Banana Pi router Comparison
Revision as of 16:59, 14 May 2018 by Sinovoip (talk | contribs)
Banana Pi Smart router Comparison
CPU Allwinner A20,32 Bit Cortex™-A7 2-Core 1G MTK MT7623N, 32 Bit Cortex™-A7 4-Core 1.3GHz
GPU ARM® Mali400MP2 ARM® Mali450 MP4 -
SDRAM 1GB DDR3 (shared with GPU) 432Mhz 2GB DDR3 (shared with GPU) 1600Mhz
Storage "SD Card up to 64GB (SDXC) 1 SATA up to 2TB " "MicroSD (TF) card (UHS-1) 2 SATAIII 6Gbps EMMC 4.5 8GB "
Network 4x Gigabit LAN 1x Gigabit WAN 4x Gigabit LAN 1x Gigabit WAN (MT7530)
RF 802.11b/g/n (RTL8192CU) "802.11a/b/g/n & BT4.1 (MT6625L) 802.11ac moudle Wi-Fi 4x4 (MT7615 option)"
Vidio In CSI input for video cameras NA
Video Out HDMI/LVDS/RGB HDMI/MIPI
Audio Output 3.5 mm Jack and HDMI N/A
Audio In Microphone N/A
GPIO 40-PIN GPIO, UART, I²C bus,I²S bus,SPI bus with two chip selects, CAN bus, PWM,+3.3 V, +5 V, ground 40-PIN: PWM,GPIO,UART,I²C bus,I²S bus,SPI bus,+3.3v,+5v,ground.
Power Source 5 volt via MicroUSB and/or MicroUSB (OTG) 12 volt via DC In
USB Ports 2 USB 2.0 ports, 1 OTG microUSB port 2 USB 3.0 host,1 USB 2.0 OTG
Buttons Reset button Power button, Uboot button
LED Power key and RJ45
Remote IR reciever
Board Size 120 mm ×  100mm
Box Size 28 mm x 170mm x 150mm
Weight 60g
OS Android and Linux OS
