BPI-Bit
Revision as of 06:33, 12 May 2018 by Sinovoip (talk | contribs) (BPI:bit PIN define)
Overview: ESP32
Overview: ESP32
BPI:bit hardware
BPI:bit hardware description
BPI:bit interface
BPI:bit PIN define
HardWare Specification of Banana pi BPI-M2 zero
P3 ADC2_CH4 GPIO13
P0 ADC2_CH8 DAC_1 GPIO25
P4 ADC2_CH3
GPIO16
P5 ADC1_CH7
GPIO35
P6 ADC2_CH5
GPIO12
P7 ADC2_CH6
GPIO14
P1 ADC1_CH4
GPIO32
P8
GPIO16
P9
GPIO17
P10 ADC2_CH9 DAC_2 GPIO26
P11 ADC2_CH7
GPIO27
P12 ADC2_CH2
GPIO02
P2 ADC1_CH5
GPIO33
P13
GPIO18 SPI_SS
P14
GPIO19 SPI_SCK
P15
GPIO23 SPI_MISO
P16
GPIO05 SPI_MOSI
3V3
POWER:3V3 3V3
POWER:3V3 3V3
POWER:3V3 P19
GPIO22 I2C_SCL
P20
GPIO21 I2C_SDA
GND
GROUND GND
GROUND GND
GROUND
BPI:bit edge interface
BPI-bit software
BPI:bit for webduino
BPI: bit Webduino Firmware Burning
Burning method:
Select ESP32 DownloadTool:
set file name Position
2 partitions.bin 0x8000
3 boot_app0.bin 0xe000
4 bit_default.bin 0x10000
- SpiFlashConfig:
SpiFlashConfig
1 SPI SPEED 40NHz
2 SPI MODE DIO
3 FLASH SIZE 32Mbit
5 BAUD 1152000
During the burning process:
Finished:
Burn time is about 20s
Webduino source code on github
BPI:bit for arduino
