Getting Started with BPI-M6
Revision as of 08:29, 3 November 2023 by Squy (talk | contribs) (→Linux)
Banana Pi BPI-M6 with Synaptics VS680
Banana Pi BPI-M6 is a new generation single board computer design , use Synaptics VS680 quad-core Cortex-A73 (2.1GHz) and One Cortex-M3 processor,Imagination GE9920 GPU.and NPU Up to 6 .75Tops. Onboard 4GB LPDDR4 memory and 16GB EMMC storage, and supports 4 USB 3.0 interface, a gigabit network port.onboard 1 HDMI-rx port and 1 Hdmi-tx port.
  • Synaptics VideoSmart VS680 quad-core Cortex-A73 (2.1GHz) and One Cortex-M3 processor
  • Imagination GE9920 GPU
  • NPU for AI up to 6 .75Tops
  • System Memory – 4GB LPDDR4
  • Storage – 16GB eMMC flash
  • Video Output – 1 HDMIin and 1 HDMIout
  • Expansion – 40-pin
  • Misc – Reset, Power, and U-boot button; power and activity LED’s;
  • M.2 Key E(PCIe + MIPI CSI)
1. Prepare a usb-serial cable, a 5V/3A adaptor type-c power supply. The serial cable is used for console debug and type-c cable is used for android image download.
1. Download and install the SenarySocSystemTool for android image download via USB type-c on M6, only support windows.
1. Open SenarySocSystemTool.exe, click Browse, and select the eMMCimg folder where the image is located.
2. Press the USB button next to type-c and connect to the computer using the type-c cable.
3. Click to start burning, and then wait for the burning to complete.
4. After Burning successfull, press the RST key, Unplug the usb and connect to power supply adaptor to startup.
5. If you want to erase eMMC, you can repeat the above steps, but you need to click on Erase eMMC instead of starting the burn.
Install Image with Balena Etcher.
1.Click on "Flash from file" to select image. Click on "Select target" to select USB device. Click on "Flash!" Start burning.
2.After the image is burned, insert the SD card into the BPI-M6. Press and hold the SPI key while inserting the power supply.
