function Select | GPIO |
| Multi 1 | Multi 2 | ||
| CON2 P01 | IPSOUT\(5V output\) | ||
| CON2 P02 | TWI3-SDA | PI1 | |
| CON2 P03 | IPSOUT\(5V output\) | ||
| CON2 P04 | TWI3-SCK | PI0 | |
| CON2 P05 | GND | ||
| CON2 P06 | LCD0-IO0 | PH7 | |
| CON2 P07 | LCDIO-03 | PH12 | |
| CON2 P08 | LCD0-IO1 | PH8 | |
| CON2 P09 | LCD0-D0 | LVDS0-VP0 | PD0 |
| CON2 P10 | PWM0 | PB2 | |
| CON2 P11 | LCD0-D1 | LVDS0-VN0 | PD1 |
| CON2 P12 | LCD0-IO2 | PH9 | |
| CON2 P13 | LCD0-D2 | LVDS0-VP1 | PD2 |
| CON2 P14 | LCD0-DE | PD25 | |
| CON2 P15 | LCD0-D3 | LVDS0-VN1 | PD3 |
| CON2 P16 | LCD0-VSYNC | ||
| CON2 P17 | LCD0-D4 | LVDS0-VP2 | PD4 |
| CON2 P18 | LCD0-HSYNC | ||
| CON2 P19 | LCD0-D5 | LVDS0-VN2 | PD5 |
| CON2 P20 | LCD0-CS | ||
| CON2 P21 | LCD0-D6 | LVDS0-VPC | PD6 |
| CON2 P22 | LCD0-CLK | PD24 | |
| CON2 P23 | LCD0-D7 | LVDS0-VNC | PD7 |
| CON2 P24 | GND | ||
| CON2 P25 | LCD0-D8 | LVDS0-VP3 | PD8 |
| CON2 P26 | LCD0-D23 | PD23 | |
| CON2 P27 | LCD0-D9 | LVDS0-VN3 | PD9 |
| CON2 P28 | LCD0-D22 | PD22 | |
| CON2 P29 | LCD0-D10 | PD10 | |
| CON2 P30 | LCD0-D21 | PD21 | |
| CON2 P31 | LCD0-D11 | PD11 | |
| CON2 P32 | LCD0-D20 | PD20 | |
| CON2 P33 | LCD0-D12 | PD12 | |
| CON2 P34 | LCD0-D19 | PD19 | |
| CON2 P35 | LCD0-D13 | PD13 | |
| CON2 P36 | LCD0-D18 | PD18 | |
| CON2 P37 | LCD0-D14 | PD14 | |
| CON2 P38 | LCD0-D17 | PD17 | |
| CON2 P39 | LCD0-D15 | PD15 | |
| CON2 P40 | LCD0-D16 | PD16 | |
| Jumper J11 of Banana pi BPI-M1 | |||
| J11 Pin | Pin Name | Multiplex Function Select | GPIO |
| J11 Pin1 | TXD | UART0-TX | PB22 |
| J11 Pin2 | RXD | UART0-RX | PB23 |
| Jumper J12 of Banana pi BPI-M1 | |||
| J12 Pin | Pin Name | Multiplex Function Select | GPIO |
| J12 Pin1 | 5V | ||
| J12 Pin2 | 3.3V | ||
| J12 Pin3 | NC | IO-7 | PH5 |
| J12 Pin4 | RXD | UART7\_RX | PI21 |
| J12 Pin5 | NC | IO-8 | PH3 |
| J12 Pin6 | TXD | UART7\_TX | PI20 |
| J12 Pin7 | GND | ||
| J12 Pin8 | GND | ||
All GPIO define list:
- Linux kernel 3.4 Source code : https://github.com/BPI-SINOVOIP/BPI-M1-bsp
- Android 4.4 source code
- Android 4.2.2 source code
- BPI-M1 Gerber/Boom/Assembly document:
- Baidu cloud: https://pan.baidu.com/s/1bM8NR12Wp_dtp-m52nuKrA?pwd=8888 (pincode:8888)
- Google drive: https://drive.google.com/file/d/1Zx-1LHhGKJ8l-qakd4pVvTuBXsQYIgV8/view?usp=sharing
- schematic diagram:https://drive.google.com/drive/folders/0B4PAo2nW2KfnflVqbjJGTFlFTTd1b1o1OUxDNk5ackVDM0RNUjBpZ0FQU19SbDk1MngzZWM?resourcekey=0-ZRCiv304nGzvq-w7lwnpjg&usp=sharing
- Allwinner documents:
Android 4.4
- 2018-07-28 update android 4.4 LCD version image
- Features Map:http://wiki.banana-pi.org/M1_Image_Map
- Baidu Drive:https://pan.baidu.com/s/1DfSIiMvW_I-kFjTZMtcVsA
- Google Drive: https://drive.google.com/open?id=1qcH9baIhOphsDdlH_yBADuBiZsvrSKnt
- Forum pthtread :http://forum.banana-pi.org/t/bananapi-m1-m1p-r1-new-image-release-20180728/6357
- Release Date: 2018-07-26
- Baidu Drive: https://pan.baidu.com/s/1HErsANQ4PsnwQJ-tH0AdTg
- Google Drive:
Ubuntu Linux
- 2022-09-07 Armbian_22.11.0-trunk_Bananapi_jammy_edge_5.19.6_xfce_desktop.img
- Google Drive: https://drive.google.com/file/d/1WtPL8Hfr9aaE3VRnpgR_R7VYsc7O3Y9P/view?usp=sharing
- Baidu Cloud: https://pan.baidu.com/s/1fM-in68EK_ABvSJ7XiY0Ag?pwd=yft7 (pincode: yft7)
- 2018-7-28 update :Ubuntu Server16.04 HDMI Version Image Link:
- Baidu Drive: https://pan.baidu.com/s/1GYH8oDK3T_WcUFn-0t9YmQ
- Google Drive: https://drive.google.com/open?id=13XTvWe90yvRdqNWiKCLZ0HcMgo33y2r6
- Baidu Drive: https://pan.baidu.com/s/1Tw_99XBZVOmKyavNxCXv3w
- Google Drive:
Debian Linux
- 2022-09-07 Armbian_22.11.0-trunk_Bananapi_BPI-M1_bullseye_edge_5.19.6_xfce_desktop.img
- Google Drive:https://drive.google.com/file/d/1px0h0se8EiRuBiGGxT40hWpU3RWzPedK/view?usp=sharing
- Baidu Cloud: https://pan.baidu.com/s/1Vclux6Wb-ToJGOaGQxV6Hg?pwd=m4a3 (pincode: m4a3)
- 2019-9-18 update. Debian 10 buster mate desktop with grub support (boot-2019.07 + kernel 5.1.1)
Armbian image
- 2023-07 Armbian_23.02.0_Banana Pi BPI-M1
- Baidu Cloud: https://pan.baidu.com/s/1pPh0vomR3MZozm2iLqBAmA?pwd=8888 (pincode:8888)
- Google Drive:https://drive.google.com/drive/folders/1ig3DOF5V9MQ38Zlvx_1zoPh_-KNzLKKx?usp=sharing
- 2023-07 Armbian_23.08.0_Banana Pi BPI-M1
- Baidu Cloud: https://pan.baidu.com/s/1L3ZTQt_JOWRrAcA7bZakmA?pwd=8888 (pincode:8888)
- Google Drive: https://drive.google.com/drive/folders/1erfCb_sPspu3ilHW8yv4ooM66hJF7KLb?usp=sharing
- Armbian_23.02.0-trunk_Bananapi_jammy_current_5.15.93.img.xz
- Armbian_23.02.0-trunk_Bananapi_jammy_edge_6.1.11.img.xz
- Baidu Cloud: https://pan.baidu.com/s/1hkkl22uVjvRct1V7N4OK2w?pwd=8888
- Google Drive: https://drive.google.com/drive/folders/1VpvVkYMqgmSnmfKXQSrEY2B6wRa-cggL?usp=share_link
- Discuss on forum: https://forum.banana-pi.org/t/banana-pi-bpi-m1-new-armbian-image/15157
- 2022-12-06 Armbian_22.11.0-trunk_Bananapi BPI-M1_bullseye_edge_6.0.9.img.xz
- Google Drive:https://drive.google.com/file/d/1ZSFOd-nVFbAn_xB9AXckx9SEKQvnMB2J/view?usp=share_link
- Baidu Cloud:https://pan.baidu.com/s/12R8mIf7_45HDtruqEvktBw?pwd=8888 (pincode: 8888)
Official OpenWRT
BPI BSP for OpenWRT
FreeBSD
OpenSuse
OpenMediaVault
Arch Linux
Gentoo Linux
- Gentoo Linux have officeal support banana pi BPI-M1, so you also can use on BPI-M1+,and BPI-R1, all is base on allwinner A20 chip.
- gentoo linux wiki : https://wiki.gentoo.org/wiki/Banana_Pi_the_Gentoo_Way
RaspBSD
CentOS
DietPi
FreeBSD/NetBSD
Lakka TV
- Banana Pi M2+ with H3 chip
- Banana Pi M3 with A83T chip
Simplenas
- SINOVOIP Aliexpress Shop: https://www.aliexpress.com/store/group/BPI-M1/1100417230_40000003426518.html
- Bipai Aliexpress Shop: https://www.aliexpress.com/store/group/BPI-M1/1101951077_40000003418620.html
- Taobao Shop: https://shop108780008.taobao.com/category-1694930629.htm
