Getting Started with BPI-R4
 * Using your USB-Serial cable Connect to debug console on BPI-R4
   G=GND;  RX=BPI-R4 input;  TX=BPI-R4 output
  * Examples:
Accessories
1. 10G SFP Module
The SFP serdes of BPI-R4 requesting link mode inband/10gbase-kr, so only SFP that support this protocol can be used!
10G SFP+ Copper Module
Note:
10G SFP+ Fibre Module
2. 4G/5G Module
3. SSD
4. Asia mPCIe WiFi6/WiFi6E
