Getting Started with BPI-R4
Revision as of 07:52, 29 December 2023 by Sinovoip (talk | contribs) (→3. Storage)
   G=GND;  RX=BPI-R4 input;  TX=BPI-R4 output
  F0: 102B 0000
  FA: 5100 0000
  FA: 5100 0000 [0200]
  F9: 1041 0000
  F3: 1001 0000 [0200]
  F3: 1001 0000
  F6: 102C 0000
  F5: 1026 0000
  00: 1005 0000
  FA: 5100 0000
  F9: 1041 0000
  F3: 1001 0000
  F6: 102C 0000
  01: 102A 0001
  02: 1005 0000
  BP: 0200 00C0 [0001]
  EC: 0000 0000 [0000]
  MK: 0000 0000 [0000]
  T0: 0000 00D7 [0101]
  System halt!
 Release Image:  https://wiki.banana-pi.org/Banana_Pi_BPI-R4#Release_image
 Note: boot device select:  https://wiki.banana-pi.org/Getting_Started_with_BPI-R4#Prepare_to_develop
How to burn image to SD card
   * apt-get install pv
   Click on "Flash from file" to select image.
   Click on "Select target" to select USB device.
   Click on "Flash!" Start burning.
 * Note: boot device select:  https://wiki.banana-pi.org/Getting_Started_with_BPI-R4#Prepare_to_develop
    * mtd erase /dev/mtd0
 4. Execute :
Network-Configuration
root@OpenWrt:/# ifconfig
br-lan    Link encap:Ethernet  HWaddr EE:A1:57:81:CA:19
         collisions:0 txqueuelen:1000
br-wan    Link encap:Ethernet  HWaddr EE:A1:57:81:CA:19
eth0      Link encap:Ethernet  HWaddr EE:A1:57:81:CA:19
         Interrupt:124
eth1      Link encap:Ethernet  HWaddr 4A:BB:84:B4:5D:3F
         Interrupt:124
eth2      Link encap:Ethernet  HWaddr 22:02:CE:9C:92:BA
         Interrupt:124
lan0      Link encap:Ethernet  HWaddr EE:A1:57:81:CA:19
lan1      Link encap:Ethernet  HWaddr EE:A1:57:81:CA:19
lan2      Link encap:Ethernet  HWaddr EE:A1:57:81:CA:19
lan3      Link encap:Ethernet  HWaddr EE:A1:57:81:CA:19
lo        Link encap:Local Loopback
ra0       Link encap:Ethernet  HWaddr 00:0C:43:26:60:88
ra1       Link encap:Ethernet  HWaddr 02:0C:43:36:60:88
rai0      Link encap:Ethernet  HWaddr 00:0C:43:2B:B1:F8
rax0      Link encap:Ethernet  HWaddr 0C:0C:43:26:60:D8
bridge name     bridge id               STP enabled     interfaces
br-wan          7fff.eea15781ca19       no              lan0, eth2
br-lan          7fff.eea15781ca19       no              apclii0 apclix0 apcli0 ra1 rai0 rax0 lan2 eth1 ra0 lan3 lan1
root@OpenWrt:/#
Accessories
1. 10G SFP Module
10G SFP+ Copper Module
root@R4CN:/# [   67.870063] sfp sfp@0: SM: enter empty:up:down event insert
[   67.875642] sfp sfp@0: SM: exit probe:up:down
[   68.199179] sfp sfp@0: SM: enter probe:up:down event timeout
[   68.215970] sfp sfp@0: module OEM              SFP-10G-T        rev 10   sn 2309250003       dc 230925
[   68.225443] sfp sfp@0: module OEM              SFP-10G-T        rev 10   has been found in the quirk list
[   68.235004] sfp sfp@0: sfp: support mode 00,00000800,00007040
[   68.240749] sfp sfp@0: tx disable 1 -> 0
[   68.244681] sfp sfp@0: SM: exit present:up:wait
[   68.343638] sfp sfp@0: SM: enter present:up:wait event los_high
[   68.349549] sfp sfp@0: SM: exit present:up:wait
[   82.476711] sfp sfp@0: SM: enter present:up:wait event los_low
[   82.482550] sfp sfp@0: SM: exit present:up:wait
[   83.584504] alloc new entry for 18:f2:2c:6f:45:3e, interface:eth2
[   83.590595] recv intf mac ae:19:d1:7e:2a:74
[   95.271188] sfp sfp@0: SM: enter present:up:wait event timeout
[   95.277715] sfp sfp@0: probing phy device through the [MDIO_I2C_ROLLBALL] protocol
[   95.821247] sfp sfp@0: CL45 PHY device [0x31c3:0x1c13] found!
[   95.826999] sfp sfp@0: CL45 PHY device [0x31c3:0x1c13] found!
[   95.832741] sfp sfp@0: CL45 PHY device [0x31c3:0x1c13] found!
[   95.838479] sfp sfp@0: CL45 PHY device [0x31c3:0x1c13] found!
[   95.844217] sfp sfp@0: CL45 PHY driver [Aquantia AQR113C] found!
[   95.850215] sfp sfp@0: phy: support mode 00,00018000,000e706c
[   95.855960] mtk_soc_eth 15100000.ethernet eth2: requesting link mode inband/10gbase-kr with support 00,00018000,000a7068
[   96.273193] mtk_soc_eth 15100000.ethernet eth2: PHY [i2c:sfp@0:11] driver [Aquantia AQR113C]
[   96.357199] sfp sfp@0: SM: exit present:up:link_up
[   96.357206] mtk_soc_eth 15100000.ethernet eth2: resolve link status: system iface=1, line iface=0
[   96.630718] sfp sfp@0: SM: enter present:up:link_up event los_high
[   96.636904] sfp sfp@0: SM: exit present:up:wait_los
[  101.395228] sfp sfp@0: SM: enter present:up:wait_los event los_low
[  101.401416] sfp sfp@0: SM: exit present:up:link_up
[  101.401426] mtk_soc_eth 15100000.ethernet eth2: resolve link status: system iface=1, line iface=0
[  101.696172] mtk_soc_eth 15100000.ethernet eth2: Link is Up - 10Gbps/Full - flow control off
[  101.704534] br-wan: port 2(eth2) entered blocking state
[  101.709754] br-wan: port 2(eth2) entered forwarding state
 root@R4CN:/#
 root@R4CN:/# i2cdetect -y 3
    0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:                         -- -- -- -- -- -- -- --
70: UU -- -- -- -- -- -- --
root@R4CN:/#
root@R4CN:/# ethtool eth2
Settings for eth2:
       Supported ports: [ ]
       Supported link modes:   100baseT/Full
                               1000baseT/Full
                               10000baseT/Full
                               1000baseKX/Full
                               10000baseKR/Full
                               2500baseT/Full
                               5000baseT/Full
       Advertised link modes:  100baseT/Full
                               1000baseT/Full
                               10000baseT/Full
                               1000baseKX/Full
                               10000baseKR/Full
                               2500baseT/Full
                               5000baseT/Full
       Link partner advertised link modes:  10baseT/Full
                                            100baseT/Full
                                            1000baseT/Full
                                            10000baseT/Full
                                            2500baseT/Full
                                            5000baseT/Full
       Speed: 10000Mb/s
       Duplex: Full
       Port: MII
       PHYAD: 17
       Transceiver: external
       Auto-negotiation: on
       Link detected: yes
root@R4CN:/#
Note:
root@R4CN:/# [  201.763041] mapfilter:drop IP addr timeout! stop dropping IP addr.
[  499.938345] sfp sfp@0: SM: enter present:up:link_up event los_high
[  499.950712] mtk_soc_eth 15100000.ethernet eth2: Link is Down
[  499.956370] sfp sfp@0: SM: exit present:up:wait_los
[  499.961367] br-wan: port 2(eth2) entered disabled state
[  502.867442] sfp sfp@0: SM: enter present:up:wait_los event remove
[  502.873705] sfp sfp@0: module removed
[  502.877937] sfp sfp@0: tx disable 0 -> 1
[  502.881872] sfp sfp@0: SM: exit empty:up:down
[  503.164077] Unable to handle kernel NULL pointer dereference at virtual address 0000000000000180
[  503.172853] Mem abort info:
[  503.175634]   ESR = 0x96000006
[  503.178683]   EC = 0x25: DABT (current EL), IL = 32 bits
[  503.183985]   SET = 0, FnV = 0
[  503.187030]   EA = 0, S1PTW = 0
[  503.190162] Data abort info:
[  503.193035]   ISV = 0, ISS = 0x00000006
[  503.196861]   CM = 0, WnR = 0
[  503.199816] user pgtable: 4k pages, 39-bit VAs, pgdp=000000012fd21000
[  503.206246] [0000000000000180] pgd=0000000132bfb003, pud=0000000132bfb003, pmd=0000000000000000
[  503.214936] Internal error: Oops: 96000006 [#1] SMP
[  503.219799] Modules linked in: ksmbd mt7991(P) mt7990(P) iptable_nat ipt_REJECT xt_time xt_tcpudp xt_state xt_socket xt_recent xt_policy xt_nat xt_multiport xt_mark xt_mac xt_limit xt_iprange xt_helper xt_esp xt_conntrack xt_connmark xt_connlimit xt_connbytes xt_comment xt_TPROXY xt_TCPMSS xt_REDIRECT xt_MASQUERADE xt_LOG xt_FLOWOFFLOAD xt_CT usblp ts_fsm ts_bm spidev rfcomm pptp ppp_mppe nf_tproxy_ipv6 nf_tproxy_ipv4 nf_socket_ipv6 nf_socket_ipv4 nf_reject_ipv4 nf_nat_tftp nf_nat_snmp_basic nf_nat_sip nf_nat_pptp nf_nat_irc nf_nat_h323 nf_nat_amanda nf_nat nf_log_ipv4 nf_flow_table_hw nf_flow_table nf_conntrack_tftp nf_conntrack_snmp nf_conntrack_sip nf_conntrack_pptp nf_conntrack_netlink nf_conntrack_irc nf_conntrack_h323 nf_conntrack_broadcast ts_kmp nf_conntrack_amanda nf_conncount mtqos mtfwd mapfilter libcrc32c l2tp_ppp iptable_raw iptable_mangle iptable_filter ipt_ah ip_tables hidp btusb btintel bnep asn1_decoder mt7990_dbg(P) mtk_wed(P) mtk_pci(P) connac_if(P) mtk_hwifi(P)
[  503.219869]  mt_wifi(P) hid mt_wifi_cmn evdev input_core cfg80211 compat xt_set ip_set_list_set ip_set_hash_netportnet ip_set_hash_netport ip_set_hash_netnet ip_set_hash_netiface ip_set_hash_net ip_set_hash_mac ip_set_hash_ipportnet ip_set_hash_ipportip ip_set_hash_ipport ip_set_hash_ipmark ip_set_hash_ip ip_set_bitmap_port ip_set_bitmap_ipmac ip_set_bitmap_ip ip_set nfnetlink nf_log_ipv6 nf_log_common ip6table_mangle ip6table_filter ip6_tables ip6t_REJECT x_tables nf_reject_ipv6 nfsd ip6_gre ip_gre gre l2tp_netlink l2tp_core udp_tunnel ip6_udp_tunnel ipcomp6 xfrm6_tunnel esp6 ah6 ip6_tunnel tunnel6 ip_tunnel rpcsec_gss_krb5 auth_rpcgss oid_registry af_key lockd sunrpc grace autofs4 dm_mirror dm_region_hash dm_log dm_crypt nls_utf8 nls_iso8859_1 nls_cp437 macsec seqiv md4 ghash_generic gf128mul gcm cts ctr ccm arc4 mtk_warp mtkhnat leds_gpio xhci_plat_hcd ohci_platform ohci_hcd fsl_mph_dr_of ehci_platform ehci_fsl ehci_hcd gpio_button_hotplug
[  503.390068] CPU: 2 PID: 7304 Comm: aqr107_mib_thre Tainted: P                  5.4.246 #0
[  503.398227] Hardware name: Bananapi BPI-R4 (DT)
[  503.402746] pstate: 80000005 (Nzcv daif -PAN -UAO)
[  503.407531] pc : __phy_read_mmd+0x20/0xa0
[  503.411529] lr : phy_read_mmd+0x38/0x60
[  503.415351] sp : ffffffc01388bd90
[  503.418653] x29: ffffffc01388bd90 x28: 0000000000000000
[  503.423952] x27: ffffff80f2ae3638 x26: ffffffc010a373c0
[  503.429250] x25: ffffffc010557918 x24: ffffff80f4ce8800
[  503.434547] x23: ffffffc010d83908 x22: ffffffc01388be3c
[  503.439845] x21: 000000000000e811 x20: 0000000000000003
[  503.445142] x19: ffffff80f4ce8800 x18: ffffffc010c0a1a8
[  503.450440] x17: 000000000000003c x16: 000000000000003c
[  503.455738] x15: 0000000000000018 x14: 00000000fffbd1b0
[  503.461035] x13: 00000000000001f4 x12: ffffffc010c0a160
[  503.466332] x11: 000000000000c503 x10: 0000000000000830
[  503.471630] x9 : ffffffc01388bd10 x8 : ffffff80efda0890
[  503.476927] x7 : ffffffc0eec26000 x6 : ffffffc0eec26000
[  503.482224] x5 : 0000000000000000 x4 : 0000000000000000
[  503.487522] x3 : ffffff80f4ce8800 x2 : 000000000000e811
[  503.492819] x1 : 0000000000000003 x0 : ffffff80f4ce8800
[  503.498117] Call trace:
[  503.500553]  __phy_read_mmd+0x20/0xa0
[  503.504202]  phy_read_mmd+0x38/0x60
[  503.507680]  aqr107_mib_read_word+0x2c/0x60
[  503.511850]  aqr107_mib_read+0x24/0x200
[  503.515673]  aqr107_mib_thread+0x20/0x50
[  503.519585]  kthread+0x120/0x128
[  503.522801]  ret_from_fork+0x10/0x1c
[  503.526368] Code: a9be7bfd aa0003e3 910003fd f9418005 (f940c0a5)
[  503.532447] ---[ end trace 3fa317a53584315f ]---
[  503.538554] Kernel panic - not syncing: Fatal exception
[  503.543768] SMP: stopping secondary CPUs
[  503.547680] Kernel Offset: disabled
[  503.551155] CPU features: 0x10002,20002008
[  503.555238] Memory Limit: none
[  503.559792] Starting Memory dump SMCC
[  503.563452] Memory dump SMCC failed
[  503.566929] Rebooting in 3 seconds..
10G SFP+ Fibre Module
root@R4CN:/# [  455.370399] sfp sfp@1: SM: enter empty:up:down event insert
[  455.375999] sfp sfp@1: SM: exit probe:up:down
[  455.687021] sfp sfp@1: SM: enter probe:up:down event timeout
[  455.703815] sfp sfp@1: module OEM              SFP-10G-BX20-U   rev 1.0  sn 2309250008       dc 230925
[  455.713292] sfp sfp@1: sfp: support mode 00,00001000,00006040
[  455.719042] mtk_soc_eth 15100000.ethernet eth1: requesting link mode inband/10gbase-kr with support 00,00001000,00006440
[  455.740862] sfp sfp@1: tx disable 1 -> 0
[  455.744792] sfp sfp@1: SM: exit present:up:wait
[  455.799020] sfp sfp@1: SM: enter present:up:wait event timeout
[  455.804849] sfp sfp@1: probing phy device through the [MDIO_I2C_NONE] protocol
[  455.812066] sfp sfp@1: SM: exit present:up:link_up
[  455.833979] mtk_soc_eth 15100000.ethernet eth1: resolve link status: system iface=0
[  455.843477] sfp sfp@1: SM: enter present:up:link_up event los_high
[  455.849657] sfp sfp@1: SM: exit present:up:wait_los
[  476.904686] sfp sfp@1: SM: enter present:up:wait_los event los_low
[  476.910875] sfp sfp@1: SM: exit present:up:link_up
[  476.941863] mtk_soc_eth 15100000.ethernet eth1: Link is Up - 10Gbps/Full - flow control off
[  476.950225] br-lan: port 4(eth1) entered blocking state
[  476.955445] br-lan: port 4(eth1) entered forwarding state
[  477.784529] alloc new entry for 18:f2:2c:6f:45:3e, interface:eth1
[  477.790622] recv intf mac 76:38:02:df:74:7f
root@R4CN:/#
root@R4CN:/# i2cdetect -y 4
root@R4CN:/#
root@R4CN:/# ethtool eth1
Settings for eth1:
       Supported ports: [ FIBRE ]
       Supported link modes:   10000baseLR/Full
       Advertised link modes:  10000baseLR/Full
       Speed: 10000Mb/s
       Duplex: Full
       Port: FIBRE
       PHYAD: 0
       Transceiver: internal
       Link detected: yes
root@R4CN:/#
2. 4G/5G Module
2.1 M.2 4G/5G Module(USB Interface)
  • BPI-R4 supports M.2 USB Interface Quectel 4G LTE EM25, RM500U-CN & RM520N-GL 5G Modules.
  • If you want to use M.2 Cellular Module on BPI-R4:
   1. Install 4G/5G Cellular Module into CN16 Slot(M.2 KEYB)
   2. Inset NANOSIM Card into SIMSlot(SIM1) with card tray(pay attention to the direction)
   3. Install antenna on the module
   4. After powering on, it will automatically dial
Quectel RM520N-GL
wwan0     Link encap:Ethernet  HWaddr A6:35:F7:7A:9E:A7
         UP RUNNING NOARP  MTU:1500  Metric:1
         RX bytes:1272 (1.2 KiB)  TX bytes:1932 (1.8 KiB)
wwan0_1   Link encap:Ethernet  HWaddr A6:35:F7:7A:9E:A7
         inet addr:10.46.121.135  Mask:255.255.255.240
         RX bytes:1292 (1.2 KiB)  TX bytes:1932 (1.8 KiB)
root@R4CN:/#
root@R4CN:/# lsusb
Bus 002 Device 002: ID 2109:0822 VIA Labs, Inc.          USB3.1 Hub
Bus 001 Device 003: ID 2109:8822 VIA Labs, Inc.          USB Billboard Device
Bus 001 Device 002: ID 2109:2822 VIA Labs, Inc.          USB2.0 Hub
root@R4CN:/#
^C
root@R4CN:/#
RM500U-CN
usb0      Link encap:Ethernet  HWaddr 5E:3B:9C:76:7C:46
         inet addr:10.95.9.23  Bcast:10.95.9.255  Mask:255.255.255.0
         inet6 addr: fe80::5c3b:9cff:fe76:7c46/64 Scope:Link
         RX packets:34 errors:0 dropped:0 overruns:0 frame:0
         TX packets:62 errors:0 dropped:0 overruns:0 carrier:0
         RX bytes:7908 (7.7 KiB)  TX bytes:10100 (9.8 KiB)
root@R4CN:/#
root@R4CN:/# lsusb
Bus 002 Device 003: ID 2c7c:0900 Quectel RM500U-CN
root@R4CN:/#
PING www.baidu.com (2409:8c54:870:34e:0:ff:b024:1916): 56 data bytes
64 bytes from 2409:8c54:870:34e:0:ff:b024:1916: seq=0 ttl=51 time=55.105 ms
64 bytes from 2409:8c54:870:34e:0:ff:b024:1916: seq=1 ttl=51 time=38.725 ms
64 bytes from 2409:8c54:870:34e:0:ff:b024:1916: seq=2 ttl=51 time=39.890 ms
^C
3 packets transmitted, 3 packets received, 0% packet loss
round-trip min/avg/max = 38.725/44.573/55.105 ms
root@R4CN:/#
EM05-CE
wwan0     Link encap:Ethernet  HWaddr F2:CC:52:10:2E:27
         inet addr:10.21.103.116  Bcast:0.0.0.0  Mask:255.255.255.248
         inet6 addr: fe80::f0cc:52ff:fe10:2e27/64 Scope:Link
         UP BROADCAST RUNNING NOARP MULTICAST  MTU:1500  Metric:1
         TX packets:91 errors:0 dropped:0 overruns:0 carrier:0
         RX bytes:7868 (7.6 KiB)  TX bytes:10133 (9.8 KiB)
root@R4CN:/#
root@R4CN:/# lsusb
Bus 001 Device 012: ID 2c7c:0125 Quectel Incorporated LTE Module
root@R4CN:/#
PING www.baidu.com (120.232.145.144): 56 data bytes
64 bytes from 120.232.145.144: seq=0 ttl=53 time=47.085 ms
64 bytes from 120.232.145.144: seq=1 ttl=53 time=36.447 ms
^C
2 packets transmitted, 2 packets received, 0% packet loss
round-trip min/avg/max = 36.447/41.766/47.085 ms
root@R4CN:/#
2.2 M.2 4G/5G Module(PCIe Interface)
2.3 miniPCIe 4G/5G Module(USB Interface)
Storage
3.1 NVMe SSD
  • Please insert one M.2 KeyM SSD(PCIe interface) into KeyM slot(CN18).
 No compatibility testing has been done and there is no guarantee that all SSDs can be used.
root@R4CN:/# lspci
0002:00:00.0 PCI bridge: MEDIATEK Corp. Device 7988 (rev 01)
0002:01:00.0 Non-Volatile memory controller: KIOXIA Corporation Device 0001
0004:00:00.0 Unclassified device [0002]: MEDIATEK Corp. Device 7981
root@R4CN:/#
root@R4CN:/#
root@R4CN:/# cat /proc/partitions
major minor  #blocks  name
 31        0     131072 mtdblock0
259        0  125034840 nvme0n1
259        1  125033472 nvme0n1p1
 31        1       1024 mtdblock1
 31        2        512 mtdblock2
 31        3       4096 mtdblock3
 31        4       2048 mtdblock4
 31        5     115200 mtdblock5
179        0    7634944 mmcblk0
253        0      56172 ubiblock0_1
root@R4CN:/#
root@R4CN:/#
3.2 PCIe to SATA
BPI-R4 Also supports JMicron's JMB585 (PCIe to 5x SATA chip)
CN19 is a 2.54mm pitch socket(XH-4A) that can power SATA HDD (about 12V/2A, 5V/2A)
root@R4CN:/# lspci
0002:01:00.0 SATA controller: JMicron Technology Corp. JMB58x AHCI SATA controller
root@R4CN:/#
root@R4CN:/#
root@R4CN:/# [  743.794932] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[  743.802031] ata1.00: HPA detected: current 234439535, native 234441648
[  743.808746] ata1.00: ATA-8: Hitachi HTS542512K9SA00, BB2OC31P, max UDMA/133
[  743.815699] ata1.00: 234439535 sectors, multi 0: LBA48 NCQ (depth 32), AA
[  743.823749] ata1.00: configured for UDMA/133
[  743.828182] scsi 0:0:0:0: Direct-Access     ATA      Hitachi HTS54251 C31P PQ: 0 ANSI: 5
[  743.836710] sd 0:0:0:0: [sda] 234439535 512-byte logical blocks: (120 GB/112 GiB)
[  743.844204] sd 0:0:0:0: [sda] Write Protect is off
[  743.848992] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[  743.854075] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[  744.221268]  sda: sda1 sda2
[  744.224485] sd 0:0:0:0: [sda] Attached SCSI disk
[  744.459896] EXT4-fs (sda1): The kernel was not built with CONFIG_QUOTA and CONFIG_QFMT_V2
root@R4CN:/#
root@R4CN:/#
 31        1       1024 mtdblock1
 31        2        512 mtdblock2
 31        3       4096 mtdblock3
 31        4       2048 mtdblock4
  8        0  117219767 sda
  8        1    8388608 sda1
  8        2    2097152 sda2
root@R4CN:/#
4. BPI-R4-NIC-BE14(Wi-Fi7)
BPI-R4-NIC-BE14 Block_Diagram
