Getting Started with BPI-R3 MINI
MediaTek MT7986(Filogic 830)
- Wifi 6 2.4G/5G(MT7976C)
- 2G DDR RAM
- 8G eMMC flash
- 128MB Nand flash
- 2x 2.5GbE Ethernet port
- 1x M.2 Key B USB inerface
- 1x M.2 KEY M PCIe inerface
- 1x USB2.0 interface
* Prepare USB-Serial interface
* Using your USB-Serial Connect debug console on BPI-R3 MINI
Note: Debug Uart 3.3v TTL
Warnning
Note: Because BPI-R3 MINI can't support that it boot from SD, So the factory will flash one default image into Nand and EMMC Device.
if you want to update EMMC device, please boot from Nand
otherwise you update Nand device when it boot from EMMC.
File:R3mini eMMC BOOT2.png
Anytime please confirm that one EMMC or Nand device include one bootable image, it's very important!!
Before burning image to eMMC, please prepare a USB disk. Let's take OpenWrt image (mtk-bpi-r3mini-EMMC-20230719.img, bl2_emmc.img) for example, the steps are below:
1. Copy EMMC boot OpenWrt image(mtk-bpi-r3mini-EMMC-20230719.img, bl2_emmc.img) to USB disk.
2. Change boot switch Jumper, the board boot from Nand device, then power up the board.
4. Execute following command to enable and copy image to EMMC device:
* dd if=mtk-bpi-r3mini-EMMC-20230719.img of=/dev/mmcblk0
5. power off R3MINI board, remove u-disk driver, change bootstrap to boot from emmc device.
1. Copy Nand boot OpenWrt image(mtk-bpi-r3mini-NAND-20230719-single-image.bin) to USB disk.
2. Change boot switch Jumper, the board boot from EMMC device, then power up the board.
* mtd erase /dev/mtd0
* dd if=mtk-bpi-r3mini-NAND-20230719-single-image.bin of=/dev/mtdblock0
5. power off BPI-R3 MINI board, remove u-disk driver, change bootstrap to boot from Nand device.
Network-Configuration
root@OpenWrt:/# ifconfig
inet addr:192.168.1.1 Bcast:192.168.1.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:2418 (2.3 KiB)
RX bytes:0 (0.0 B) TX bytes:8538 (8.3 KiB)
RX bytes:0 (0.0 B) TX bytes:4408 (4.3 KiB)
Interrupt:124
RX bytes:0 (0.0 B) TX bytes:8674 (8.4 KiB)
Interrupt:124
lo Link encap:Local Loopback
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Interrupt:6
root@OpenWrt:/#
FAN
- CN16 supports PWM control.
PWM FAN Control
M.2 KEY B slot
currently, M.2 KEY B slot only support USB 4G/5G module, example: Quectel RM500U-CN
when you insert one 4G/5G module, you may check it.
4G/5G Module
- BPI-R3mini supports 4G LTE EM05, 5G Quectel RM500U-CN or RM500Q-GL Series.
The released image default driver is RM500U-CN, install RM500U-CN and it can be used.
If you use other modules, such as RM500Q-GL or EM05, you may need to modify the driver.
Ap mode on BPI-R3
- ra0 is MT7986a 2.4G wifi
- rax0 is MT7986a 5G wifi
Wifi & Serial cable
TTL Voltage
