Getting Started with BPI-R4
   G=GND;  RX=BPI-R4 input;  TX=BPI-R4 output
  * Examples:
 Release Image:  https://wiki.banana-pi.org/Banana_Pi_BPI-R4#Release_image
 Note: boot device select:  https://wiki.banana-pi.org/Getting_Started_with_BPI-R4#Prepare_to_develop
How to burn image to SD card
   * apt-get install pv
   Click on "Flash from file" to select image.
   Click on "Select target" to select USB device.
   Click on "Flash!" Start burning.
 * Note: boot device select:  https://wiki.banana-pi.org/Getting_Started_with_BPI-R4#Prepare_to_develop
    * mtd erase /dev/mtd0
 4. Execute :
Network-Configuration
root@OpenWrt:/# ifconfig
         collisions:0 txqueuelen:1000
         Interrupt:124
         Interrupt:124
eth2 Link encap:Ethernet HWaddr 22:02:CE:9C:92:BA
         Interrupt:124
lo Link encap:Local Loopback
ra0 Link encap:Ethernet HWaddr 00:0C:43:26:60:88
ra1 Link encap:Ethernet HWaddr 02:0C:43:36:60:88
rai0 Link encap:Ethernet HWaddr 00:0C:43:2B:B1:F8
rax0 Link encap:Ethernet HWaddr 0C:0C:43:26:60:D8
bridge name bridge id STP enabled interfaces br-wan 7fff.eea15781ca19 no lan0, eth2
bridge name bridge id STP enabled interfaces br-lan 7fff.eea15781ca19 no apclii0 apclix0 apcli0 ra1 rai0 rax0 lan2 eth1 ra0 lan3 lan1
root@OpenWrt:/#
Accessories
1. 10G SFP Module
10G SFP+ Copper Module
root@R4CN:/# [   67.870063] sfp sfp@0: SM: enter empty:up:down event insert
[   67.875642] sfp sfp@0: SM: exit probe:up:down
[   68.199179] sfp sfp@0: SM: enter probe:up:down event timeout
[   68.215970] sfp sfp@0: module OEM              SFP-10G-T        rev 10   sn 2309250003       dc 230925
[   68.225443] sfp sfp@0: module OEM              SFP-10G-T        rev 10   has been found in the quirk list
[   68.235004] sfp sfp@0: sfp: support mode 00,00000800,00007040
[   68.240749] sfp sfp@0: tx disable 1 -> 0
[   68.244681] sfp sfp@0: SM: exit present:up:wait
[   68.343638] sfp sfp@0: SM: enter present:up:wait event los_high
[   68.349549] sfp sfp@0: SM: exit present:up:wait
[   82.476711] sfp sfp@0: SM: enter present:up:wait event los_low
[   82.482550] sfp sfp@0: SM: exit present:up:wait
[   83.584504] alloc new entry for 18:f2:2c:6f:45:3e, interface:eth2
[   83.590595] recv intf mac ae:19:d1:7e:2a:74
[   95.271188] sfp sfp@0: SM: enter present:up:wait event timeout
[   95.277715] sfp sfp@0: probing phy device through the [MDIO_I2C_ROLLBALL] protocol
[   95.821247] sfp sfp@0: CL45 PHY device [0x31c3:0x1c13] found!
[   95.826999] sfp sfp@0: CL45 PHY device [0x31c3:0x1c13] found!
[   95.832741] sfp sfp@0: CL45 PHY device [0x31c3:0x1c13] found!
[   95.838479] sfp sfp@0: CL45 PHY device [0x31c3:0x1c13] found!
[   95.844217] sfp sfp@0: CL45 PHY driver [Aquantia AQR113C] found!
[   95.850215] sfp sfp@0: phy: support mode 00,00018000,000e706c
[   95.855960] mtk_soc_eth 15100000.ethernet eth2: requesting link mode inband/10gbase-kr with support 00,00018000,000a7068
[   96.273193] mtk_soc_eth 15100000.ethernet eth2: PHY [i2c:sfp@0:11] driver [Aquantia AQR113C]
[   96.357199] sfp sfp@0: SM: exit present:up:link_up
[   96.357206] mtk_soc_eth 15100000.ethernet eth2: resolve link status: system iface=1, line iface=0
[   96.630718] sfp sfp@0: SM: enter present:up:link_up event los_high
[   96.636904] sfp sfp@0: SM: exit present:up:wait_los
[  101.395228] sfp sfp@0: SM: enter present:up:wait_los event los_low
[  101.401416] sfp sfp@0: SM: exit present:up:link_up
[  101.401426] mtk_soc_eth 15100000.ethernet eth2: resolve link status: system iface=1, line iface=0
[  101.696172] mtk_soc_eth 15100000.ethernet eth2: Link is Up - 10Gbps/Full - flow control off
[  101.704534] br-wan: port 2(eth2) entered blocking state
[  101.709754] br-wan: port 2(eth2) entered forwarding state
 root@R4CN:/#
root@R4CN:/# i2cdetect -y 3
    0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:                         -- -- -- -- -- -- -- --
70: UU -- -- -- -- -- -- --
root@R4CN:/#
root@R4CN:/# ethtool eth2
Settings for eth2:
       Supported ports: [ ]
       Supported link modes:   100baseT/Full
                               1000baseT/Full
                               10000baseT/Full
                               1000baseKX/Full
                               10000baseKR/Full
                               2500baseT/Full
                               5000baseT/Full
       Advertised link modes:  100baseT/Full
                               1000baseT/Full
                               10000baseT/Full
                               1000baseKX/Full
                               10000baseKR/Full
                               2500baseT/Full
                               5000baseT/Full
       Link partner advertised link modes:  10baseT/Full
                                            100baseT/Full
                                            1000baseT/Full
                                            10000baseT/Full
                                            2500baseT/Full
                                            5000baseT/Full
       Speed: 10000Mb/s
       Duplex: Full
       Port: MII
       PHYAD: 17
       Transceiver: external
       Auto-negotiation: on
       Link detected: yes
root@R4CN:/#
Note:
10G SFP+ Fibre Module
2. 4G/5G Module
  • BPI-R4 supports M.2 USB Interface Quectel 4G LTE EM25, RM500U-CN & RM520N-GL 5G Modules.
  • If you want to use Cellular Module on BPI-R4:
   1. Install 4G/5G Cellular Module into CN16 Slot(M.2 KEYB)
   2. Inset NANOSIM Card into SIMSlot(SIM1) with card tray(pay attention to the direction)
   3. Install antenna on the module
   4. After powering on, it will automatically dial
3. NVMe SSD
  • please insert one M2.KeyM SSD into M2.KeyM slot.
4. Asia mPCIe WiFi6/WiFi6E
