Banana Pi BPI-R3 Mini
MediaTek MT7986(Filogic 830)
The MT7986A(Filogic 830) integrates four Arm Cortex-A53 cores up to 2GHz with up to 18,000 DMIPs of processing power and 6Gbps of dual 4x4 Wi-Fi6 connectivity. It has two 2.5g Ethernet interfaces and serial peripheral interfaces (SPI). Filogic 830‘s built-in hardware acceleration engine enables fast and reliable Wi-Fi offloading and wireless network connection. In addition, the chip supports Mediatek FastPath™ technology, which is suitable for games, AR/VR and other low-latency applications.
Application direction
- Internet service Router
- Wireless Router
- Wireless Repeater
- Home security Gateway
- Home Automation
- Nas device
- Soft router
- Network and communication applications
- Wifi 6 2.4G/5G(MT7976C)
- 2G DDR RAM
- 8G eMMC flash
- 128MB Nand flash
- 2x 2.5GbE network port
- 1x M.2 Key B USB interface
- 1x M.2 KEY M PCIe interface
- 1x USB2.0 interface
| HardWare Specification of Banana pi BPI-R3 Mini | |||
| CPU | MediaTek MT7986A(Filogic 830) Quad-core ARM Cortex-A53 | ||
| SDRAM | 2 GB DDR4 | ||
| On board Storage | 128MB SPI NandFlash,8GB eMMC | ||
| On board Network | 2x 2.5GbE Ethernet | ||
| Wifi | Wifi6 2x2 2.4G + 3x3 5G(MT7976C) | ||
| M.2 Key B | 1x M.2 Key B interface | ||
| M.2 Key M | 1x M.2 KEY-M PCIe inerface | ||
| USB | 1x USB 2.0 | ||
| Buttons | Reset button, boot switch | ||
| 5x Leds | Power ,System, Wifi 2G ,Wifi 5G ,4G Lte ,SSD | ||
| DC Power | 20W/12V,USB TypeC PD | ||
| Sizes | 65x65mm | ||
| Weight | 100g | ||
SSD and 5G support
- Opensource Driver BSP
- BPI-R3 Mini DXF file
- Google Drive: https://drive.google.com/file/d/1FgNVjR-kPdFVNZBPkAF8xTIZ4YauJ_2O/view?usp=sharing
- Baidu Cloud: https://pan.baidu.com/s/1t1hZjNdg7rMBJcqVEZN-Ag?pwd=8888 (pincode:8888)
- BPI-R3 Mini schematic diagram
- Google Drive:https://drive.google.com/file/d/1wvovcYf0OtvQl5fekJku25QNeER1D7cM/view?usp=sharing
- Baidu Cloud: https://pan.baidu.com/s/1HohHjd2w-mqLlBhwsXR87A?pwd=8888 (pincode:8888)
- Bananapi R3 review with WiFi / CPU benchmarks and power consumption numbers: https://wiki.junicast.de/en/junicast/review/bananapi-BPI-R3
Release image
- bl2_emmc.img
- Google Drive:https://drive.google.com/file/d/1L5lVyg8dDl60eyzkqBr-8aeG2Weq5ouo/view?usp=sharing
- Baidu Cloud:https://pan.baidu.com/s/1vdnCKqr0GSzQid7Y3ADCKw?pwd=8888 (pincode:8888)
- 2023-11-15 BPI-R3 Mini OpenWRT image with Opensource Driver BSP (support Quectel RM500U-CN & RM520N-GL 5G Modules)
- Google Drive: https://drive.google.com/drive/folders/1lENckxpiZa5bdkPAA6FfbGx1IlLJqHql?usp=sharing
- Baidu Cloud: https://pan.baidu.com/s/1btkUMs84-Agj31WxRx8_Dg?pwd=8888 (pincode:8888)
- 2023-11-15 BPI-R3 Mini OpenWRT image with MTK vendor driver, Not OpenSource Driver BSP (support Quectel RM500U-CN & RM520N-GL 5G Modules)
- Google Drive: https://drive.google.com/drive/folders/1RaKPSbQU94miUyawoyPq8RNUdubabKYq?usp=sharing
- Baidu Cloud: https://pan.baidu.com/s/1yFp2P-pV4-b1_x6FjD8NBg?pwd=8888 (pincode:8888)
Accessories
Case design
5G module support
- BPI-R3 mini can use Quectel RM500U-CN & RM520N-GL 5G Modules
- BIPAI Aliexpress shop : https://www.aliexpress.com/item/1005005873750368.html?
- SINOVOIP Aliexpress shop: https://www.aliexpress.com/store/group/BPI-R3-Mini/1100417230_40000004378662.html?
- Taobao shop : https://item.taobao.com/item.htm?spm=a213gs.success.result.1.1bd14831HTwBxZ&id=730610953668
- OEM&ODM ,please contact : [email protected]
