Banana Pi BPI-CM2
[hide]BPI-CM2 Introduction
Banana Pi BPI-CM2 with RK3568 design
Banana Pi BPI-CM5 with A311D2 design
Banana Pi BPI-CM5 with BPI-CM4 base board
Banana Pi BPI-CM4 with A311D design
Banana Pi BPI-CM4 with base board
Banana Pi BPI-CM4 with Raspberry Pi CM4 base board
Banana Pi BPI-CM2 is a computer module with Rockchip RK3568 Quad-core ARM Cortex-A55 CPU, Mali-G52 1-Core-2EE GPU,2GB LPDDR4/LPDDR4x ,8 G eMMC flash (Max 128G),Designed with Board to Board connectors for enhanced stability same as Raspberry Pi CM4 , which means that it should work with carrier boards designed for the Raspberry Pi CM4.
Application direction
- . Maker DIY
- . Internet service gateway
- . robot control
- . Industrial control and industrial automation gateway
- . Nas device
- 1. Rockchip RK3568 Quad-core ARM Cortex-A55 CPU
- 2. Mali-G52 1-Core-2EE GPU
- 3. 2GB LPDDR4/LPDDR4x (Max 8G)
- 4. 8G eMMC flash (Max 128G)
- 14. support Android and Linux system.
- 15. Size: 55x40mm
BPI-CM2 Module Hardware interface
BPI-CM2 Module PIN Out define
BPI-CM2 moudule base board interface
Banana Pi BPI-CM2 SBC specifications
Same size as RPI CM4
Third part image
- OEM&ODM please contact : judyhuang@banana-pi.com
