Banana Pi BPI-R4
Revision as of 03:03, 27 September 2023 by Sinovoip (talk | contribs) (Hardware spec)
Banana Pi BPI-R4 with MediaTek Filogic 800 (MT7988)
Banana Pi BPI-R4 with 2.5G ETH and PoE support
Banana Pi BPI-Wifi6 Router with Triductor TR6560 + TR5220 wifi SOC
Banana Pi BPI-R4 Router board with MediaTek MT7988A (Filogic 880) quad-core ARM Corex-A73 design ,4GB DDR4 RAM,8GB eMMC,128MB SPI-NAND flash onboard, also have 2x 10Gbe SFP, 4x Gbe network port,with USB3.2 port,M.2 support 4G/5G/NVME SSD.2x miniPCIe slots with PCIe3.0 2lane interface for Wi-Fi 7 NIC (Network Interface Card). It is a very high performance open source router development board.
MediaTek MT7988(Filogic 880)
Mediatek Filogic 880. the 36Gbps Wi-Fi 7 access point/router/gateway platform delivers the fastest and most reliable connection experience
The MediaTek MT7988A is a world-Leading network processing platform for high-performance and reliable networking experiences,both in wired and wireless applications. The MT7988A comprises a rich connection interface sets include 4 Gigabit Ethernet ports. 2 US下GMII interfaces. 4 PCIe Interfaces,and 2 USB 3.2 en1 Ports
the MT7988A further enables seamless Wi-Fi 7 tri-band,2.4 GHz.5 GHz and 6 GHz,connectivity,with its Wi-Fi 7 companion chip that features 320-MHz bandwidth,4096-QAM ,MLO,MRU,and AFC.
To answer the need of fast-evolving tunneling applications,the MT7988A comes with MediaTek Tunnel offload processor System(TOPS),which facilitates the processing of a wide range of tunneling protocols.The MT7988A optimizes networking performance with exquistitely tuned ISA of MediaTek TOPS,and is dedicated to lifting networking offloading performance to premium level.
Application direction
  • Internet service Router
  • Wifi 7 Wireless Router
  • 4G/5G Wireless Router
  • Wireless Repeater
  • Home security Gateway
  • Home Automation
  • Nas device
  • Network and communication applications
  • MediaTek MT7988A (Filogic 880) quad-core Arm Corex-A73,1.8GHz processor
  • 4GB DDR4
  • 8GB eMMC flash
  • 128MB SPI-NAND Flash
  • Micro SD card slot
  • 2x 10Gbe SFP slot (option 1x 10Gbe SFP and 1x SOC embedded 2.5Gbe PHY. NOTE: Need to modify hardware)
  • 4x Gbe network port
  • 1x USB3.2 slot
  • 1x M.2 KEY-B slot with USB3.2/PCIe3.0 interface for 5G
  • 1x M.2 KEY-M slot with PCIe3.0 1lane interface for NVME SSD
  • 2x miniPCIe slots with PCIe3.0 2lane interface for Wi-Fi 7 NIC (Network Interface Card)
  • 26 PIN GPIO Header for expanding application
WiFi7 iPA NIC Module support
BPI-R4 wifi 7 modue use MediaTek MT7996+MT7995+MT7977A+MT7977B chip design
HardWare Specification of Banana pi BPI-R4
CPU MediaTek MT7988A (Filogic 880) quad-core Arm Corex-A73,1.8GHz processor
SDRAM 4 GB DDR4
GPIO 26 Pin GPIO,some of which can be used for specific functions including UART, I2C, SPI, PWM, I2S.
On board Network 4 Port 10/100/1000Mbps Ethernet
SFP 2x10G SFP or 1x10G SFP and 1x 2.5GbE
Wifi Wifi6/Wifi 7
mini PCIE 2x miniPCIe slots with PCIe3.0 2lane interface for Wi-Fi 7 NIC (Network Interface Card)
M.2 interface 1x M.2 KEY-B slot with USB3.2/PCIe3.0 interface for 5G,1x M.2 KEY-M slot with PCIe3.0 1lane interface for NVME SSD
USB 1xUSB 3.2 slot
Buttons Reset button,WPS botton, boot switch
DC Power 12V/5.2A or 19V 3.2A
Sizes 100.5x148mm same as Banana Pi BPI-R64 and Banana Pi BPI-R2
Weight 250g
Release image
BPI-R4 Accessories
WiFi7 iPA NIC
Wifi 7 module interface
Asia WiFi6/WiFi6E
mPCIe 4G/5G Module
M.2 5G module
10G SFP Fibre
