Banana Pi BPI-R3 Mini
Revision as of 02:47, 3 January 2024 by Sinovoip (talk | contribs) (Case design)
Banana Pi BPI-R3 Metal case
The MT7986A(Filogic 830) integrates four Arm Cortex-A53 cores up to 2GHz with up to 18,000 DMIPs of processing power and 6Gbps of dual 4x4 Wi-Fi6 connectivity. It has two 2.5g Ethernet interfaces and serial peripheral interfaces (SPI). Filogic 830‘s built-in hardware acceleration engine enables fast and reliable Wi-Fi offloading and wireless network connection. In addition, the chip supports Mediatek FastPath™ technology, which is suitable for games, AR/VR and other low-latency applications.
Application direction
  • Internet service Router
  • Wireless Router
  • Wireless Repeater
  • Home security Gateway
  • Home Automation
  • Nas device
  • Soft router
  • Network and communication applications
  • MediaTek MT7986A(Filogic 830) Quad core ARM Cortex A53
  • Wifi 6 2.4G/5G(MT7976C)
  • 2G DDR RAM
  • 8G eMMC flash
  • 128MB Nand flash
  • 2x 2.5GbE network port
  • 1x M.2 Key B USB interface
  • 1x M.2 KEY M PCIe interface
  • 1x USB2.0 interface
HardWare Specification of Banana pi BPI-R3 Mini
CPU MediaTek MT7986A(Filogic 830) Quad-core ARM Cortex-A53
SDRAM 2 GB DDR4
On board Storage 128MB SPI NandFlash,8GB eMMC
On board Network 2x 2.5GbE Ethernet
Wifi Wifi6 2x2 2.4G + 3x3 5G(MT7976C)
M.2 Key B 1x M.2 Key B interface
M.2 Key M 1x M.2 KEY-M PCIe inerface
USB 1x USB 2.0
Buttons Reset button, boot switch
5x Leds Power ,System, Wifi 2G ,Wifi 5G ,4G Lte ,SSD
DC Power 20W/12V,USB TypeC PD
Sizes 65x65mm
Weight 100g
SSD and 5G support
  • Opensource Driver BSP
https://github.com/BPI-SINOVOIP/BPI-R3MINI-OPENWRT-V21.02.3
  • BPI-R3 Mini DXF file
Google Drive: https://drive.google.com/file/d/1FgNVjR-kPdFVNZBPkAF8xTIZ4YauJ_2O/view?usp=sharing
Baidu Cloud: https://pan.baidu.com/s/1t1hZjNdg7rMBJcqVEZN-Ag?pwd=8888 (pincode:8888)
  • BPI-R3 Mini schematic diagram
Google Drive:https://drive.google.com/file/d/1wvovcYf0OtvQl5fekJku25QNeER1D7cM/view?usp=sharing
Baidu Cloud: https://pan.baidu.com/s/1HohHjd2w-mqLlBhwsXR87A?pwd=8888 (pincode:8888)
Release image
  • bl2_emmc.img
Google Drive:https://drive.google.com/file/d/1L5lVyg8dDl60eyzkqBr-8aeG2Weq5ouo/view?usp=sharing
Baidu Cloud:https://pan.baidu.com/s/1vdnCKqr0GSzQid7Y3ADCKw?pwd=8888 (pincode:8888)
  • 2023-11-15 BPI-R3 Mini OpenWRT image with Opensource MAC80211 wifi Driver BSP (support Quectel RM500U-CN & RM520N-GL 5G Modules)
Google Drive: https://drive.google.com/drive/folders/1lENckxpiZa5bdkPAA6FfbGx1IlLJqHql?usp=sharing
Baidu Cloud: https://pan.baidu.com/s/1btkUMs84-Agj31WxRx8_Dg?pwd=8888 (pincode:8888)
  • 2023-11-15 BPI-R3 Mini OpenWRT image with MTK vendor wifi driver, Not OpenSource Driver BSP (support Quectel RM500U-CN & RM520N-GL 5G Modules)
Google Drive: https://drive.google.com/drive/folders/1RaKPSbQU94miUyawoyPq8RNUdubabKYq?usp=sharing
Baidu Cloud: https://pan.baidu.com/s/1yFp2P-pV4-b1_x6FjD8NBg?pwd=8888 (pincode:8888)
Accessories
Case design
5G module support
  • BPI-R3 mini can use Quectel RM500U-CN & RM520N-GL 5G Modules
