Banana Pi BPI-M64
Revision as of 23:31, 12 May 2023 by Sinovoip (talk | contribs)
Banana Pi BPI-M6 with Synaptics VS680
Banana Pi BPI-M5 Amlogic S905X3 Processor
Banana Pi BPI-M4 Realtek RTD1395
Overview:Allwinner A64
Premium Aluminum Enclosure
BPI-M64 acrylic case
BPI-M64 for BPI 4.0 Successful case : A64 for smart home design
BPI-M64 for BPI 4.0 Successful case :A64 for IoT gateway design
Banana Pi BPI-M64 is a 64-bit quad-core mini single board computer. It features 2GB of RAM and 8GB eMMC. It also has onboard WiFi and BT. On the ports side, the BPI-M64 has 2 USB A 2.0 ports, 1 USB OTG port, 1 HDMI port, 1 audio jack, and lastly a DC power port. The processor is pin-to-pin comptialbe with R18, so it comes with two versions:M64 and M64-R18.
  • Allwinner A64 1.2 Ghz Quad-Core ARM Cortex A53 64-Bit Processor.
  • 2 GB DDR3 SDRAM
  • 8G EMMC
  • 10/100/1000Mbps Ethernet
  • WiFi (AP6212) & Bluetooth
  • MIPI LCD interface
  • Camera interface
HardWare Specification of Banana pi BPI-M64
CPU Allwinner 64 Bit Quad Core ARM Cortex A53 1.2 GHz CPU
GPU Dual core Mali 400 MP2 GPU
Memory 2GB LPDDR3 (shared with GPU)
Network 10/100/1000 Mbit/s Ethernet + Wi-Fi 802.11 b/g/n + Bluetooth 4.0
Video Output(s) 1080p capable HDMI port and multi-channel audio output (NO H./X.265 capabilities)
Remote IR Receiver
LED Power Status and 8P8C
Size & Weight 92x60mm, 48g
OS Android and Linux
Banana Pi BPI-M64 has a 40-pin GPIO header . Following is the Banana Pi GPIO Pinout:
40 PIN GPIO of Banana pi BPI-M64
CON2-P01 VCC-3V3
CON2-P02 VCC-5V
CON2-P03 TWI1-SDA PH3
CON2-P04 VCC-5V
CON2-P05 TWI1-SCK PH2
CON2-P06 GND
CON2-P07 PH6 PH6
CON2-P08 UART2-TX PB0
CON2-P09 GND
CON2-P10 UART2-RX PB1
CON2-P11 PH7 PH7
CON2-P12 UART2-CTS PB3
CON2-P13 DMIC-CLK PH10
CON2-P14 GND
CON2-P15 DMIC-DIN PH11
CON2-P16 UART2-RTS PB2
CON2-P17 VCC-3V3
CON2-P18 PD4 PD4
CON2-P19 SPI1-MOSI PD2 UART4-TX
CON2-P20 GND
CON2-P21 SPI1-MISO PD3 UART4-RX
CON2-P22 PC0 PC0
CON2-P23 SPI1-CLK PD1 UART3-RX
CON2-P24 SPI1-CS PD0 UART3-TX
CON2-P25 GND
CON2-P26 PC2 PC2
CON2-P27 PC4 PC4
CON2-P28 PC3 PC3
CON2-P29 PC7 PC7
CON2-P30 GND
CON2-P31 PCM0-BCLK PB5
CON2-P32 PCM0-DIN PB7
CON2-P33 PCM0-SYNC PB4
CON2-P34 GND
CON2-P35 PCM0-DOUT PB6
CON2-P36 PL9 PL9
CON2-P37 PL12 PL12
CON2-P38 PL7 PL7
CON2-P39 GND
CON2-P40 PL8 PL8
CSI camer PIN define of Banana pi BPI-M64
CN5-P01 NC
CN5-P02 GND
CN5-P03 CSI0-SDA PE13
CN5-P04 CSI0-AVDD
CN5-P05 CSI0-SCK PE12
CN5-P06 CSI0-Reset PE16
CN5-P07 CSI0-VSYNC
CN5-P08 CSI0-PWDN PE17
CN5-P09 CSI0-HSYNC PE2
CN5-P10 CSI0-DVDD
CN5-P11 CSI0-DOVDD
CN5-P12 CSI0-D7 PE11
CN5-P13 CSI0-MCLK PE1
CN5-P14 CSI0-D6 PE10
CN5-P15 GND
CN5-P16 CSI0-D5 PE9
CN5-P17 CSI0-PCLK PE0
CN5-P18 CSI0-D4 PE8
CN5-P19 CSI0-D0 PE4
CN5-P20 CSI0-D3 PE7
CN5-P21 CSI0-D1 PE5
CN5-P22 CSI0-D2 PE6
CN5-P23 GND
CN5-P24 CSI0-AFVCC
MIPI DSI display PIN define of Banana pi BPI-M64
CN6-P01 VCC
CN6-P02 IPSOUT
CN6-P03 VCC
CN6-P04 IPSOUT
CN6-P05 GND
CN6-P06 IPSOUT
CN6-P07 GND
CN6-P08 IPSOUT
CN6-P09 NC
CN6-P10 GND
CN6-P11 NC
CN6-P12 DSI-D0N
CN6-P13 NC
CN6-P14 DSI-D0P
CN6-P15 NC
CN6-P16 GND
CN6-P17 TWI0-SDA PH1
CN6-P18 DSI-D1N
CN6-P19 TWI0-SCK PH0
CN6-P20 DSI-D1P
CN6-P21 CTP-INT PH4
CN6-P22 GND
CN6-P23 CTP-RST PH8
CN6-P24 DSI-CKN
CN6-P25 GND
CN6-P26 DSI-CKP
CN6-P27 LCD-BL-EN PD5
CN6-P28 GND
CN6-P29 LCD-RST PD6
CN6-P30 DSI-D2N
CN6-P31 LCD-PWR-EN PD7
CN6-P32 DSI-D2P
CN6-P33 GND
CN6-P34 GND
CN6-P35 LCD-PWM PL10
CN6-P36 DSI-D3N
CN6-P37 GND
CN6-P38 DSI-D3P
CN6-P39 NC
CN6-P40 GND
Uart PIN define of Banana pi BPI-M64
CON2 P03 UART0-TXD PB8
CON2 P02 UART0-RXD PB9
CON2 P01 GND
Win 10 IoT
banana pi BPI-M64 IOT certifying pass by Microsoft:windows 10 iot core
BPI-M64 for Win10 IoT : https://catalog.azureiotsolutions.com/details?title=Allwinner_Banana_Pi_BPI_M64&source=all-devices-page
link: https://azure.microsoft.com/en-us/documentation/articles/iot-hub-tested-configurations/
get start:
https://github.com/Azure/azure-iot-sdks/blob/master/doc/get_started/windows10-iot-core-banana-pi-bpi-m64-csharp.md
test on BPI-M64
discuss on forum: http://forum.banana-pi.org/t/banana-pi-bpi-m64-iot-certifying-pass-by-microsoft-windows-10-iot-core/2090
Windows 10 IoT Core for BPI-M64 Release Note
This document describes how to build AllWinner UEFI Firmware and bring a AllWinner dev board up with it. The AllWinner UEFI Firmware, as the major boot system for AllWinner-Windows platform, is based on the EDK2 framework which is open-source and with some AllWinner platform software packages injected.
Some updates:
1. Update the OS version to build v.10.0.15063.0 \(Creators Update\)
2. New page style of Device Portal, visit [1](https://deviceipaddr:8080) to check it
3. Built-in Cortana assistant, need to be enabled in settings page in default app and Device Portal
4. Support on-screen keyboard, need to be enabled in Device Portal
5. Enable 100M Ethernet and fix some bugs
6. Support built-in UART bus in A64 SoC\(not built in the ffu, later provide driver binary and deployment helper\)
7. Support built-in IR module in A64 SoC\(not built in the ffu, later provide source code and dev doc for developers in community\)
Known Issues:
Kernel debug is enabled by default. This will slow the bring-up process. If a kernel debug is not necessary for you, visit Device Portal and navigate to Processes->Run Command page, run this command to disable : Bcdedit /store C:\EFIESP\EFI\Microsoft\boot\BCD /set {default} debug off
An PnP bug in audio device may cause a blue screen when acting software shutdown
Ethernet device may not start with problem code 12 at the first time to bring up
And another bomb! I uploaded core driver binaries and packaging toolchains on GitHub!
Here is the repo address: https://github.com/Leeway213/BSP-aw1689
And also some driver source code here with A64 datasheet in readme: https://github.com/Leeway213/driver-samples
Welcome makers developers and anyone-elsers to post your feedback.
Microsoft Azure IoT
  • we have test BPI-M64 with Microsoft Azure IoT with aarch64 Ubuntu 18.04 Linux
Microsoft Azure IoT Edge using DPS with TPM 2.0 SLB9670 : https://www.youtube.com/watch?v=k9_GSQgKlqk&feature=youtu.be
Microsoft Azure IoT Edge using DPS with TPM 2.0 ST33 i2c : https://www.youtube.com/watch?v=2MrO1-esjwI&feature=youtu.be
  • BPI-M64 Android 7 source code
download link : https://github.com/BPI-SINOVOIP/BPI-A64-Android7
  • BPI-M64 Android 6.0.1 source code
download link : https://drive.google.com/open?id=0B_YnvHgh2rwjdTRVRVFaSHd2cnc
  • BPI-M64 (allwnner A64) Linux 4.4 source code
https://github.com/BPI-SINOVOIP/BPI-M64-bsp-4.4
Forum pthread: http://forum.banana-pi.org/t/banana-pi-bpi-m64-allwnner-a64-linux-4-4-source-code-public-on-github/6706
  • BPI-M64 Linux kernel 3.4 BSP code:
github link : https://github.com/BPI-SINOVOIP/BPI-M64-bsp
  • BPI-M64 Win10 IoT source code
https://bananapi.gitbooks.io/bpi-m64/content/en/sourcecodeongithub.html
  • BPI-M64 Robot Operating System (ROS):
github: https://github.com/techping/BPI-robot-1
discuss on forum: http://forum.banana-pi.org/t/discuss-robot-operating-system-ros-on-banana-pi/10967
documents
google driver :google driver
baidu cloud : http://pan.baidu.com/s/1kVRpcYb
BPI-M64 BT Lab test :https://bananapi.gitbooks.io/bpi-m64/content/en/bpi-m64bt40labtest.html
BPI-M64 WIFI Lab test :https://bananapi.gitbooks.io/bpi-m64/content/en/bpi-m264wifilabtest.html
BPI-M64 Validation test : https://bananapi.gitbooks.io/bpi-m64/content/en/bpi-m64validationtestreport.html
CE FCC RoHS : http://forum.banana-pi.org/t/bpi-m64-ce-fcc-rohs-certification/2747
Amazon AWS Greengrass
Banana Pi BPI-M64 passed Amazon AWS Greengrass:https://devices.amazonaws.com/detail/a3G0h000000OvPoEAK/Banana-Pi-BPI-M64
How to install the Android image
  • 2020-07-10 update, Android 7.1, base on kernel 3.10
Download Android 7.1 image
  • 2018-10-24 update Android 6.0 & 7.0 & 8.1, based on kernel 3.10.
M64 Android 6.0 HDMI & LCD7
Features Map: http://wiki.banana-pi.org/M64_Image_Map#Android_6.0
HDMI Version Image Links:
Google Drive : https://drive.google.com/open?id=1Em7ZXVvbJI7wMXy_TM4VNwHo6Oa-vVBc
Baidu Drive : https://pan.baidu.com/s/1ZginIvO3LVakqokIZAX1Xw
LCD7 Version Image Links:
Google Drive : https://drive.google.com/open?id=1Tts1krZyzwz9mL90j1ilTzVrJm6hh_J4
Baidu Drive : https://pan.baidu.com/s/1oKMx_Ml5K1Jv7-qeS-NMsQ
M64 Android 7.0 HDMI & LCD7
Features Map:http://wiki.banana-pi.org/M64_Image_Map#Android_7.0
Google Drive : https://drive.google.com/open?id=1mvKyK6KuPixs-jLD0FocIaV465bJ1Eig
Baidu Drive : https://pan.baidu.com/s/15b32TXdh6752c-GBnR-Zeg
Google Drive : https://drive.google.com/open?id=16Ffc5xiZgD7JYgrMtCGaOYLCuZdQGcnY
Baidu Drive : https://pan.baidu.com/s/1a9RYKSTRhCO-UzFfIoGCtQ
  • BPI-M64 Android 8.1 HDMI & LCD7
Features Map:http://wiki.banana-pi.org/M64_Image_Map#Android_8.1
Google Drive : https://drive.google.com/open?id=1UBaH9CNbmC9-n3jGImrFIAPZ8aZhqMJz
Baidu Drive : https://pan.baidu.com/s/1lz57HrqNHx6f_Q6nk0oZvA
Google Drive : https://drive.google.com/open?id=1wktuCcvolfozMFkLmugfZtGziHDj-1EM
Baidu Drive : https://pan.baidu.com/s/1MteYqyBp8LeECjcDteCTZQ
  • 2018-9-17 update android 6.0
Features Map :http://wiki.banana-pi.org/M64_Image_Map#Android_6.0
Google Drive : https://drive.google.com/open?id=19ExJ9Ztfy3UgK9NZ4SiaVZAMozgyCJl7
Baidu Drive : https://pan.baidu.com/s/1s_orgiEI7JU_hUgjnpd25w
Google Drive : https://drive.google.com/open?id=1gWD_IT0P4NvdeqtK5I4MnJjwzsP7SXJc
Baidu Drive : https://pan.baidu.com/s/1K0HYPiQe6nGvAS5bAAFHow
Forum pthread : http://forum.banana-pi.org/t/banana-pi-bpi-m64-new-images-release-2018-09-18/6796
  • 2018-08-17 update,android 8.1
This release is for banana pi M64 board which is based on Allwinner A64, We have two images release,Android 8.1 is based on kernel 4.9
BPI-M64 Android 8.1 Features Map:http://wiki.banana-pi.org/M64_Image_Map#Android_8.1
HDMI-LCD-Version:
Google Drive : https://drive.google.com/open?id=11XjvTAbPw57R6H5kL27GVXry4xu18dVs
Baidu Drive : https://pan.baidu.com/s/1PQgJCUo6cY3wWxJ7rZrk-A
Forum pthread:http://forum.banana-pi.org/t/bananapi-bpi-m64-a64-new-image-android-8-1-ubuntu-release-2018-08-17/6531
  • 2018-05-20 update ,android 7.0
hdmi-Version and Lcd 5.0 version
baidu cloud : https://pan.baidu.com/s/1O3PsI73WmFFvhxMmzEscIQ
  • 2017-05-11 update ,android 6.0
HDMI-Version
Google Drive:https://drive.google.com/open?id=0B_YnvHgh2rwjcF9USm1MWWtxSXc
Baidu Cloud:https://pan.baidu.com/s/1bHWhlW
MD5: f85281213b9c5b88008a487dd1b6963c
LCD-Version
Google Drive:https://drive.google.com/open?id=0B_YnvHgh2rwjdHpFbHJMQWtsbFk
Baidu Cloud:https://pan.baidu.com/s/1kVJVPGV
MD5:be27e4eced96d3de81d46e512fd978eb
forum pthread:http://forum.banana-pi.org/t/bpi-m64-new-image-android-6-0-version-v3/3240/4
How to install BPI Linux Image
  • 2020-08-26 update, Ubuntu Mate 18.04, Ubuntu Server 16.04, Raspbian Stretch, base on kernel 4.4
Download Image
  • 2020-04-21 update, Rasbian Stretch, Ubuntu 16.06 Mate Desktop, Ubuntu 16.06 Server and Ubuntu 18.04 Mate Desktop, base on kernel 4.4
google drive:https://drive.google.com/drive/folders/0B_YnvHgh2rwja3I4SllZN2VkYm8
baidu cloud:https://pan.baidu.com/s/18XH8_uusUGBusbp4xw4txQ Pincode:36R0
  • 2018-11-02 update, based on kernel 3.10 & kernel 4.4.
BPI-M64 Ubuntu 16.04 Desktp
Features Map: http://wiki.banana-pi.org/M64_Image_Map#Ubuntu_Desktop_16.04
Google Drive : https://drive.google.com/file/d/1YzdkY8i-IsXzXLkbPCPNbAuhYbHmUwgv/view
Baidu Drive : https://pan.baidu.com/s/1XhOJBQtPkhvidjgipFNdzg
md5sum : 3564f0d3de9936aa26b93eaf027703a0
BPI-M64 Ubuntu 16.04 AARCH64 Kernel 3.10
Features Map : http://wiki.banana-pi.org/M64_Image_Map#Ubuntu_Desktop_aarch64_16.04
Google Drive : Chttps://drive.google.com/file/d/1MglySZLvquRPu1Wj8oLwdKBkFnRzLUL-/view
Baidu Drive : https://pan.baidu.com/s/1_ZTDCuL9QZf6qrqaE4gbgQ
md5sum : 7422e02daa01bff6de808490e89b436e
BPI-M64 Ubuntu 16.04 AARCH64 Kernel 4.4
features Map:http://wiki.banana-pi.org/M64_Image_Map#Kernel_4.4.89
Google Drive : https://drive.google.com/file/d/1g_m1NLn1-wUQ8jjPKEAwQcSj4d4P9vRP/view
Baidu Drive : https://pan.baidu.com/s/1JmKQGRKvJ9DwL_ij0K79FA
md5sum : ea9bba6ab7fc78f7b8478bfd013a9b50
forum pthread: http://forum.banana-pi.org/t/banana-pi-bpi-m64-new-images-ubuntu16-04-desktop-aarch64-release-2018-11-1/7159/1
Debian 9.5 AARCH64 Kernel 3.10
Features Map: http://wiki.banana-pi.org/M64_Image_Map#Debian_9.5_AARCH64
Image Links: Google Drive : Coming soon
Baidu Drive: https://pan.baidu.com/s/1DJd7CGAT0NiijKfOBq9J4Q
md5sum: 71fe25c1922c7f9ef81bb88e0f544de6
  • 2018-4-17 update Ubuntu 16.04.4 with linux kernel 4.4.89
image name:2018-04-17-ubuntu-16.04-mate-desktop-demo3-k4.4.89-vdpau-3-mic-docker-bpi-r18-avs-aarch64-sd-emmc.img.zip
Google Drive: https://drive.google.com/open?id=1dlfo9LGNcrc-_cpKd1uJnrNx0PdonBnK
MD5: 4b7e163d260e58a39ba8905e7ed39943
Forum pthread:http://forum.banana-pi.org/t/bpi-r18-avs-new-image-ubuntu-16-04-4-with-linux-kernel-4-4-89-2018-4-17/5435
  • 2018-09-18 This release is for banana pi M64 board which is based on Allwinner A64, We release three Images, Ubuntu 16.04 Desktop & Android is based on kernel 3.10.
Features Map :http://wiki.banana-pi.org/M64_Image_Map#Ubuntu_Desktop_16.04
Google Drive :
Baidu Drive : https://pan.baidu.com/s/1wANJ4SwfNwKtBcd02WcbWA
forum pthread : http://forum.banana-pi.org/t/banana-pi-bpi-m64-new-images-release-2018-09-18/6796
  • 2018-08-17 update Ubuntu 16.04 Server kernel 3.10.105
Google Drive : https://drive.google.com/open?id=1K-B4u8jGcv17s3I9v-Pr0xv5u5txvfok
Baidu Drive : https://pan.baidu.com/s/1HcrR8NsL9_1RwbZNa7uwmg
  • 2017-08-14 update based on ubuntu 16.04.3 LTS Mate Desktop (64-bit),support BPI-M64 kernel 3.10.105
Google Drive: https://drive.google.com/file/d/0B_YnvHgh2rwjN1h1U0xDYUxET00/view?usp=sharing
baidu cloud: http://pan.baidu.com/s/1pLkbdTT
MD5: ae34baa840874276858d936a7ca85c4f
Forum pthread:http://forum.banana-pi.org/t/bpi-m64-new-image-2017-08-14-ubuntu-16-04-mate-desktop-beta-aarch64-bpi-m64-sd-emmc/3695
  • 2022-09-07 Armbian_22.11.0-trunk_Bananapim64_bullseye_edge_5.19.7_xfce_desktop.img
Google Drive:https://drive.google.com/file/d/1UUbn24l3q_OsVP4XWT6eVQN531tHPzX0/view?usp=sharing
Baidu Cloud:https://pan.baidu.com/s/1vFR9sUR0FhWgS1pemk9lTg?pwd=ina6 (pincode: ina6)
  • 2018-11-2 update , This release is for banana pi M64 board which is based on Allwinner A64, We release two Images, Debian 9.5 AARCH64 is based on kernel 3.10 & kernel 4.4.
M64 Debian 9.5 AARCH64 Kernel 3.10
Features Map : * http://wiki.banana-pi.org/M64_Image_Map#Debian_9.5_AARCH64
Google driver : https://drive.google.com/file/d/10qGv2gVrSgwXMBLDsCF0nQFc9EJnnkeS/view
Baidu Drive : https://pan.baidu.com/s/1DJd7CGAT0NiijKfOBq9J4Q
md5sum : 71fe25c1922c7f9ef81bb88e0f544de6
M64 Debian 9.5 AARCH64 Kernel 4.4
Features Map: * http://wiki.banana-pi.org/M64_Image_Map#Debian_9.5_AARCH64
Google Drive : https://drive.google.com/file/d/17fh3YY6cwOzHMsqwnRQRTu9cXjKU4_tV/view
Baidu Drive : https://pan.baidu.com/s/1sOR6WFz2U9MT0ltq6zYnJA
md5sum : f3c2391b0232178018fda7ebfd64b14c
forum pthread:http://forum.banana-pi.org/t/banana-pi-bpi-m64-new-images-debian-9-5-aarch64-release-2018-11-02/7166
  • 2017-08-13 debian 8.9 jessie Mate Desktop (64-bit),support BPI-M64 kernel 3.10.105
Google Drive:https://drive.google.com/file/d/0B_YnvHgh2rwjazlNRTRHei1NbmM/view?usp=sharing
baidu cloud:http://pan.baidu.com/s/1eSeTQeA
MD5: 9ddf067457ebaf193de63c5c7141446a
Forum pthread:http://forum.banana-pi.org/t/bpi-m64-new-image-2017-08-13-debian-8-jessie-mate-desktop-preview-aarch64-bpi-m64-sd-emmc/3694
  • Armbian_23.02.0-trunk_Bananapim64_jammy_current_5.15.93.img.xz
  • Armbian_23.02.0-trunk_Bananapim64_jammy_edge_6.1.11_xfce_desktop.img.xz
Baidu Cloud: https://pan.baidu.com/s/1hkkl22uVjvRct1V7N4OK2w?pwd=8888
Google Drive: https://drive.google.com/drive/folders/1VpvVkYMqgmSnmfKXQSrEY2B6wRa-cggL?usp=share_link
Discuss on forum: https://forum.banana-pi.org/t/banana-pi-bpi-m64-new-armbian-image/15161
  • 2022-09-07 Armbian_22.11.0-trunk_Bananapim64_jammy_edge_5.19.7_xfce_desktop.img
Google Drive:https://drive.google.com/file/d/1_BaSpSdIaxJYy-QjaXLsOrJ25Ja7vA78/view?usp=sharing
Baidu Cloud:https://pan.baidu.com/s/1uOex7pm2tPhfJ47hoXIuGA?pwd=7hms (pincode: 7hms)
Raspbian
  • 2018-11-06 update : This release is for banana pi M64 board which is based on Allwinner A64, We release two Images, Raspbian 9.4 is based on kernel 3.10 & kernel 4.4.
BPI-M64 Raspbian 9.4 Kernel 3.10
Features Map : http://wiki.banana-pi.org/M64_Image_Map#Raspbian_9.4_AARCH64
Google Drive : https://drive.google.com/file/d/1qoKCVDgiuEj0IVEzuPgzuFLjFR9hTLH8/view
Baidu Drive : https://pan.baidu.com/s/1MlIzQRpjs_soBDXOKf8NAw
md5sum : e321c6dbb096a0348fceb9d4a0b6c210
BPI-M64 Raspbian 9.4 Kernel 4.4
Features Map : http://wiki.banana-pi.org/M64_Image_Map#Kernel_4.4.89_4
Google Drive : https://drive.google.com/file/d/1WnsHKnbI_FWQVkHQmbCcJ3yJ38oWaHGy/view
Baidu Drive : https://pan.baidu.com/s/1Bu-xiqiYsnau_xZp8-QEkw
md5sum : 1d4f00680e6869e2c4e66e205e61d93d
forum pthread: http://forum.banana-pi.org/t/banana-pi-bpi-m64-new-images-raspbian-9-4-kernel-3-10-4-4-release-2018-11-06/7195
Fedora Linux
  • BPI-M64 fedora image download(not support desktop): fedora 31 with grub (u-boot-2019.07 + kernel 5.3.0)
https://drive.google.com/file/d/1dIr943Ke28lEtCDpy8cI3q1dBUtHymJP/view?usp=drivesdk
https://drive.google.com/file/d/1F3nYOw9AiLLaz8be0umz_9nlnhDP3t0s/view?usp=drivesdk
Forum pthread:http://forum.banana-pi.org/t/bananapi-bpi-m64-new-image-fedora-31-with-grub-u-boot-2019-07-kernel-5-3-0/9938
Manjaro
  • 2019-01-15 update,BananaPi BPI-M64 Support Run Manjaro AArch64 System
Baidu Drive: https://pan.baidu.com/s/18drwPBFKAzf4lFe6IPjaPA
Google Drive: https://drive.google.com/open?id=1Lu8xw4sAVyiHJT4eYcolNTAIKG154gm6
Bpi Ftp Server: https://dev.banana-pi.org.cn/Image/BPI-M64/Manjaro/
md5sum : 8c9964fbd80836228c72fa205eb62f78
username: manjaro/root
password: bananapi
Forum pthread:http://forum.banana-pi.org/t/bananapi-bpi-m64-new-image-manjaro-aarch64-system-2019-01-16/7696
FreeBSD
Clonezilla
Others
Win 10 IoT
  • 2017-1-13 updae Win10 IoT Core beta0.2
baidu cloud :http://pan.baidu.com/s/1c2ce100
  • Win10 IoT Core 10586 beta0.1
download link : https://drive.google.com/open?id=0B_YnvHgh2rwjODJOSS1TdkRvcEk
baidu link : http://pan.baidu.com/s/1dEQyGgD
MD5: 1c09118cd45bf0c3b61d1846710a3649
  • 1,How-to use ubuntu system to support lcd7**?
1."vi /media/pi/BPI-BOOT/bananapi/bpi-m64/linux/lcd7/uEnv.txt"
2.If you use HC070TG lcd7 screen, change "touch=gt9xxnew_ts" But if you use S070WV20 lcd7 screen, you don't need to change.
3. "bpi-bootsel /usr/lib/u-boot/bananapi/bpi-m64/u-boot-with-dtb-bpi-m64-lcd7-8k.img.gz"
4.reboot
For more operation details please see Wiki: http://wiki.banana-pi.org/Getting_Started_with_M64
