Banana Pi BPI-M2M
- Allwinner R16/A33 Quad Core ARM Cortex A7 CPU.
- 512MB DDR3 SDRAM.
- 8G eMMC flash
- CSI camera interface
- DSI display interface
- how to burn image : Quick Start Banana pi SBC
- how to development BPI-M2 Magic : Getting Started with M2M
| Banana Pi M2 Magic | |
| CPU | Allwinner R16 ARM Cortex-A7 Quad-Core |
| GPU | PowerVR SGX544MP1 Comply with OpenGL ES 2.0 OpenCL 1x, DX9_3 |
| Memory | 512MB LPDDR3 (shared with GPU) |
| Storage | On Board 8GB eMMC Flash, Micro SD-Card slot. |
| Network | Wi-Fi 802.11 b/g/n (AP6212) + Bluetooth BT4.0 |
| Video Input(s) | A CSI input connector allows for the connection of a designed camera module |
| Video Output(s) | MIPI Display Serial Interface (DSI) for raw LCD Panel |
| Audio Input(s) | On board microphone |
| Audio Output(s) | 3.5mm jack |
| USB ports | USB 2.0 PORT (x1), USB OTG (x1) |
| Remote | Not IR Receiver |
| Switches | Reset, Power and U-boot |
| Size & Weight | 51x51mm, 48g |
| OS | Android and Linux |
| 40 PIN GPIO of Banana pi BPI-M2 Magic | |||
| PIN number | Default Function | Function2:GPIO | |
| CON1-P01 | VCC-3V3 | ||
| CON1-P02 | DCIN | ||
| CON1-P03 | TWI1-SDA | PH5 | |
| CON1-P04 | DCIN | ||
| CON1-P05 | TWI1-SCK | PH4 | |
| CON1-P06 | GND | ||
| CON1-P07 | PWM1 | PH1 | |
| CON1-P08 | UART2-TX | PB0 | |
| CON1-P09 | GND | ||
| CON1-P10 | UART2-RX | PB1 | |
| CON1-P11 | UART3_TX | PH6 | |
| CON1-P12 | AP-PCM-CLK-CTS | PG11 | |
| CON1-P13 | UART3_RX | PH7 | |
| CON1-P14 | GND | ||
| CON1-P15 | LVDS_V1N | PD21 | |
| CON1-P16 | UART2-RTS | PB2 | |
| CON1-P17 | VCC-3V3 | ||
| CON1-P18 | UART2-CTS | PB3 | |
| CON1-P19 | SPI0_MOSI | PC0 | |
| CON1-P20 | GND | ||
| CON1-P21 | SPI0_MISO | PC1 | |
| CON1-P22 | LVDS_V1P | PD20 | |
| CON1-P23 | SPI0_CLK | PC2 | |
| CON1-P24 | SPI0_CS | PC3 | |
| CON1-P25 | GND | ||
| CON1-P26 | LVDS_VCN | PD25 | |
| CON1-P27 | LVDS_V0N | PD19 | |
| CON1-P28 | LVDS_VCP | PD24 | |
| CON1-P29 | LVDS_V0P | PD18 | |
| CON1-P30 | GND | ||
| CON1-P31 | LVDS_V2N | PD23 | |
| CON1-P32 | LVDS_V2P | PD22 | |
| CON1-P33 | LVDS_V3N | PD27 | |
| CON1-P34 | GND | ||
| CON1-P35 | AP-PCM-SYNC | PG10 | |
| CON1-P36 | LVDS_V3P | PD26 | |
| CON1-P37 | PL11-EINT11 | PL11-EINT11 | |
| CON1-P38 | AP_PCM_DIN | PG13 | |
| CON1-P39 | GND | ||
| CON1-P40 | AP-PCM-DOUT | PG12 | |
| CSI Camera pin define of Banana pi BPI-M2 Magic | |||
| CN3-P01 | NC | ||
| CN3-P02 | GND | ||
| CN3-P04 | CSI0-AVDD | ||
| CN3-P10 | CSI0-DVDD | ||
| CN3-P11 | |||
| CN3-P15 | GND | ||
| CN3-P16 | CSI0-D5 | PE9 | |
| CN3-P18 | CSI0-D4 | PE8 | |
| CN3-P19 | CSI0-D0 | PE4 | |
| CN3-P20 | CSI0-D3 | PE7 | |
| CN3-P21 | CSI0-D1 | PE5 | |
| CN3-P22 | CSI0-D2 | PE6 | |
| CN3-P23 | GND | ||
| CN3-P24 | CSI0-AFVCC | ||
- DSI Pin Name**
| MIPI DSI PIN define of Banana pi BPI-M2 Magic | |||
| CN2-P01 | DSI-D0N | ||
| CN2-P02 | DSI-D0P | ||
| CN2-P03 | DSI-D1N | ||
| CN2-P04 | DSI-D1P | ||
| CN2-P05 | DSI-CKN | ||
| CN2-P06 | DSI-CKP | ||
| CN2-P07 | DSI-D2N | ||
| CN2-P08 | DSI-D2P | ||
| CN2-P09 | DSI-D3N | ||
| CN2-P10 | DSI-D3P | ||
| CN2-P11 | NC | ||
| CN2-P12 | NC | ||
| CN2-P13 | TP-SDA | PH3 | |
| CN2-P14 | TP-SCK | PH2 | |
| CN2-P15 | TP-INT | PB5 | |
| CN2-P16 | TP-RST | PB6 | |
| CN2-P17 | LCD-BL-EN | PL4 | |
| CN2-P18 | LCD-RST | PL5 | |
| CN2-P19 | LCD-PWR-EN | PB7 | |
| CN2-P20 | LCD-PWM | PH0 | |
| CN2-P21 | GND | ||
| CN2-P22 | GND | ||
| CN2-P23 | PS | ||
| CN2-P24 | PS | ||
The header CON4 is the UART0 interface. kernel debug uart is UART2 of 40pin header.
| Uart PIN define of Banana pi BPI-M2 Magic | |||
| CON3-P1 | GND | ||
| CON3-P2 | UART0-RX | ||
| CON3-P3 | UART0-TX | ||
android 6.0 source code
google driver : https://drive.google.com/file/d/1FhHAVjNWTi8Uq-LNMn0liqcHS4cSN5xY/view?usp=drivesdk
- BPI-M2 Magic Gerber/Boom/Assembly document:
- Baidu cloud: https://pan.baidu.com/s/1cpuZXDWfuW6twX_IYBRWaw?pwd=8888 (pincode: 8888)
- Google drive: https://drive.google.com/file/d/1017oWy4oR7l5weSilT0MqaIQubfBkTXa/view?usp=sharing
- allwinner R16 chip Datasheet-V1.4 (1): https://drive.google.com/file/d/0B4PAo2nW2KfnVW9FSUpPX2FLcU0/view?usp=sharing
- Allwinner_R16_User_Manual_V1.2: https://drive.google.com/file/d/0B4PAo2nW2KfnUjZUNVdyN1RkVlE/view?usp=sharing
- SCH : google driver
- AXP223 Datasheet V1.0_en :https://drive.google.com/file/d/0B4PAo2nW2KfnckxWZFBBMUNWSUk/view?usp=sharing
- BPI-M2 Magic DXF file public https://drive.google.com/file/d/0B4PAo2nW2KfnalhDRG5EclU1dHM/view?usp=sharing
Android 6.0 LCD7-Version
- 2019-08-06 update ,BPI-M2 Magic Android 6 new image release ,This release is for banana pi M2m board with BPI 7" panel, and it is based on Android 6.0 Operation system with kernel 3.4.
- Android 6
- Fetures Map: http://wiki.banana-pi.org/M2M_Image_Map#Kernel_3.4
- Google Drive : https://drive.google.com/open?id=1QH9v37XCpOAxFJLaazsSzzFyFj2LdPtg
- Baidu Drive : https://pan.baidu.com/s/1xO9jZQsNXoTAmdpDFBiwYg (PinCode:alyr)
- MD5 : 90e2f11480b54ba6fa5b630770913a85
- FAQ
- How to install Android image,Please see here: http://wiki.banana-pi.org/Install_Linux_%26_Android_images_on_Banana_pi_SBC#Install_Android_Images
- Android 6
- Image Link:
- Google Drive: https://drive.google.com/open?id=0B_YnvHgh2rwjbkNuaEt4OTlyQjg
- Baidu Drive:https://pan.baidu.com/s/1qY8zAmo
- Forum thread:
- 2021-03-24 release, Ubuntu Mate Desktop 16.04 with kernel 3.4.39
- Download: 2021-03-24-ubuntu-16.04-mate-desktop-bpi-m2m-sd-emmc.img.zip
- MD5: 393407f3433acf69eabc19e8730f63f0
- 2021-03-24 release, Ubuntu Server 16.04 with kernel 3.4.39
- Download: 2021-03-24-ubuntu-16.04-server-bpi-m2m-sd-emmc.img.zip
- MD5: 80f6bef4628eef0da8c5800819cc1cfd
- 2019-05-11 update This release is for banana pi M2 Magic board which is based on R16, and it is based on Ubuntu 16.04 Operation system with kernel 3.4.
- .BPI-M2M Ubuntu Server 16.04 Features Map : http://wiki.banana-pi.org/M2M_Image_Map
- LCD7 SD & Emmc version images:
- Google Drive : https://drive.google.com/file/d/1jrW7BKWblRyYYpgB6SEMnRWoGjREVexe/view
- Baidu Drive : https://pan.baidu.com/s/1QIXnZHg7MS9pR7pRXvZu1w (PinCode:n20l)
- MD5 : 9dcd344f0a6433bc649301930599d45b
- CD7 Emmc version image:
- Notes : Because sd pins and uart0 pins are the same, so we have to use uart2 as debug console before, and I release this image is just in order to release uart2 to use and set uart0 as debug console.
- How to burn image:you just need to use m2m boot from a sd image, then use sd image to install this emmc image on emmc.
- Google Drive : https://drive.google.com/open?id=1vJqO2O47Ekq9diny7kZQKBQLXylCGuTG
- Baidu Drive : https://pan.baidu.com/s/1xE5tpw0DqNAV2mqKg_TbpQ (PinCode:awpy)
- MD5 : 9f576cfaeb0329648b14b541ff2f5dd4
- FAQ:For more operation details please see Wiki: http://wiki.banana-pi.org/Getting_Started_with_M2M
- forum pthread: http://forum.banana-pi.org/t/bpi-m2m-r16-new-image-release-ubuntu-server-16-04-2019-05-09/9205
- Unbutu 16.04 2018-08-25 Image Link: This release is for banana pi M2 Magic board which is based on R16, and it is based on Ubuntu 16.04 Operation system with kernel 3.4.
- BPI-M2M Ubuntu 16.04 Features Map:http://wiki.banana-pi.org/M2M_Image_Map
- LCD 7’-Version Google Drive : https://drive.google.com/open?id=14LH4NGAyfeCXhnKlzc75-K6p2gmO5RrM
- LCD 7’-Version Baidu Drive : https://pan.baidu.com/s/17jiGC4fCSTfVKPWUgh-VXA
- Forum pthread:http://forum.banana-pi.org/t/bpi-m2m-r16-new-image-release-ubuntu-16-04-2018-08-25/6596
- For more operation details please see Wiki: http://wiki.banana-pi.org/Getting_Started_with_M2M
- Unbutu 16.04 2018-01-04 Image Link:
- Baidu Drive:https://pan.baidu.com/s/1kVKjxOF
- Google Drive: https://drive.google.com/file/d/1GKwVO03Z5VHOaodVVyboLC-F7r_qyk7e/view?usp=sharing2
- MD5: df72548c26cd42b8138f334f5b383f31
- Unbutu 16.04 2017-10-23 Image Link:
- Baidu Drive:http://pan.baidu.com/s/1hsGhxWS
- Google Drive: https://drive.google.com/file/d/0B_YnvHgh2rwjU2xWQ3otX0JZb1E/view?usp=sharing
- MD5: 23cd3f0891d8ad274984eea3f4981eab
Tina Linux
- 2017-11-15 update : tina astar m2magic
- more about Tina Linux Tina Linux
- image name : 2017-11-15-tina_astar-m2magic_card0_burn_by_PhoenixCard.img
- google downlad : https://drive.google.com/open?id=13iVMJJVY6i8GJjMjoAyk62IDW83MagDX
- forum pthread: http://forum.banana-pi.org/t/bpi-m2-magic-new-image-2017-11-15-tina-astar-m2magic-card0-burn-by-phoenixcard/4184
