Banana Pi BPI-W2
- Mali T820 MP3 GPU
- 2G DDR4 SDRAM
- 2 SATA interface
- HDMI in & HDMI out
- Mini DP
| HardWare Specification of Banana pi BPI-R2 | |||
| Soc | Realtek RTD1296 quad-core ARM A53 | ||
| GPU | Mali T820 MP3 GPU | ||
| SDRAM | 2GB DDR4 \(shared with GPU\) | ||
| Power | 12V @ 2A via DC power | ||
| Features | |||
| Low-level peripherals | 40 Pins Header, 28×GPIO, some of which can be used for specific functions including UART, I2C, SPI, PWM, I2S. | ||
| Onboard Network | 2x 10/100/1000Mbps Ethernet | ||
| Wifi/Bluetooth | **Option** ,not support onboard WIFI & BT | ||
| RGMII | 1 RGMII interface with PIN | ||
| On board Storage | MicroSD \(TF\) card, 2 SATA 6Gbps ,eMMC,SIM card slot | ||
| Display | HDMI \(Type A\) output with HDCP 1.4, resolutions up 1920x1200; MIPI DP | ||
| Video decoder/encode | The Video DSP of RTD1296 is dedicated to manipulating,decoding and encoding of video streams in various formats, e.g. decoding 4K2K H.265,Full HD MPEG1/2/4/H.264/H.264 MVC,AVC/VC-1,VP8,AVS,AVS Plus,HD jpeg,etc.Video decoding and encoding can run simultaneously. support 3D de-intrlacing,video scaling up to 4K2K and so on. | ||
| Aideo decoding | Audio decoding is carried out by an Audio DSP that is capable of decoding a set of audio formats,e.g. DTS HD,Dolby Digital Plus,TrueHD,and other popular formats.the Audio DSP also performs audio post processing | ||
| Audio | support two audio device HDMI and headphone, also support Audio In/Out with PIN define. support 2 MIC in | ||
| HDMI Out/In | 1\* HDMI out port and 1\* HDMI In port | ||
| Audio outputs/Inputs | HDMI, I2S audio,Audio micro out, Audio out/in with PIN define | ||
| M.2 KEY E:PCIE 2.0/USB 2.0 | 1 pcie 2.0 interface | ||
| M.2 KEY E:PCIe 1.1 / SDIO / USB 2.0 | 1 pcie 1.1 and SDIO interface | ||
| USB 3.0 | 1x USB 3.0 host | ||
| USB 2.0 | 2x USB 2.0 OTG, 1 with standard USB port , 1 define with PIN | ||
| M.2 KEY B | 1 * M.2 interface USB 2.0 for 4G with Micro SIM card slot | ||
| Mini DP | 1* Mini DP | ||
| TYPE C | 1 type C interface | ||
| RTC battery | RTC battery power interface | ||
| Leds | Red, Green, Blue | ||
| Other | IR reciever | ||
| Weight | 100g | ||
BPI-W2 GPIO PIN define
| Banana Pi BPI-W2 40-pin GPIO | |||
| GPIOPinName | DefaultFunction | Function2:GPIO | |
| CON1-P01 | VCC-3V3 | ||
| CON1-P02 | 5VD | ||
| CON1-P03 | I2C5\_SCL | GPIO13 | |
| CON1-P04 | 5VD | ||
| CON1-P05 | I2C5\_SDA | GPIO14 | |
| CON1-P06 | GND | ||
| CON1-P07 | PWM0\_0 | ||
| CON1-P08 | IGPIO3 | | ||
| CON1-P09 | | | ||
| CON1-P10 | IGPIO2 | | ||
| CON1-P11 | GPIO17 | | ||
| CON1-P12 | GPIO58 | | ||
| CON1-P13 | GPIO25 | | ||
| CON1-P14 | | | ||
| CON1-P15 | GPIO27 | | ||
| CON1-P16 | IGPIO5 | | ||
| CON1-P17 | | | ||
| CON1-P18 | IGPIO4 | | ||
| CON1-P19 | GPIO7 | | ||
| CON1-P20 | | | ||
| CON1-P21 | GPIO4 | | ||
| CON1-P22 | IGPIO9 | | ||
| CON1-P23 | GPIO5 | | ||
| CON1-P24 | GPIO6 | | ||
| CON1-P25 | | | ||
| CON1-P26 | GPIO8 | | ||
| CON1-P27 | GPIO12 | | ||
| CON1-P28 | GPIO11 | | ||
| CON1-P29 | GPIO100 | | ||
| CON1-P30 | | | ||
| CON1-P31 | GPIO21 | | ||
| CON1-P32 | GPIO54 | | ||
| CON1-P33 | GPIO59 | | ||
| CON1-P34 | | | ||
| CON1-P35 | GPIO57 | | ||
| CON1-P36 | GPIO22 | | ||
| CON1-P37 | GPIO23 | | ||
| CON1-P38 | GPIO24 | | ||
| CON1-P39 | | | ||
| CON1-P40 | GPIO60 | | ||
| BPI-W2 Debug UART \(CON3\) | | | | :--- | :--- | :--- | | CON2-P1 | GND | | | CON2-P2 | UART0-RX | | | CON2-P3 | UART0-TX | |
