Getting Started with BPI-R3 MINI
Banana Pi BPI-R3 Mini Router board with MediaTek MT7986(Filogic 830) quad core ARM A53 chip design ,2G DDR RAM ,8G eMMC flash onboard,It is a very high performance open source router development board,support Wi-Fi6 2.4G wifi use MT7976 and 5G wifi use MT7976, support 2 2.5GbE network port.
- MediaTek MT7986(Filogic 830) Quad core ARM Cortex A53
- Wifi 6 2.4G/5G(MT7976C)
- 2G DDR RAM
- 8G eMMC flash
- 128MB Nand flash
- 2x 2.5GbE network port
- 1x M.2 Key B USB inerface
- 1x M.2 KEY M PCIe inerface
- 1x USB2.0 interface
* Prepare USB-Serial interface
* Using your USB-Serial Connect debug console on BPI-R3 MINI
Note: Debug Uart 3.3v TTL
*R3 boot switch Jumper Setting Note: EMMC Boot or Nand boot Support.
Warnning
Note: Because BPI-R3 MINI can't support that it boot from SD, So the factory will flash one default image into Nand and EMMC Device. if you want to update EMMC device, please boot from Nand, otherwise you update Nand device when it boot from EMMC. Anytime please confirm that one EMMC or Nand device include one bootable image, it's very important.
Before burning image to eMMC, please prepare a USB disk. Let's take OpenWrt image (mtk-bpi-r3mini-EMMC-20230719.img, bl2_emmc.img) for example, the steps are below:
1. Copy EMMC boot OpenWrt image(mtk-bpi-r3mini-EMMC-20230719.img, bl2_emmc.img) to USB disk.
2. Change boot switch Jumper, the board boot from Nand device, then power up the board.
4. Execute following command to enable and copy image to EMMC device:
* dd if=mtk-bpi-r3mini-EMMC-20230719.img of=/dev/mmcblk0
7. power off R3MINI board, remove u-disk driver, change bootstrap to boot from emmc device.
Network-Configuration
root@OpenWrt:/# ifconfig
inet addr:192.168.1.1 Bcast:192.168.1.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:2418 (2.3 KiB)
RX bytes:0 (0.0 B) TX bytes:8538 (8.3 KiB)
RX bytes:0 (0.0 B) TX bytes:4408 (4.3 KiB)
Interrupt:124
RX bytes:0 (0.0 B) TX bytes:8674 (8.4 KiB)
Interrupt:124
lo Link encap:Local Loopback
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Interrupt:6
root@OpenWrt:/#
FAN
- R317 for 5V FAN and R318 for 12V FAN.
- CN23 supports PWM control while CN22 does not support.
PWM FAN Control
miniPCIe slot
SFP
After high and low temperature test, the following modules are suppoted by BPI-R3:
4G&5G
- BPI-R3 supports 4G LTE EC25.
- If you want to use 5G on BPI-R3:
Ap mode on BPI-R3
- ra0 is MT7986a 2.4G wifi
- rax0 is MT7986a 5G wifi
Wifi & Serial cable
UART_TX0 is the Boot Strapping PIN and must be kept low during power-on.
TTL Voltage
