Banana Pi BPI-R3 Mini
Banana Pi BPI-R3 Mini Router board with MediaTek MT7986(Filogic 830) quad core ARM A53 chip design ,2G DDR RAM ,8G eMMC flash onboard,It is a very high performance open source router development board,support Wi-Fi6 2.4G wifi use MT7976 and 5G wifi use MT7976, support 2 2.5GbE network port.
Application direction
- . Internet service Router
- . Wireless Router
- . Wireless Repeater
- . Home security Gateway
- . Home Automation
- . Nas device
- . Soft router
- MediaTek MT7986(Filogic 830) Quad core ARM Cortex A53
- Wifi 6 2.4G/5G(MT7976C)
- 2G DDR RAM
- 8G eMMC flash
- 128MB Nand flash
- 2x 2.5GbE network port
- 1x M.2 Key B USB inerface
- 1x M.2 KEY M PCIe inerface
- 1x USB2.0 interface
| HardWare Specification of Banana pi BPI-R3 Mini | |||
| CPU | MediaTek MT7986(Filogic 830) Quad core ARM Cortex A53 chip design | ||
| SDRAM | 2 GB DDR4 | ||
| On board Storage | Nand flash,8GB eMMC onboard | ||
| On board Network | 2 2.5GbE Ethernet | ||
| Wifi | Wifi 6 4x4 2.4G Wifi(MT7976) +4x4 5G Wifi(MT7976) | ||
| 1x M.2 Key B interface | |||
| M.2 Key M | 1x M.2 KEY-M PCIe inerface | ||
| USB | 1 USB 2.0 | ||
| 5 Leds | Power ,System, Wifi 2G ,Wifi 5G ,4G Lte ,SSD | ||
| DC Power | 20W/12V TypeC PD | ||
| Sizes | |||
| Weight | 100g | ||
SSD and 5G support
- Opensource Driver BSP
- BPI-R3 Mini DXF file : https://drive.google.com/file/d/1IoqG4o9SfWqgzOfeBqzOUJDo91EVPhjc/view?usp=sharing
- BPI-R3 schematic diagram :
- Bananapi R3 review with WiFi / CPU benchmarks and power consumption numbers: https://wiki.junicast.de/en/junicast/review/bananapi-BPI-R3
Release image
- 2023-07-19 BPI-R3 Mini OpenWRT image with Opensource Driver BSP
- Google Drive:https://drive.google.com/drive/folders/1Lf04fV3MW7XWssxHLLUlOaZmJh_lRLY5?usp=sharing
- Baidu Cloud: https://pan.baidu.com/s/1dsDxsNPttjbqg-qr7bHNWA?pwd=8888 (pincode:8888)
- 2023-07-19 BPI-R3 Mini OpenWRT image with MTK vendor driver, Not OpenSource Driver BSP
- Google Drive:https://drive.google.com/drive/folders/1KC0GAiTLUc_TK2g4rUD2AWgN4DXKNn2x?usp=sharing
- Baidu Cloud:https://pan.baidu.com/s/17h7Ts80noZqwDUYYaVPFIQ?pwd=8888 (pincode:8888)
Accessories
- BIPAI Aliexpress shop : https://www.aliexpress.com/item/1005005873750368.html?
- SINOVOIP Aliexpress shop: https://www.aliexpress.com/store/group/BPI-R3-Mini/1100417230_40000004378662.html?
- Taobao shop : https://item.taobao.com/item.htm?spm=a213gs.success.result.1.1bd14831HTwBxZ&id=730610953668
