Banana Pi BPI-P2 Pro
Banana Pi BPI-P2 pro(Armsom Pro) is a development board based on RK3308B-S chip developed by armsom company. With a high-performance 4-core ARM Cortex-A35 processor, it provides a high-performance external memory interface (16bit DDR2/DDR3/DDR3L/LPDDR2). The chip has a wealth of interfaces, such as I2S,PCM,TDM, I2C,UART,SPDIF,HDMI ARC, etc., to meet the application of different products. RK3308 has a rich voice interface, its own eight ADC interface, multi-channel I2S and multi-channel PDM interface. This not only provides customers with a wealth of interface choices, but also can reduce the hardware design difficulty and hardware design cost of products.
  • CPU: 64bits Quad-core Arm Cortex-A35 Rockchip RK3308.
  • 512 DDR3 SDRAM.
  • 8G eMMC flash onboard.
  • WiFi (AP6255) & Bluetooth onboard.
  • 100M LAN
Getting Start with BPI-P2 Pro
ArmSoM-p2 pro
SOC RockChip RK3308B-S
CPU Quad-core ARM Cortex-A35
GPU none
ROM 512MB
RAM 8GB ,eMMC
TF Card TF card (Max 64GB)
Network 100M LAN
PoE power PoE function support,Output Voltage 5V, Output Power 10W
WiFi AP6256
Audio Output With built-in audio CODEC, including ADC×8 and DAC×2
Power Source TYPE C 5V/2A or PoE power
USB 1xUSB 2.0
1xType-C
Others Fan、RTC、LED、debug
Low-level peripherals 40 Pin + 12 Pin
LED Power led & Status led
Product size 65mm X 52.5mm
Weight 30g
Memory \(SDRAM\) 512M 512M DDR3(shared with GPU) 512M DDR3(shared with GPU) 512 MB DDR2
IR N/A N/A N/A N/A
Weight 30g 30g 15g 9g
PoE support
