Getting Started with BPI-R4
Revision as of 01:42, 21 November 2023 by Sinovoip (talk | contribs) (Prepare to develop)
 * Using your USB-Serial cable Connect to debug console on BPI-R4
  * Examples:
Accessories
1. 10G SFP Module
The SFP serdes of BPI-R4 requesting link mode inband/10gbase-kr, so only SFP that support this protocol can be used!
10G SFP+ Copper Module
Note:
10G SFP+ Fibre Module
2. 4G/5G Module
3. SSD
4. Asia mPCIe WiFi6/WiFi6E
