Banana Pi BPI-M6
About VideoSmart VS680
- Synaptics VideoSmart VS680 quad-core Cortex-A73 (2.1GHz) and One Cortex-M3 processor
- Imagination GE9920 GPU
- NPU for AI up to 6 .75Tops
- 4GB LPDDR4
- 16GB eMMC flash
- M.2 Key E(PCIe + MIPI CSI)
- 4 USB 3.0
- 1 GbE ethernet
- 1 HDMIin and 1 HDMIout
| HardWare Specification of Banana pi BPI-M6 | |||
| CPU | Synaptics VS680 quad-core Cortex-A73 (2.1GHz) and One Cortex-M3 processor | ||
| GPU | Imagination GE9920 GPU | ||
| NPU for AI | Up to 6 .75Tops | ||
| Memory | 4 GB LPDDR4 | ||
| Video | 1 x HDMI 2.1 (up to 4K@60Hz with HDR, CEC, EDID) out, and 1 HDMI in Port | ||
| Audio Output(s) | 1 x HDMI digital output | ||
| Display | MIPI DSI interface | ||
| M.2 interface | M.2 Key E(PCIe + MIPI CSI) | ||
| Switches | SPI boot and U-boot | ||
| Power Source | 5 volt @3A TYPE C | ||
| OS | Android and Linux | ||
Source code on github
- Senary VS680(Synaptics SN3680) datasheet:
- The VS680 NPU is ranked first on AI benchmark website: https://ai-benchmark.com/ranking_IoT.html
- BPI-M6 AI function test: https://www.youtube.com/watch?v=RIO0K_V12D4
- BPI-M6 VS680 SOC System Tool Manual V1.3.2.1
- Baidu Cloud: https://pan.baidu.com/s/1tX7UVSJQOcNhMlazQRQkpw?pwd=8888 (pincode:8888)
- Google Drive: https://drive.google.com/file/d/1gQalGLqNN24TeTBmJGzS0e3HeXxRD1fP/view?usp=sharing
- BPI-M6 schematic diagram
- Baidu Cloud: https://pan.baidu.com/s/18VTAdGtQFb2nu1bku8mHBw?pwd=8888 (pincode:8888)
- Google Drive: https://drive.google.com/file/d/1z-o5dZWcYrmTqNH3Wz9ttWUzptveCS6s/view?usp=sharing
- BPI-M6 DXF File:
- Baidu Cloud: https://pan.baidu.com/s/1Ngc11CcnufAdDcdwMd2mmQ?pwd=8888 (pincode:8888)
- Google Drive: https://drive.google.com/file/d/1HJmpC5L3YqrJt4IsN0SMD5HoowqfGCyU/view?usp=sharing
- Vergleich Banana Pi Bpi M6 Vs Raspberry Pi 5:https://cool-web.de/raspberry/vergleich-banana-pi-bpi-m6-vs-raspberry-pi-5.htm
- Banana Pi Bpi M6 Raspberry Pi 5 Alternative Ersteinrichtung Firmware Image Hochladen:https://cool-web.de/raspberry/banana-pi-bpi-m6-raspberry-pi-5-alternative-ersteinrichtung-firmware-image-hochladen.htm
- 2023-08-30 release aosp_dolphin_tablet-syna-image-lpddr4x
- Baidu Cloud: https://pan.baidu.com/s/1unEibD-NI8-Ti5le2E6d7g?pwd=8888 (pincode:8888)
- Google Drive:https://drive.google.com/file/d/1egPBOusdlNGJDdp5muAjiv2MvMya0F-H/view?usp=sharing
- SINOVOIP Aliexpress Shop: https://www.aliexpress.us/item/3256805894958914.html
- BIPAI Aliexpress Shop: https://www.aliexpress.us/item/3256805895088983.html
- Taobao Shop:https://item.taobao.com/item.htm?spm=a213gs.success.result.1.27e34831MXYuie&id=740957817652&qq-pf-to=pcqq.group
