BPI-Bit
BPI:bit hardware
BPI:bit hardware description
BPI:bit interface
BPI:bit edge interface
BPI:bit PIN define
P3 | ADC2_CH4 | GPIO13 | |||
P4 | ADC2_CH3 | GPIO16 | |||
P5 | ADC1_CH7 | GPIO35 | |||
P6 | ADC2_CH5 | GPIO12 | |||
P7 | ADC2_CH6 | GPIO14 | |||
P1 | ADC1_CH4 | GPIO32 | |||
P8 | GPIO16 | ||||
P9 | GPIO17 | ||||
P11 | ADC2_CH7 | GPIO27 | |||
P12 | ADC2_CH2 | GPIO02 | |||
P2 | ADC1_CH5 | GPIO33 | |||
P13 | GPIO18 | SPI_SS | |||
P14 | GPIO19 | SPI_SCK | |||
P15 | GPIO23 | SPI_MISO | |||
P16 | GPIO05 | SPI_MOSI | |||
3V3 | POWER:3V3 | ||||
P19 | GPIO22 | I2C_SCL | |||
P20 | GPIO21 | I2C_SDA | |||
GND | GROUND | ||||
GND | GROUND | ||||
GND | GROUND |
BPI-bit software
BPI:bit for webduino
BPI: bit Webduino Firmware Burning
Burning method:
Select ESP32 DownloadTool:
File and burn position corresponding | |||
set | file name | Position | |
1 | bootloader_dio_40m.bin | 0x1000 | |
2 | partitions.bin | 0x8000 | |
3 | boot_app0.bin | 0xe000 | |
4 | bit_default.bin | 0x10000 |
- SpiFlashConfig:
SpiFlashConfig | |||
1 | SPI SPEED | 40NHz | |
2 | SPI MODE | DIO | |
3 | FLASH SIZE | 32Mbit | |
4 | COM | COMx(Fill in the port number assigned by the computer) | |
5 | BAUD | 1152000 |
During the burning process:
Finished:
Burn time is about 20s
Webduino source code on github
BPI:bit for arduino
