BPI Open debugger board
Revision as of 03:00, 13 May 2018 by Sinovoip (talk | contribs)
Hardware Specification
Open Debugger is a set of programming tools in the development of STM series of microcontrollers, TI CC1x, 2x, TI CC3x series SOC, when STC Series MCU can be programmed quickly and easily debug, debugging programmer does not have to do something different series of chips switching plug tedious work. In addition, it also integrates a USB to serial port, which is a common interface for embedded development. It is also one of USB2.0 HUB, making it easy to extend to other USB tools. With it, no longer need to face a bunch of different writer, complicated mess of wiring, USB port deficiencies.
  • Operating Voltage:DC 5V
  • ting temperature:0°C to 85°C
  • The onboard voltage output::3.3 V
  • Maximum output current:2000 mA
  • Supported operating systems:
Microsoft® Windows® 2000
Windows XP SP2/SP3 operating system (32-bit versions)
Windows Vista® operating system (32 and 64 bit)
Windows 7 operating system (32 and 64 bit)
Windows 8 operating system (32 and 64 bit)
How to use
please see online gitbook doc : https://bananapi.gitbooks.io/bpi-open-debugger-burn-board/content/en/
