Banana Pi BPI-W2
  • Mali T820 MP3 GPU
  • 2G DDR4 SDRAM
  • 2 SATA interface
  • 1XGigabit LAN 1x Gigabit WAN
  • HDMI in & HDMI out
  • Mini DP
HardWare Specification of Banana pi BPI-R2
Soc Realtek RTD1296 quad-core ARM A53
GPU Mali T820 MP3 GPU
Power 12V @ 2A via DC power
Features
Wifi/Bluetooth **Option** ,not support onboard WIFI & BT
On board Storage MicroSD \(TF\) card, 2 SATA 6Gbps ,eMMC,SIM card slot
Display HDMI \(Type A\) output with HDCP 1.4, resolutions up 1920x1200; MIPI DP
HDMI Out/In 1\* HDMI out port and 1\* HDMI In port
USB 3.0 1x USB 3.0 host
Mini DP 1* Mini DP
TYPE C 1 type C interface
RTC battery RTC battery power interface
Leds Red, Green, Blue
Other IR reciever
Sizes 148 mm × 100.5mm
Weight 100g
