Getting Started with BPI-R3 MINI
MediaTek MT7986(Filogic 830)
- Wifi 6 2.4G/5G(MT7976C)
- 2G DDR RAM
- 8G eMMC flash
- 128MB Nand flash
- 2x 2.5GbE Ethernet port
- 1x M.2 Key B USB inerface
- 1x M.2 KEY M PCIe inerface
- 1x USB2.0 interface
* Prepare USB-Serial interface * Using your USB-Serial Connect debug console on BPI-R3 MINI Note: Debug Uart 3.3v TTL![]()
Warnning
if you want to update EMMC device, please boot from Nand![]()
otherwise you update Nand device when it boot from EMMC.![]()
Before burning image to eMMC, please prepare a USB disk. Let's take OpenWrt image (mtk-bpi-r3mini-EMMC-20230719.img, bl2_emmc.img) for example, the steps are below:
1. Copy EMMC boot OpenWrt image(mtk-bpi-r3mini-EMMC-20230719.img, bl2_emmc.img) to USB disk. 2. Change boot switch Jumper, the board boot from Nand device, then power up the board. 3. Plug in USB disk to the board, and mount the USB to /mnt or other directory as follows: (you can skip mounting if it is mounted automatically) * mount -t vfat /dev/sda1 /mnt * change your directory to the mounting point, here is : cd /mnt
4. Execute following command to enable and copy image to EMMC device: * echo 0 > /sys/block/mmcblk0boot0/force_ro * dd if=bl2_emmc.img of=/dev/mmcblk0boot0 * dd if=mtk-bpi-r3mini-EMMC-20230719.img of=/dev/mmcblk0 * mmc bootpart enable 1 1 /dev/mmcblk0
5. power off R3MINI board, remove u-disk driver, change bootstrap to boot from emmc device. Note: Enable EMMC device, boot strap is from EMMC.
1. Copy Nand boot OpenWrt image(mtk-bpi-r3mini-NAND-20230719-single-image.bin) to USB disk. 2. Change boot switch Jumper, the board boot from EMMC device, then power up the board. 3. Plug in USB disk to the board, and mount the USB to /mnt or other directory as follows: (you can skip mounting if it is mounted automatically) * mount -t vfat /dev/sda1 /mnt * change your directory to the mounting point, here is : cd /mnt
4. Execute following command to erase the whole Nand flash and copy image to nand device: * mtd erase /dev/mtd0 * dd if=mtk-bpi-r3mini-NAND-20230719-single-image.bin of=/dev/mtdblock0
5. power off BPI-R3 MINI board, remove u-disk driver, change bootstrap to boot from Nand device. Note: Enable Nand device, boot strap is from Nand.
Network-Configuration
root@OpenWrt:/# ifconfig
lo Link encap:Local Loopback
root@OpenWrt:/#
FAN
- CN16 supports PWM control.
PWM FAN Control
M.2 KEY B slot
currently, M.2 KEY B slot only support USB 4G/5G module, example: Quectel RM500U-CN
when you install one 4G/5G module, you may check it.
4G/5G Module
BPI-R3mini supports 4G LTE EM05, 5G Quectel RM500U-CN/RG200U-CN or RM520N-GL/RM500Q-GL Series.
The released image default driver is RM500U-CN, install RM500U-CN and it can be used.
If you use other modules, such as RM520N-GL/RM500Q-GL or EM05, you may need to modify the driver.
Ap mode on BPI-R3
- ra0 is MT7986a 2.4G wifi
- rax0 is MT7986a 5G wifi
Wifi & Serial cable
If the chip type of serial cable is pl2303, the driver fails to load the firmware apparently and thus the wifi can't work.
Other types including cp2102,ch340 and FDTI are all available, serial cable vlotage must be 3.3v LVTTL standard.
You can buy the serial cable here: https://www.aliexpress.us/item/3256805457599756.html?
If your computer has a USB TypeC connector and supports PD12V/1.5A (20W) or above, you can also directly use the computer to power BPI-R3mini.
Moreover, since BPI-R3mini has built-in USB to serial port chip CH340E, you do not need to use additional serial cables.
NOTE:If your computer does not support USB PD, then the R3mini will most likely keep restarting.
Because the power consumption of R3mini is relatively large (all peripherals are plugged in and the power consumption is close to 20W when running)
TTL Voltage
